pgroell
Posted: Tue Sep 16, 2008 1:35 am Post subject: Z13-8B Brown-out battery question |
Hello,
I have a question about the Z13-8B drawing.
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8B(BrownOutBattery).pdf
I understand that the brown-out battery relay opens when pushing the engine start button, disconnecting the brownout battery from the main battery circuit.
But I am right to think that in order to have the E-bus energized by the brown-out battery at cranking time, the e-bus alternate feed switch has to be closed.
Or is the alternate feed relay closed by another mean I'm unable to figure out reading the drawing.
Thanks for your help.
Pascal GROELL
www.notreavion.net
nuckolls.bob(at)cox.net Guest
Posted: Tue Sep 16, 2008 4:20 am Post subject: Z13-8B Brown-out battery question |
At 02:35 AM 9/16/2008 -0700, you wrote:
Hello,
battery circuit.
brown-out battery at cranking time, the e-bus alternate feed has to be closed.
Your analysis is correct. To use this feature for the purpose
of preventing reset of e-bus feed systems due to starter
inrush brown-out, the e-bus alternate feed switch needs to
be closed during starting.
( -Thomas Paine 1776- )
pgroell(at)yahoo.fr Guest
Posted: Tue Sep 16, 2008 8:30 am Post subject: Z13-8B Brown-out battery question |
Hello,
Thanks for the answer
Best regards
Pascal
| Quote: | -----Message d'origine-----
De : owner-aeroelectric-list-server(at)matronics.com [mailto:owner-
aeroelectric-list-server(at)matronics.com] De la part de Robert L.
Nuckolls, III
Envoyé : mardi 16 septembre 2008 14:21
À : aeroelectric-list(at)matronics.com
Objet : Re: Z13-8B Brown-out battery question
<nuckolls.bob(at)cox.net>
>Hello,
>battery circuit.
the
closed.
figure
