Fwd: rubber pipe
hervechaussures(at)tiscal
PostPosted: Mon Sep 15, 2008 1:18 am    Post subject: Fwd: rubber pipe Reply with quote
Date: Mon, 15 Sep 2008 10:16:13 +0100
To: sales(at)matronics.com
Subject: rubber pipe
Does any one know where I could get a rubber pipe ,2 inches in
diameter,and 2 inches in length to fit in my rotax 914.it is the
rubber which fit in between the carburetor and the air box to the turbo.
G.CHET 914
Herve
davidjoyce(at)doctors.org
PostPosted: Mon Sep 15, 2008 1:31 am    Post subject: Fwd: rubber pipe Reply with quote
Herve, Have you tried Europa? Regards, David Joyce, G-XSDJ
PostPosted: Mon Sep 15, 2008 1:38 am    Post subject: Fwd: rubber pipe Reply with quote
Date: Mon, 15 Sep 2008 10:17:54 +0100
Subject: Fwd: rubber pipe
>From: Herve <hervechaussures(at)tiscali.co.uk>
>G.CHET 914
>Herve
craigb(at)onthenet.com.au
PostPosted: Mon Sep 15, 2008 2:02 am    Post subject: Fwd: rubber pipe Reply with quote
Just a thought, but if you really get stuck, you could cut down a radiator
hose from a large
car or small truck. Could well be cheaper too
craig
PostPosted: Mon Sep 15, 2008 2:08 am    Post subject: Fwd: rubber pipe Reply with quote
Hi David
I got the last one from europa,but it only lasted 4 hours.I need a stronger one
Gilles.Thesee(at)ac-greno
PostPosted: Mon Sep 15, 2008 2:27 am    Post subject: Fwd: rubber pipe Reply with quote
stronger one
Herve,
It is a part related to the engine manufacturer rather than the airframe
manufacturer. Have tried your Rotax importer/dealer ? IIRC the p/n
should appear in the parts catalog.
Also, for those installing an aftercooler, the exchanger core weight
must be adequately supported lest the exchanger or turbo bear the
additional weight.
Those rubber hoses are very similar to radiator hoses, so in a pinch I
would try a radiator/truck store.
Best regards,
Gilles
http://contrails.free.fr
