Starboard spar pin bush
craigb(at)onthenet.com.au
PostPosted: Sat Sep 13, 2008 7:21 pm    Post subject: Starboard spar pin bush Reply with quote
Just wondering if anyone has, or is considering, replacing the Starboard
bush in the starboard wing with a nut
or threaded plate, to allow more positive location of the spars on that
side, which might also allow for easier
rigging, obviously it would need to have a diameter less than 12mm (half
inch) if the port wing bushes are to be
unchanged.
Craig
peterz(at)zutrasoft.com
PostPosted: Sat Sep 13, 2008 8:52 pm    Post subject: Starboard spar pin bush Reply with quote
I may be misunderstanding the suggestion, but if the proposal is to introduce threads onto the main spar pins, I would suggest that treads may introduce a shear-point in the pin, weakening it substantially. I would suggest staying with the std factory smooth pins.
JMHO, YMMV, etc, etc....
Cheers,
Pete
A239
On Sat, Sep 13, 2008 at 11:27 PM, craig bastin <craigb(at)onthenet.com.au (craigb(at)onthenet.com.au)> wrote:
[quote]--> Europa-List message posted by: "craig bastin" <craigb(at)onthenet.com.au (craigb(at)onthenet.com.au)>
unchanged.
Craig
PostPosted: Sat Sep 13, 2008 9:31 pm    Post subject: Starboard spar pin bush Reply with quote
My thought was to leave the front 80% (or so) of the original bushing
in the wing spar and then the nut or threaded plate on the back of the spar and a tapered thread on the new pin from the 12mm down just enough to allow a nice lock up of the spar into the seat back. and then set
the clearance with washers in the same way as the port side pip pin. Looking at the clearance I believe this would be do-able with a small relief in the starboard quick connect plate to allow the nut/ plate to slide past.
Visit - www.EuropaOwners.org
jrgowing(at)bigpond.net.a
PostPosted: Sat Sep 13, 2008 11:41 pm    Post subject: Starboard spar pin bush Reply with quote
Craig
when you put in the front and reary lift pins you should be able to have
them locate the spar snugly in its place against the cockpit module.
JR Bob Gowing UK Kit 327 in Oz
PostPosted: Mon Sep 15, 2008 12:36 am    Post subject: Starboard spar pin bush Reply with quote
Yes I have them in and it's all fine, I was just thinking a "postive"
retention of the spar/pins
etc would be safer, and give me more piece of mind, I am probably worrying
about nothing.
