bmeyette
Posted: Sat Sep 13, 2008 3:15 pm Post subject: Nosewheel Breakout Force |
IIRC, mine squished down quite a bit, but not completely flattened.
Once you get the breakout force set, you drill the leg for a cotter pin
Brian
_________________ Brian Meyette, Cornish, NH
RV-7A QB tipup, supercharged Subaru STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM
http://brian76.mystarband.net/RV-7Ahome.htm |
carl.froehlich(at)cox.net Guest
Posted: Sun Sep 14, 2008 3:58 am Post subject: Nosewheel Breakout Force |
Keep in mind you will need to tighten the nut again after the first few
landings and takeoffs. Make sure you get grease throughout the nose fork.
Carl Froehlich
RV-8A (450 hrs)
RV-10 (wings)
