robertrv607(at)yahoo.com Guest
Posted: Fri Sep 05, 2008 11:20 am Post subject: Efis Question |
Hello:
I am considering buying the Efis-D10A, For those with this unit,
question 1- Do you find it, to work proplerly, and are you happy with
it.
2- How difficult is to connect. I am tired of working under that
crowded space,,,,All I need would be basic fuctions...
NO G or anyof the options...
Does any one has the schematic, drawings for connection..
it shows a 25 pin connector....do I have to have 25 wires????
Finally, when installing this unit, what instruments one remove
from the pannel....I believe the Attitud Ind. is out??
What happens if the unit fails? one would be without a very essential
tool..... for safety etc...
Your comments and suggestions appreciated...
Bert
rv6a
Do not Archive
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
bobbyhester(at)newwavecom Guest
Posted: Fri Sep 05, 2008 2:08 pm Post subject: Efis Question |
I have it and yes it works great! Not real hard to connect, you'll have
to tee into the pitot and static lines, and run a few wires (not 25).
You can see how I have mine in my panel in the attached pictures. The G
meter is just an option that is available and does not require any thing
extra to install. The second picture I attached is the optional screen
you can bring up if you have a Garmin GPS wired into it.
Surfing the web from Hopkinsville, KY
Visit my website at: http://www.geocities.com/hester-hoptown/RVSite/
bert murillo wrote:
Quote: |
Hello:
it.
Bert
rv6a
Do not Archive
Description: |
Filesize: |
75.75 KB |
Viewed: |
587 Time(s) |
Description: |
Filesize: |
72.5 KB |
Viewed: |
618 Time(s) |
carl.froehlich(at)cox.net Guest
Posted: Fri Sep 05, 2008 6:48 pm Post subject: Efis Question |
Bert,
I replaced an electric RC Allen AI with the D10A. I feed it with the serial
output from my GX-60 GPS nav/comm, and will also feed it from a SL-30
nav/comm when I save up a few more pennies.
In short, the D10A has done everything Dynon advertises it would do, and
considering the continuous (and free) software upgrades from Dynon I expect
it will do more in the future. The D10A is about the best bang for the buck
as you can get.
Some thoughts:
1. Get the EDC D10A remote compass. While I flew with just the internal
compass for a few months and found it to work well, the external compass is
far easier to calibrate and it is required if you want to input outside air
temperature into the D10A. With outside air temperature the D10A provides
continuous True Air Speed indication as well as wind direction and wind
speed. I find I use this wind information far more than I expected and now
would not want to be without it.
2. As I have dual batteries I did not get the battery backup. Your install
may be different.
3. As I only removed the AI to install the D10A, I still have all the
standard steam gauges (air speed, altitude, vertical speed). Considering
the minor cost, I would recommend having these standard instruments in the
panel along with the D10A.
4. The HSI function works just as good as a standard HSI.
5. If you are going to use the D10A for glide slope and localizer
indication, you should consider getting two D10As. That way you can keep
the normal display up on one and HSI on the other. Considering the cost of
a CDI head these day, a second D10A make a whole lot more sense than putting
a standalone CDI in the panel.
6. If you can solder wires to a D connector, you can install the D10A.
7. Dynon has a list of known GPS and Nav radios that customer report
working with the D10A. You should call them to see if what you are planning
to feed it is on the list or not.
8. While the D10A does not need GPS input to work, the GPS input provides
the data to compute wind speed and direction. Either a GPS or a Nav input
is needed of course for HSI functions.
9. I have a Navaid wing level for my autopilot. When it dies I'll get the
Dynon servo and feed it off the D10A. Again the best bang for the buck for
an autopilot.
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
marty_away(at)hotmail.com Guest
Posted: Sat Sep 06, 2008 5:34 am Post subject: Efis Question |
FWIW C Talking with the DYNON president at AirVenture C he stated they are trying to add synthetic vision to their system next year.
Marty Heller
RV-7 C fitting canopy
[quote] From: carl.froehlich(at)cox.net
To: rv-list(at)matronics.com
Subject: RE: Efis Question
Date: Fri C 5 Sep 2008 22:47:55 -0400
--> RV-List message posted by: "Carl Froehlich" <carl.froehlich(at)cox.net>
Bert C
output from my GX-60 GPS nav/comm C and will also feed it from a SL-30
In short C the D10A has done everything Dynon advertises it would do C and
as you can get.
Some thoughts:
compass for a few months and found it to work well C the external compass is
may be different.
3. As I only removed the AI to install the D10A C I still have all the
standard steam gauges (air speed C altitude C vertical speed). Considering
the minor cost C I would recommend having these standard instruments in the
indication C you should consider getting two D10As. That way you can keep
a CDI head these day C a second D10A make a whole lot more sense than putting
6. If you can solder wires to a D connector C you can install the D10A.
8. While the D10A does not need GPS input to work C the GPS input provides
an autopilot.
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
Posted: Thu Sep 11, 2008 10:37 am Post subject: Efis Question |
Bobby : Again thanks for the reply.. have a question, do you have any schematic
drawing shoing the wiring, the way you did it?
It would be a great help to see how it is done...
thanks
Bert
--- On Fri, 9/5/08, Bobby Hester <bobbyhester(at)newwavecomm.net> wrote:
Quote: | From: Bobby Hester <bobbyhester(at)newwavecomm.net>
Subject: Re: Efis Question
Date: Friday, September 5, 2008, 6:07 PM
Quote: | I have it and yes it works great! Not real hard to connect, you'll have
bert murillo wrote:
Quote: | --> RV-List message posted by: bert murillo
<robertrv607(at)yahoo.com>
Quote: |
Hello:
it.
Bert
rv6a
Do not Archive
sbuc(at)hiwaay.net Guest
Posted: Thu Sep 11, 2008 10:52 am Post subject: Efis Question |
bert murillo wrote:
Quote: | Bobby : Again thanks for the reply.. have a question, do you have any schematic
thanks
Bert
Dynon installation manual with all wiring schematics and pinouts can be
downloaded here:
http://www.dynonavionics.com/downloads/Install_Guides/EFIS-D10A%20Installation%20Guide.pdf
In particular see section 2, "Wiring Overview".
Sam Buchanan
Posted: Thu Sep 11, 2008 11:51 am Post subject: Efis Question |
Sam: Thanks for the info. One question, when I make the harness, at least I
hope I can,,, hate to pay $200 plus for one....is better to use all the pins,
that is connect all 25 wires, even if I do not need them... or should I save myself
a lot of work, and use only the minimun required.. to connect the unit....
your suggestions will be appreciated as always.
Bert
rv6a
Date: Thursday, September 11, 2008, 2:51 PM
Quote: | --> RV-List message posted by: Sam Buchanan <sbuc(at)hiwaay.net>
schematic
thanks
Bert
downloaded here:
Sam Buchanan
Posted: Thu Sep 11, 2008 7:17 pm Post subject: Efis Question |
bert murillo wrote:
Quote: | Sam: Thanks for the info. One question, when I make the harness,
at least I hope I can,,, hate to pay $200 plus for one....is better
to use all the pins, that is connect all 25 wires, even if I do not
need them... or should I save myself a lot of work, and use only the
Bert rv6a
Bert, I would use only the pins necessary to make the connections you need.
Sam Buchanan
Posted: Fri Sep 12, 2008 6:19 am Post subject: Efis Question |
bert
Date: Thursday, September 11, 2008, 11:16 PM
Bert rv6a
Sam Buchanan
Posted: Sun Sep 21, 2008 9:24 am Post subject: Efis question |
Hi:
I posted this before did not go thru...I try again..
I will be ready soon to install my Efis..10- the question is what happpens if this
thing failed, I understand I have to remove my Attitud Ind., if nothing else for
lack of space, which is the case for me...now you would be without the most important
Indicator...specially under IMC,,
Would like to hear comments, for those with experience on this unit etc..
Bert
rv6a
Bruce(at)glasair.org Guest
Posted: Sun Sep 21, 2008 1:19 pm Post subject: Efis question |
Probably dead.
Bruce
www.Glasair.org
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Posted: Mon Sep 22, 2008 5:40 am Post subject: Efis question |
Bruce:
you have a glassair? any how what is the answer...
--- On Sun, 9/21/08, Bruce Gray <Bruce(at)glasair.org> wrote:
[quote]From: Bruce Gray <Bruce(at)glasair.org>
Subject: RE: Efis question
Date: Sunday, September 21, 2008, 5:15 PM
Probably dead.
Bruce
www.Glasair.org
ronlee(at)pcisys.net Guest
Posted: Mon Sep 22, 2008 6:26 am Post subject: Efis question |
Bert, if you are IMC and all you have is an EFIS for spatial orientation
and you lose it then most likely within a minute or two you will enter
uncontrolled flight and will soon be dead.
People...think about what you are doing.
Ron Lee
jfogarty(at)tds.net Guest
Posted: Mon Sep 22, 2008 7:39 am Post subject: Efis question |
Ron, That is a great point.
Jim
RV9a building - MN
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Mon Sep 22, 2008 6:38 pm Post subject: Efis question |
That is true whether it is an EFIS or a "steam gauge" attitude indicator that is your sole spatial orientation reference.
David Maib
Jim
RV9a building - MN
[quote]---
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
tcone1(at)comcast.net Guest
Posted: Mon Sep 22, 2008 7:49 pm Post subject: Efis question |
Since when is a loss of ADI or artificial horizon an automatic trip to the morgue?
Don't they teach "partial panel" anymore?
Posted: Mon Sep 22, 2008 8:30 pm Post subject: Efis question |
Do you think that most people are competent at partial panel in IMC?
The oroginal poster suggested that panel space was an issue which I find
hard to believe.
Perhaps a good wing-leveler/autopilot might save you in you lost your
only attitude source.
Ron Lee
Posted: Mon Sep 22, 2008 10:34 pm Post subject: Efis question |
I'm really not trying to be snide, but if they aren't competent at partial panel, what in the heck are they doing penetrating IMC???? Betting their life that everything works? I'll take the odds in Vegas over that bet, any day.
Training is a much better investment than ANY gizmo.
Tim Cone
Posted: Tue Sep 23, 2008 4:05 am Post subject: Efis question |
Tim, look at accident reports and you will find that 75% or so of the fatalities are due to pilot error.
You have running out of fuel.
You see flying into IMC when the pilot is not instrument rated but had been trained on partial panel.
The Seaside OR crash appears to be a guy of unknown (to me) qualifications taking off into IMC.
There was a plane that took off out of Steamboat Springs CO or close who impacted terrain.
The weather was not suitable for this VFR pilot to fly and possibly not for any plane not certified
for flight into icing conditions. I have not seen the report but would guess that it was gross
pilot error. A family killed because of pilot stupidity.
You see all kinds of Darwinistic behavior. Reality. A gizmo "may" make up for other system
or human failures. Better judgement and training are perhaps better.
The original poster needs to objectively assess his training, abilities and judgement and plan
accordingly. Leaving out a alternate attitude reference that works for him may get him killed.
Adding a "gizmo" might save him.
Ron Lee
Posted: Tue Sep 23, 2008 4:35 am Post subject: Efis question |
I thought I didn't have a dog in this fight, but I do. I have lost
friends, and friends of friends, due to stupid pilot tricks. Rarely
does the airframe let us down. That leaves two things .... the pilot,
and his source of information. There are times when no amount of
information will save the pilots bacon ...... let's face it ..... we all
do the stupid pilot tricks ..... and an old pilot is one that survives
all of his (or her) stupid mistakes. So far I'm a survivor.
Now, back to my dog. I'm going to install the Odyssey panel
(http://www.mglavionics.com/html/odyssey.html)
and am going through the process of choosing how I want to populate the
rest of the panel with backup instruments for IFR. By the time I
purchase 2.5" gauges I can almost buy a small efis system, independent
of the Odyssey. My problem is .... I've never flown behind a glass
panel ..... and don't have an IFR ticket (yet). My partner has/does
both ..... but for him there is a pilot and a copy of the left seat
panel on the right side. I've spent a fair amount of time pondering the
question of which path to go ..... and I've been collecting a few
pictures of others panel ..... which just turns my thought processes
into a headache. But I ramble ..... my question is this: What did you
choose for your IFR backup capability, and why did you go that
route???? Would you go that same route today????
Linn
Ron Lee wrote:
[quote] Tim, look at accident reports and you will find that 75% or so of the
Ron Lee
