edgraydallas
Posted: Thu Sep 11, 2008 9:50 am Post subject: Kitfox-List Digest: 25 Msgs - 09/10/08 |
I'm about ready to cover the fuse of my Kitfox II, ser. No. 605 and making
decision about elevator trim (do I run wire for elec. Or cable for manual
trim like Eurofox. Sonny Logan who built No. 36 two decades ago tells me no
trim needed, just use flaperons. I'm thinking a simple bungee pulling elev.
Tube either way with a small rope and a sailboat clam cleat is the simplest.
Any input appreciated.
Dennis Golden, if you see this, you can practice covering technique on my
bird at no charge. Have you made an engine decision yet?
Ed Gray Dallas KII Rotax 582 GSC 3 blade
lcfitt(at)sbcglobal.net Guest
Posted: Thu Sep 11, 2008 10:42 am Post subject: Kitfox-List Digest: 25 Msgs - 09/10/08 |
Ed,
Some of the guys are installing an electric trim with a flat elevator -
without ribs, using a bubble to cover the trim servo like is standard on the
Rans. I have the bubbles or can do the whole install if you want. Contact
me off list for info or some tips if you want to do a homebrew.
Lowell
peteohms
Posted: Thu Sep 11, 2008 11:21 am Post subject: Kitfox-List Digest: 25 Msgs - 09/10/08 |
My III trims just fine with flaps.
Pete
Hell Paso, TX ,912, sn 1000
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
