frans(at)paardnatuurlijk. Guest
Posted: Mon Sep 08, 2008 11:24 pm Post subject: Cabin vent - air outlet? |
It is easy to install air inlets, there are plenty of examples in the galleries and build logs.
But when air enters the cabin, air has also to be able to leave somewhere.
How have people accomplished this? I don't see any examples for this.
Originally, I planned to make an exit in the D-panel, and let the air escape via the rear fuselage (trim tab slots). But now I've read that the rear fuselage has a higher pressure than the cabin.
What is the best way to vent the cabin, to obtain a steady airflow, rather than trying to pressurize the cabin or to get oscillations in the air? Any ideas or satisfying implementations?
Frans
Visit - www.EuropaOwners.org
Posted: Tue Sep 09, 2008 1:42 am Post subject: Cabin vent - air outlet? |
Lance who is building a Mono about three hours drive from myself has an
outlet installed in the top
of the "D" that vents to freestream airflow just behind the bulkhead via
ramp simmilar to a cowl flap
exit, it slopes in line with the fuselage so rain etc doesnt try and fill up
the "outlet" while parked
I plan to do the same on mine, from memory he has a small baffle plate that
can be adjusted as needed and closed
when parked.
craig
philipgeorge347(at)hotmai Guest
Posted: Tue Sep 09, 2008 2:02 am Post subject: Cabin vent - air outlet? |
Frans . You will find if it is a mono wheel Cair will be drawn out thru the wheel- well as this is a low pressure area .Being drawn thru the retraction lever slot . This is not so on the tri-gear.
Phil George .XS Mono wheel.
Quote: | Subject: Cabin vent - air outlet?
Date: Tue C 9 Sep 2008 10:23:40 +0300
--> Europa-List message posted by: "Frans Veldman" <frans(at)paardnatuurlijk.nl>
It is easy to install air inlets C there are plenty of examples in the galleries and build logs.
But when air enters the cabin C air has also to be able to leave somewhere.
Originally C I planned to make an exit in the D-panel C and let the air escape via the rear fuselage (trim tab slots). But now I've read that the rear fuselage has a higher pressure than the cabin.
What is the best way to vent the cabin C to obtain a steady airflow C rather than trying to pressurize the cabin or to get oscillations in the air? Any ideas or satisfying implementations?
Frans
&g=
Try Facebook in Wint/01/' target='_new'>Try it Now! [quote][b]
wooburnaviation(at)google Guest
Posted: Tue Sep 09, 2008 2:05 am Post subject: Cabin vent - air outlet? |
Well we must have had a particulary draughty rear fuselage, as we had a domestic plastic vent grill in the D panel, and that seemed to work fine when combined with a NACA duct. I think the NACA placement is more important, bearing in mind the low pressure that definately exists on top of the wing !
Dave
On 09/09/2008, Frans Veldman <frans(at)paardnatuurlijk.nl (frans(at)paardnatuurlijk.nl)> wrote: [quote]--> Europa-List message posted by: "Frans Veldman" <frans(at)paardnatuurlijk.nl (frans(at)paardnatuurlijk.nl)>
josok-e(at)ukolo.fi Guest
Posted: Tue Sep 09, 2008 2:55 am Post subject: Cabin vent - air outlet? |
Don'f wotty about venting out, if there would be over-pressure in the cabin, it will lift/bulge the doors enough to escape. The rear of the fuselage definitively has a higher pressure, probably from high pressure air from under the wings entering the flap drive slots. There always was a cold draft though the flying controlsblowing into the cockpit. The UC slot did not have any effect. With flaps down, slow approach, there was an exhaust smell entering from somewhere.Never found out from where, opening the vents fully reduced it.
Jos Okhuijsen
raimo.toivio(at)rwm.fi Guest
Posted: Tue Sep 09, 2008 3:45 am Post subject: Cabin vent - air outlet? |
Thatīs true. Through the UC slot you can see mother ground
but nothing comes in.
Somebody wrote years ago if you forget to close the door(s) properly
(one shooting bolt is not in) you will notice it soon,
because in that case the UC slot will be an air inlet instead of outlet.
I have had no problems with air outlets.
During cold seasons I feel some nasty draught (extra air inlets) from
the headrest and seat ass storage areas. They should be fully closed but
obvioushly they are not. They are on my list to improve. Any ideas?
Raimo from Finland
OH-XRT
kheindl(at)msn.com Guest
Posted: Tue Sep 09, 2008 5:52 am Post subject: Cabin vent - air outlet? |
Frans,
One neat solution is by Ian Rickard, with an opening in the D-panel and ducted to an outlet in the tailfin.
I never noticed any problem, with a little vent in the rear of the door , and as Josok says, air will also escape past the door seals.
Karl
Date: Tue, 9 Sep 2008 10:23:40 +0300
Frans
Posted: Tue Sep 09, 2008 6:35 am Post subject: Cabin vent - air outlet? |
Frans
I used to notice the draft tugging gently at my sleeve! It is worth
putting a nylon latch half way along the door frame to hold the latched
door in place
Graham
Karl Heindl wrote:
Quote: |
Frans,
Karl
Posted: Tue Sep 09, 2008 1:56 pm Post subject: Cabin vent - air outlet? |
Thanks for the answers. I'm building a tri-gear by the way. As air inputs I have a scoop in the top (in the closed position it is completely level with the fuselage), windows with a vent opening, and these ACS "ultimate vents" just below the instrument panel. I guess this is enough for air vents.
The general consensus seams to be that the doors will function as an air exit. I'm not to happy with that, for I try to keep them into their intended shape (have some aluminium bar rivited in to discourage them from bulging out) and using them as an exit will probably generate some noise. Good idea that the area above the wing will be low pressure, I could maybe make some gills in the bagage bay just above the wing. Anything that enters via the flap slots will find a quick way out then as well.
Frans
hagargs(at)earthlink.net Guest
Posted: Tue Sep 09, 2008 6:43 pm Post subject: Cabin vent - air outlet? |
I had vents in the D panel and the higher pressure in the back caused
some exhaust getting into the flap slots while going slow to enter the
cockpit. After performing a preflight on a Liberty (certificated Europa?)
I noted 2 openings on the bottom of the fuselage. Each had a reverse
scoop over it. I went back to my Europa. I already had an access door
under the fuselage for the gascolator. I pulled the door off approx 4"
X 5" and fashioned a reverse scoop out of fiberglass. In addition to
this I made better closure of the flap slots using rubber sheeting. The
results were noticeably better, using a CO monitor. I now only get a short
beep once in a while in the pattern rather than exceeding limits.
Steve Hagar
A143
Mesa AZ
Quote: | [Original Message]
To: <europa-list(at)matronics.com>
Date: 9/9/2008 12:27:37 AM
Quote: | But when air enters the cabin, air has also to be able to leave somewhere.
g-iani(at)ntlworld.com Guest
Posted: Wed Sep 10, 2008 1:53 am Post subject: Cabin vent - air outlet? |
Frans
Karl has made reference to my vent mod. I have tidied up the documentation
a little and it is attached. I do not suggest it is the right solution
rather an experiment. So far I have not made the time to do any detailed
measurements.
I have never detected air moving in or out round my door seals.
Ian Rickard G-IANI XS Trigear, 200 hours
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
Description: |
 Download |
Filename: |
Cabin_Air_Extractor.pdf |
Filesize: |
317.86 KB |
Downloaded: |
127 Time(s) |
sidsel.svein(at)oslo.onli Guest
Posted: Wed Sep 10, 2008 7:40 am Post subject: Cabin vent - air outlet? |
After consulting with EA2004 about any possible strength issues (none), I
built an air outlet vent on top of the fuselage behind the doors - see
attached photo. This is a low pressure area.
Under the fore part of this vent is a 2 inch hole through the fuselage. I
built a sliding valve under the hole to partially or fully close the
opening. I have, however, during two years of flying never adjusted this
valve from full open, whether in summer time or during the winter, so I
consider it unnecessary to have it. Air flow through the cockpit is instead
controlled only by the fresh air or heater inlets (either ones always open
to some extent).
Svein
LN-SKJ
Description: |
Filesize: |
47.88 KB |
Viewed: |
169 Time(s) |
Posted: Wed Sep 10, 2008 1:08 pm Post subject: Cabin vent - air outlet? |
[quote:9df425b733="g-iani"]Frans
measurements.
-----[/quote:9df425b733]
I like this mod. Looks like a low drag solution and very effective, provided that the stern post is a low pressure area indeed. I'm going to try this, if it doesn't work very well I have not made any modification to the exterior of the airplane, so I can easily undo it. It doesn't take much to implement this.
Another mod could be to make this opening, but without the hose. This might reduce the pressure in the rear fuselage, keepiing the exhaust fumes away from the cockpit, and a vent in the D-panel will then also work better.
Frans
steven.pitt2(at)ntlworld. Guest
Posted: Wed Sep 10, 2008 10:32 pm Post subject: Cabin vent - air outlet? |
I have fitted Ian's mod and it also appears to work as I do not have the
tugging shirtsleeves from the doors. My only comment about positioning is
that if you go below the 'd' in the bulkhead, if you travel any distance
with luggage this blocks the outlet. The positioning is a compromise.
Steve Pitt
G-SMDH
Posted: Thu Sep 11, 2008 12:44 am Post subject: Cabin vent - air outlet? |
Frans
Quote: | I like this mod. Looks like a low drag solution and very effective,
implement this.<
Yes that was my thinking
Quote: | Another mod could be to make this opening, but without the hose. This might
from the cockpit, and a vent in the D-panel will then also work better.<
Yes we have tried this and it does make a difference. As I said we have not
had time to do detailed measurements.
karelvranken(at)hotmail.c Guest
Posted: Thu Sep 11, 2008 11:12 am Post subject: Cabin vent - air outlet? |
Svein,
You say the area where you placed the outlet is a low pressure area. Are you
sure? Did you measure that pressure? I think when the profile is diminishing
the pressure raises. On that place I have an intake for ventilation and even
in hot days I can't open fully the inlet because the windstream can't be
endured for a long time.
Karel Vranken. F-PKRL
Posted: Thu Sep 11, 2008 12:25 pm Post subject: Cabin vent - air outlet? |
[quote:67f80f7028="stevenwpitt"]
Steve Pitt
G-SMDH
-----[/quote:67f80f7028]
I was thinking about putting it in the top of the bulkhead. As I have a hi-top, there is excess space above this 'D'.
Frans
Posted: Thu Sep 11, 2008 1:33 pm Post subject: Cabin vent - air outlet? |
Karel,
No, I have not measured the pressure, I relied on what EA2004 said also
about the pressure in this area. I think they were correct, because the air
speed over the top is higher than the airplane's speed through the ambient
air and hence the pressure is lower than the ambient pressure (compare the
fuselage profile to a wing profile - higher speed hence lower pressure on
top of the wing).
All I can say for sure is that the pressure at my vent outlet is lower than
in the cockpit, because air goes out through that vent (I can feel the air
flow by holding my hand under the outlet opening). The air pressure in the
cockpit may be higher than ambient, though, because of the efficient NACA
intakes on both sides (built as per Europa standard). If air comes in
through your vent, it must mean that your cocpit pressure is lower than at
your top vent opening. Where does this air leave your cockpit?
Svein
Posted: Fri Sep 12, 2008 11:41 am Post subject: Cabin vent - air outlet? |
Svein,
Air leaves the cockpit area trough the undercarriage lever arm sleeve and
perhaps other holes. I can put a botlang leaf on this place and it will not
move.
Karel Vranken #447 F-PKRL
