AndrewTR30
Posted: Wed Sep 10, 2008 7:38 pm Post subject: Aeroshell 5 or 6 |
Which one of these two greases is better suited for use in wheel bearings. From the site, it looks like #5 but in my plans, Vans says to use #6...
Or is there something better altogether?
_________________ Andrew Rayhill
RV-10 40078
Phoenix |
Kellym
Posted: Wed Sep 10, 2008 7:57 pm Post subject: Aeroshell 5 or 6 |
I'm no where that far along in the build process..........but, for
grins, I own a Mooney M20E which is 1644 lbs empty, 2575 gross, and it
specifies Aeroshell #5 for wheel bearings. #6 is lighter. I've had it in
Phoenix for 10 years, with no issues on the wheel bearings using #5.
Given our dry heat, I'd be inclined to use #5 unless I got a very good
explanation why #6 was recommended.
Kelly
RV10 40866
CHD
AndrewTR30 wrote:
Andrew Rayhill
RV-10 40078
Phoenix
http://forums.matronics.com/viewtopic.php?p 3749#203749
KCHD |
bobbyhester(at)newwavecom Guest
Posted: Thu Sep 11, 2008 3:23 am Post subject: Aeroshell 5 or 6 |
My Cleveland wheels had a sticker on them when they were new that said
they put Aeroshell 22 in the bearing at the factory, so that is what I use.
Surfing the web from Hopkinsville, KY
Visit my website at: http://www.geocities.com/hester-hoptown/RVSite/
AndrewTR30 wrote:
Andrew Rayhill
RV-10 40078
Phoenix
Charles Heathco
Posted: Fri Sep 12, 2008 4:20 am Post subject: Aeroshell 5 or 6 |
Anyone know if these numbers mean viscosity? would they be like wire , biger number thiner, or vice/versa? Charlie
rv9jim(at)juno.com Guest
Posted: Fri Sep 12, 2008 5:39 am Post subject: Aeroshell 5 or 6 |
Charlie,
The higher the number the thicker the grease. Normally, a #2 is
the most common viscosity you will find. It goes down- #1, 0, 00, 000,
then it goes to heavy oils. "Drop point" temperature is more critical
for our wheel bearings. Our bearings get hot (altho for a short time) so
the higher the drop point temp the better it is for us. This means
that if you put a "blob" of grease on a steel plate and put it vertical
and heat it, what temp will the grease begin to slide down the plate and
off the steel plate. The synthetic based greases are prefered as they
have the highest drop point temps while maintaining their viscosity. I
sell regular #2 grease that has a drop point around 300* and a synthetic
that is also a viscosity #2 that has a drop point temp of 560*.
Needless to say I use the synthetic based greases. The side bar on the
synthetic greases is they are "water proof" vs: regular grease that will
absorb the water and thus put the water in direct contact with the
bearing. Rust occurs even tho you use regular grease. The synthetic
based greases will not absorb water. I live in the Florida area with
lots of trailers that haul boats in and out of the ocean. You can see
real quick what works and what does not.
Jim Nelson
RV9-A
N15JN
Dreaming of getting away? Click here for an island experience in Hawaii.
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3nKLOkLZEILgh2wQmZ0yTepHPH9cmbiNAUpUZj9uwiZzJA4D/
Ed Anderson
Posted: Fri Sep 12, 2008 6:09 am Post subject: Aeroshell 5 or 6 |
Jim, your note on grease peaked my interest. Do you have any brand names of
the synthetic wheel bearing grease suitable for the RV wheel bearings you'd
care to share??
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
http://www.andersonee.com
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
http://www.dmack.net/mazda/index.html
_________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
