Classic stall characteristics (High Top Mod)
g-iani(at)ntlworld.com
PostPosted: Sun Sep 07, 2008 2:32 am    Post subject: Classic stall characteristics (High Top Mod) Reply with quote
Frans
Both the original High Top (with the high cowl) and the new version (lowered
cowl, bigger screen) the difference in max speed and cruise speed (for a
fixed power setting) is too small to measure given the other variables such
as weight and very small build differences.
The only thing I have noticed since we completed testing is that the new
(64b) setup seems to be very slightly less stable in pitch. Having modified
the aircraft we cannot go back to the original to get a real comparison.
The new deeper screen seems to generate a little more lift from the
fuselage. Flying "hands off" in gusty conditions, and directly into wind,
the nose will hunt up and down very slightly with a period of about 10
seconds. This is so slight that the original High Top may have been the
same but we did not notice until we started to look carefully for
differences. If you have your hand on the stick you damp this out. Most of
this testing was done with the TruTrak autopilot on to maintain the heading
and this could be the cause.
Has any other high top owner noticed anything similar?
Ian Rickard G-IANI XS Trigear, 200 hours
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
frans(at)paardnatuurlijk.
PostPosted: Sun Sep 07, 2008 8:32 am    Post subject: Classic stall characteristics (High Top Mod) Reply with quote
Hi Ian,
You might be interested to know that we have incorporated a modified
mod64b, that is, we have lowered the forward section only by 3,5 cm
(about halfway), and made it parallel with the lower fuselage. With some
juggling we were able to use the original windscreen for this. (Actually
we bought the deeper windscreen as well, but this one was not going to
fit with our modified mod, so we extended the rear window flange
slightly so we could use the original windscreen, which was a bit
oversized anyway). We thought this to be a good alternative because:
1) We didn't like the look of mod 64b too much (don't feel offended,
this is just a matter of personal taste), and now it looks much more
like a regular Europa XS. The windscreen remains flatter, and does not
extend below the side windows.
2) We already built a customised instrument panel, which partly utilized
the taller panel space available.
3) We wanted to have a better view outside, but we didn't desire to see
the entire cowling. Wink
We are not flying yet, but you may be sure we will give a detailed
report. Not that this will say anything, as we have incorporated a few
more mods.
If we find some time we will post a few pictures. Too busy building
until now to worry about pictures. Wink
Frans
PostPosted: Sun Sep 07, 2008 12:13 pm    Post subject: Classic stall characteristics (High Top Mod) Reply with quote
A picture about my hi-top mod64B mod:
[img:9080fbc341]http://www.privatepilots.nl/europa/modfranshi.jpg[/img:9080fbc341]
Visit - www.EuropaOwners.org
PostPosted: Mon Sep 08, 2008 12:49 am    Post subject: Classic stall characteristics (High Top Mod) Reply with quote
Frans
Pictures as soon as possible please.
I never feel offended that others decide to do things in a new and different
way. This is what the Club and development is all about. What we want to
do is to take the best ideas and make them available to others. Yours may
be better looking, structurally stronger, easier to fly, cheaper to produce
etc or it may be the opposite so let us all know what you are doing.
Perhaps we could do an article for the Europa Flyer at some stage. It would
also be useful to know what regulations apply to what you are doing. In the
UK we would need to convince the LAA that it was sound engineering.
PostPosted: Mon Sep 08, 2008 3:19 am    Post subject: Classic stall characteristics (High Top Mod) Reply with quote
Hi Ian,
I posted already a picture. It shows where I cut the upper fuselage. It
also shows that I had to fiddle a little bit with the window flange to
make the window fit again. The rear flange got a bit narrow, so I
extended it with 5 layers of bid, then temporary put the window in with
plastic tape over the edges to fil the gap with expancel. For the lower
flange I extended the 3mm foam from the insert and shaped it into the
window's curve. The cut itself is fixed a la the mod 64B manual. On the
outside there are a few extra layers of bid. It is probably stronger
than it used to be. Once this was ready, fitting and bonding the window
was no different than normally.
The idea was that the hi-top extended the head room with 5 cm, but the
firewall with 7 cm. Compared to the normal XS this would cut 2 cm of the
lower part of the vision to the outside. I wanted to take that back,
plus a little bit more, without changing the look of the normal XS, and
retaining the panel space that became available by the still taller
firewall.
It would
In the Netherlands we have no regulations. Very Happy Well, we need a compass,
an ASI, and Altitude gauge. There is no inspection. Once the airplane is
ready I only need a statement from a certified mechanic (not an
inspector!) that he has no objections and that's it! He will walk
around, kick the tires, confirm that it pretty much looks like an
airplane, and sign it off. I don't have to tell anything about mod's etc.
Once I have gone through that, I'm finished with it for the rest of my
life. The builder is considered to be the manufacturer, and once a year
I have to sign a document that I maintained my airplane conform the
rules of the manufacturer (yep, that's me too), in order to get a new
airworthiness certificate. If I want to cut off the last foot of my
wings, to see how it flies without it, I'm free to do so.
It is no coincidence that some mod's (nose wheel springs, tail wheel
mod, etc.) originate from the Netherlands. This is probably the most
liberal country for experimentals worldwide.
Frans
david.stanbridge(at)swift
PostPosted: Mon Sep 08, 2008 11:32 am    Post subject: Classic stall characteristics (High Top Mod) Reply with quote
One contributing factor to the reduced stability will be that the higher fuselage perimeters resulting from the modification has shifted the aerodynamic centre of the wing / fuselage combination forward. This then reduces the longitudinal static margin (distance between CG and AC) and as a result the aircraft will be less stable in pitch.
Frans
David Stanbridge
