skidmk
Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
Posted: Thu Sep 04, 2008 12:26 pm Post subject: Metric screws etc |
Looking to replace all my painted screws on the airframe with Stainless ones... has anyone done this? I prefer phillip heads to slotted, would anyone know how many 4mm or 5mm I would require.
M
_________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
dougsappllc(at)gmail.com Guest
Posted: Thu Sep 04, 2008 12:37 pm Post subject: Metric screws etc |
Yep, have them in stock, pls contact me off list.
Best,
Doug Sapp
On Thu, Sep 4, 2008 at 1:26 PM, skidmk <skidmk(at)gmail.com (skidmk(at)gmail.com)> wrote:
[quote]--> Yak-List message posted by: "skidmk" <skidmk(at)gmail.com (skidmk(at)gmail.com)>
M
Ottawa, Ontario
[url=http://forums.matronics.com/viewtopic.php?p 2608#202608]http://forums.matronics.com/viewtopic.php?p 2608#202608[/url]
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
pa3arw(at)euronet.nl Guest
Posted: Thu Sep 04, 2008 12:47 pm Post subject: Metric screws etc |
You need a lot, around 150 pieces of each minimum, expensive though, but
worth it. I have changed them all by stainless steel ones.
I would strongly recommend to use torx screws instead, they are more
suitable ( they fit a lot better) for electric screw drivers with adjustable
torque.
Hans O.
RA3326K
Netherlands
-----Oorspronkelijk bericht-----
Van: owner-yak-list-server(at)matronics.com
[mailto:owner-yak-list-server(at)matronics.com] Namens skidmk
Verzonden: donderdag 4 september 2008 22:27
Aan: yak-list(at)matronics.com
Onderwerp: Metric screws etc
M
Ottawa, Ontario
Posted: Thu Sep 04, 2008 1:13 pm Post subject: Metric screws etc |
Actually for a CJ6 you need 336 of the 4mm, and 102 of the 5mm. And not all that expensive (at)26.00 per hundred.
Always Yakin,
Doug
On Thu, Sep 4, 2008 at 1:47 PM, Hans Oortman 1 <pa3arw(at)euronet.nl (pa3arw(at)euronet.nl)> wrote:
[quote]--> Yak-List message posted by: "Hans Oortman 1" <pa3arw(at)euronet.nl (pa3arw(at)euronet.nl)>
torque.
Hans O.
RA3326K
Netherlands
Van: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)
[mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] Namens skidmk
Aan: yak-list(at)matronics.com (yak-list(at)matronics.com)
M
Ottawa, Ontario
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
petervs(at)knology.net Guest
Posted: Fri Sep 05, 2008 12:11 pm Post subject: Metric screws etc |
I bought 500 4mm and 200 5mm and have a few left on my yak. I put a nylon
washer underneath each screw to prevent any corrosion between the ss screw
and the aluminum. Even though the screws varied in length from 8 to 12 mm, I
bought all 12mm and had no problems. I bought the screws wholesale for about
$19 per hundred, and the washers from McMaster Carr.
Pete
Posted: Fri Sep 05, 2008 1:17 pm Post subject: Metric screws etc |
Guys,
There are many styles of Phillips head screws, some pan head, some truss head, some low profile truss head just to name a few. They come in many different profiles, pitches and head styles. If you want the correct screw you've got to know what to ask for. If you call MMC and ask for 4mm philips head screws you just might end up with something that would be correct to use on your tractor rather than the correct sized screw, with the correct thread pitch and the correct head profile. I have sold thousands of these screws in the past years.
The possibility of dissimilar metal corrosion on the painted surface under the screw head is zip to nil, but the nylon washer does help a bunch to protect the paint. On newer/softer paints the base of the screw head will become "bonded" to the painted surface, when the screw is removed at a later date it breaks the paint loose around the screw head, the nylon washer prevents this, this is the main reason the nylon washers are used.
Best from Omak,
Doug
On Fri, Sep 5, 2008 at 1:06 PM, Peter K. Van Staagen <petervs(at)knology.net (petervs(at)knology.net)> wrote:
[quote]--> Yak-List message posted by: "Peter K. Van Staagen" <petervs(at)knology.net (petervs(at)knology.net)>
Pete
