Europa-List: Fw: Fire extinguishers
carl(at)flyers.freeserve.
PostPosted: Thu Sep 04, 2008 11:33 pm    Post subject: Europa-List: Fw: Fire extinguishers Reply with quote
Just a personal opinion but I would have thought that a CO2 extinguisher would be an acceptable substitute. You can pick up a new 2kg model for about £30 on ebay. Weight not ideal but better than nothing I would have thought.
The problem with all extinguishers is that they are designed to cut off the oxygen supply to the fire but would also cut off the occupants oxygen supply. Fact is any extinguisher in the air is going to cause problems.
If there was an engine fire a CO2 extinguisher could be discharged in the engine bay and would be very effective. In the cockpit is another matter.
