carl(at)flyers.freeserve. Guest
Posted: Wed Sep 03, 2008 1:02 pm Post subject: Manifold Pressure Gauge |
I am just filling in the LAA form to change our propeller (from a fixed
pitch to a CS version - Woodcomp/ Smart Avionics controller). The engine is
a Rotax 912 UL 80hp.
The LAA form says that the installation of a manifold pressure gauge is
mandatory. Anyone know why?
Its probably a dumb question but I dont understand the point of monitoring
manifold pressure on a normal engine. I always thought it was more relevant
to turbocharged engines.
Also where does one take the pressure takeoff on the engine - I would guess
the balancing pipe between the carburettors - is there a mod required on the
engine?
Thanks for the explanation in advance.
Carl Pattinson
G-LABS
_______________________________________
No viruses found in this outgoing message
Scanned by iolo AntiVirus 1.5.4.5
http://www.iolo.com
Posted: Wed Sep 03, 2008 2:06 pm Post subject: Manifold Pressure Gauge |
Hi! Carl
Don't know where you take it off on the 912 UL but the 914 has a sensor
already plumbed in .
You need the manifold pressure to know how much power you are applying (
you could be labouring the engine, since the prop is controlling the RPM
the throttle becomes the power applicator. I had this difficulty with
the 3300 Jabiru because they wouldn't give me MP/power/RPM/
ambient/altitude graphs I never knew where the engine was loaded until
many hours experimenting with fuel usage. Of course the Rotax is geared
so the RPM is still more complex.
Usually on a direct drive the rule of thumb is to run "squared" = 24" MP
to 2,400 Engine Rpm, at least in the initial stages of experimentation.
Bob Harrison G-PTAG.
frans(at)paardnatuurlijk. Guest
Carl Pattinson wrote:
Quote: |
<carl(at)flyers.freeserve.co.uk>
is a Rotax 912 UL 80hp.
A CS prop keeps the rotation speed constant (hence the name Constant
Speed prop). The RMP gauge doesn't tell you the engine power anymore, it
shows just the prop setting. If you fly with a certain rpm, and throttle
back, nothing will change on your rpm gauge as the prop will keep the
rpm constant. Hence you won't notice anything as the engine looses power
for whatever reason. However, engine power can be determined by looking
at the manifold pressure. It is close to ambient pressure if the
throttle is wide open, and it will be showing a vacuum at idle, and of
course anything in between.
Frans
terrys(at)cisco.com Guest
Posted: Wed Sep 03, 2008 2:07 pm Post subject: Manifold Pressure Gauge |
Hi Carl,
With a fixed pitch prop, you can get a relative indication of power
level from the engine rpm. So on a Cessna 152, your standard procedure
might be to pull the power back to 1500 rpm abeam the numbers on down
wind. With a constant speed prop, the rpm will be held constant over a
wide range of power settings, so the standard measure of power is
manifold pressure (although we also use fuel flow often). So on our
Europa I would normally pull the power back to 15 inches abeam the
numbers.
Terry Seaver
wooburnaviation(at)google Guest
Posted: Wed Sep 03, 2008 2:38 pm Post subject: Manifold Pressure Gauge |
If you have a constant speed controller, and there is a loss of power in the engine ( for example from carb ice), the RPM will remain constant ( within the limits of the prop/CS system) as the prop will fine off.
The simple way to tell what power the engine is producing, if a power loss occours, is via manifold pressure gauge.
On 03/09/2008, Carl Pattinson <carl(at)flyers.freeserve.co.uk (carl(at)flyers.freeserve.co.uk)> wrote: [quote]--> Europa-List message posted by: "Carl Pattinson" <carl(at)flyers.freeserve.co.uk (carl(at)flyers.freeserve.co.uk)>
I am just filling in the LAA form to change our propeller (from a fixed pitch to a CS version - Woodcomp/ Smart Avionics controller). The engine is a Rotax 912 UL 80hp.
The LAA form says that the installation of a manifold pressure gauge is mandatory. Anyone know why?
Its probably a dumb question but I dont understand the point of monitoring manifold pressure on a normal engine. I always thought it was more relevant to turbocharged engines.
Also where does one take the pressure takeoff on the engine - I would guess the balancing pipe between the carburettors - is there a mod required on the engine?
Carl Pattinson
G-LABS
r.collings(at)onetel.net Guest
Posted: Thu Sep 04, 2008 1:56 am Post subject: Manifold Pressure Gauge |
Carl Hi. Its not a dumb question at all, but one that you will have answered
to when you have completed the PPL licence endorsement cause for complexes
aircraft, i.e., those fitted with a variable pitch prop!You may already this
because of the mono's retractable undercarriage, but a couple of hours spent
under instruction in a complex single would be money well spent.
Regards Richard
raimo.toivio(at)rwm.fi Guest
Posted: Thu Sep 04, 2008 11:50 am Post subject: Manifold Pressure Gauge |
I am looking for a very small MAP gauge - digital or analogical.
Does anybody have a tip?
Ideal would be a CS prop controller WITH integrated gauge
but there obviously does not exist any.
Raimo from Finland
OH-XRT
jeff(at)rmmm.net Guest
Posted: Thu Sep 04, 2008 12:24 pm Post subject: Manifold Pressure Gauge |
Raimo,
I don't know about the gauge but I couldn't help noticing your
beautiful Europa in this months EAA Sport Aviation. Congratulations on
a great looking plane and thanks for some fine recognition of our
plane.
Jeff Roberts,
USA
A258 - N128LJ / Gold Rush 150 hours and climbing slowly.
Raimo from Finland
OH-XRT
kheindl(at)msn.com Guest
Posted: Thu Sep 04, 2008 12:39 pm Post subject: Manifold Pressure Gauge |
Raimo C
The CS1 controller from Smart Avionics C displays the m. pressure C if you have the optional pressure switch . I believe it is 50 punds.
Karl
<html><div></div></html>
[quote] From: raimo.toivio(at)rwm.fi
Subject: Re: Manifold Pressure Gauge
Date: Thu C 4 Sep 2008 23:05:55 +0300
--> Europa-List message posted by: "Raimo Toivio" <raimo.toivio(at)rwm.fi>
Raimo from Finland
OH-XRT
Raimo C I meant POUNDS
Karl
Raimo from Finland
OH-XRT
Posted: Fri Sep 05, 2008 4:22 am Post subject: Manifold Pressure Gauge |
Jeff,
thank you for your beautiful words - your statement made good for my hearth.
I will stop working just now, drive to the airport (EFTP), go airborne and finally
test my adjustable poor manīs wing leveller (Trio ap will be installed next winter).
That is a rubber string with a hook. One end is fitted to the stick and when flying
alone hooked end is in the gear slot (that must take off before landing!).
Raimo from Finland
OH-XRT
