Rowland_Carson
Joined: 04 Jul 2008 Posts: 155 Location: Cheltenham, England
Posted: Wed Sep 03, 2008 1:16 pm Post subject: wiring exit from stick - uk practice? |
I'm looking at the bottom of the control stick as I assemble the
various parts and am wondering what is the best practice (in UK) for
getting the wiring from a switch or switches mounted on the top of
the stick out of the stick at or near the bottom.
I had a troll through the list archives for various keywords but
couldn't find anything relevant, despite having a strong remembrance
of the topic being aired not so long ago.
I want a PTT at last on the P1 stick, but it would be nice to have a
duplicate trim switch there too. (Yes, I'm thinking about shielding
them from accidental activation.)
Obviously the electrical cable(s) should exit in a place that
minimises the chances of (a) fouling up the controls and (b) getting
chafed and causing shorts or open circuits.
It seems perhaps safest to make a hole in the aft side of the stick
(CS16) just above CS01. That way a conventional grommet can easily be
fitted, something that might be harder to do if the hole was lower
down and passing through the thickness of CS16, CS16B, and CS01.
What have other UK builders done that has met with approval from
inspectors and (if involved) LAA Engineering?
regards
Rowland
| Rowland Carson LAA #16532 http://home.clara.net/rowil/aviation/
| 1100 hours building Europa #435 G-ROWI e-mail <rowil(at)clara.net>
Posted: Wed Sep 03, 2008 2:09 pm Post subject: wiring exit from stick - uk practice? |
Hi! Rowland
Find the place of smallest movement but not to weaken the control stick
along with your own appraisals mentioned below.
Bob H G-PTAG
wooburnaviation(at)google Guest
Posted: Wed Sep 03, 2008 2:42 pm Post subject: wiring exit from stick - uk practice? |
I have my only trim switch on the forward face of the stick. I was excellent to use.
On 04/09/2008, Robert C Harrison <ptag.dev(at)tiscali.co.uk (ptag.dev(at)tiscali.co.uk)> wrote: [quote]--> Europa-List message posted by: "Robert C Harrison" <ptag.dev(at)tiscali.co.uk (ptag.dev(at)tiscali.co.uk)>
Hi! Rowland
Bob H G-PTAG
Posted: Thu Sep 04, 2008 12:18 am Post subject: wiring exit from stick - uk practice? |
Rowland, An exit hole at the back of the stick just above CS01 has worked
well for me. The wire is covered by a flexible boot designed to stop the
pens & other things you will drop jamming the controls.
As to trim on the stick, there is the thought that if you fly with
other pilots and share the flying, then the co pilot will want access to the
trim. For me having the switch with the indicator and a CB in some central
position, reasonably close to the throttle hand, makes more sense.
Regards, David, G-XSDJ
willie.harrison(at)tinyon Guest
Posted: Thu Sep 04, 2008 2:48 am Post subject: wiring exit from stick - uk practice? |
Does anyone know a source of pre-made stick boots for the Europa?
Alternatively, does anyone have a they can share?
Cheers
Willie Harrison
G-BZNY Kit 401
Quote: |
<davidjoyce(at)doctors.org.uk>
worked well for me. The wire is covered by a flexible boot designed
to stop the pens & other things you will drop jamming the controls.
Rowland_Carson
Posted: Thu Sep 04, 2008 6:44 am Post subject: wiring exit from stick - uk practice? |
At 2008-09-03 23:17 +0100 peter.rees01(at)tiscali.co.uk wrote:
Quote: | I wouldn't drill the stick to the size for a conventional gromit -
this would seriously weaken the stick
Peter - I hadn't considered that a hole big enough for a grommet
would compromise the strength of the stick - after all it's got to
have 2 off 1/4" holes drilled in it near the bottom for the AN4-17A
bolt that secures it to CS01.
Quote: | the reason that the stick
diameter was increased when it went from steel to ali was that the ali
stick at the smaller diameter was not stong enough at higher G
Now I'm really confused! My CS16 are steel, have 2 bends and are 1"
OD. They came in an XS fuselage kit collected in September 2001. When
did the sticks change to aluminium?
I know the original Classic sticks were straight, but I don't know
what diameter they were or what material they were made of. My paper
manual (page 13-11 issue 1) still shows the straight sticks, but
later PDFs show the cranked ones.
This suggests that there been 3 different types of stick supplied in
Europa kits over the years - straight Classic, small steel cranked,
large aluminium cranked. Is that correct?
Quote: | On HI, we have drilled holes at an angle to the stick (heading
downwards) at the front of the stick (just above the point where the
stick passes in to the tuffnel bush). the hole is bigger than the
screened wire that runs to the PTT (and comm box frequency change) -
I've put some heatshrink over the screened cable where it passes
through the stick (and a zip tie each side to make sure that the cable
stays in place)
That sounds OK. If the grommet is eliminated I think you definitely
need to ensure that the wire is not going to move relative to the
metal and thus chafe. After deburring the hole (as far away from
orthogonal to stick surface as possible so the wire has a minimal
chicane to negotiate) I'm inclined to go for a tie-wrap around the
stick below the exit, and some sort of bung or spacer to immobilise
it inside and above the hole too.
It would be interesting to know if there is any authoritative answer
to how large a hole can safely be made in the stick - and how that
answer changes for the (3?) different models of stick!
I'm copying this reply back to the list as Peter's e-mail client has
been set to reply to the "from" address (me) rather than the
"reply-to" address (the list).
regards
Rowland
Rowland_Carson
At 2008-09-04 09:50 +0100 William Harrison wrote:
Quote: | Does anyone know a source of pre-made stick boots for the Europa?
Willie - Tim Ward, a regular poster on this list, sells nice leather
ones made by a leatherworker in NZ, and supplies them worldwide.
Quote: | Alternatively, does anyone have a they can share?
Not sure how that would work .... Mine are not in service yet, but
I'm planning to keep them fitted once they're on!
regards
Rowland
Rowland_Carson
At 2008-09-03 23:09 +0100 Robert C Harrison wrote:
Quote: | Find the place of smallest movement but not to weaken the control stick
Bob - I think least movement is somewhere between the pitch-axis
pivot bolt and the rod-end-bearing connecting to the pitch pushrod.
It looks as though there is enough room inside CS01 to get the sort
of wire I want to use past the AN5-23 pitch pivot bolt. CS01 is
fairly beefy there, so I'd hope a radial hole would not cause
significant weakness, but it would be nice to have an answer from
someone who knows about the stress calculations for that part.
That exit hole would be insde the leather boot and so I'd want to
make the sort of anti-chafe provision for the wire that I dreamed up
in my reply to David Joyce.
regards
Rowland
Rowland_Carson
At 2008-09-04 09:17 +0100 David Joyce wrote:
Quote: | An exit hole at the back of the stick just above CS01 has worked
David - thanks, I have a set of Tim Ward's boots, but I'm not sure
about keeping the wiring inside them as there is no guarantee that
the wires won't chafe on the moving parts while out of sight in
there. I think I'd prefer to take the wire down the outside of the
boot, although that would be less aesthetic. However I suppose
(thinking aloud here) the ideal solution would be an extra strip of
leather sewn on to the outside (or even better inside) of the boot to
form a channel down the boot between its (mobile) top edge and its
(fixed) bottom edge. That would keep the wire under control and
pretty safe from chafing as well as from snagging on one's high heels.
Quote: | if you fly with other pilots and share the flying, then the co pilot
will want access to the trim. For me having the switch with the
indicator and a CB in some central position, reasonably close to the
I was thinking of a duplicate switch on the stick, leaving the
central one in position, but I don't know if LAA Engineering has
approved such an arrangement. If not, I wouldn't want to be the first
to lock horns with them over FMEA!
It's just that most of the aircraft I've flown with electric trim
have a rocker switch on the yoke and I've found that so much more
ergonomic and fast to use than reaching across to a separate switch
or a mechanical trim wheel.
However, I may have to settle for a single central switch just to
keep life simple.
Incidentally, I'm not planning to use a commercial stick grip as they
are mostly fitted with much more complex switchery than what I want.
I do believe that the grips I want are hiding inside some chucks of
mahogany that I have lying around - I just have to let them out, as
the sculptors say. But before I do that, I will need to decide how
many switches they must accomodate and where the switch(es) should go
regards
Rowland
Posted: Thu Sep 04, 2008 7:10 am Post subject: wiring exit from stick - uk practice? |
Hi! Willie
I recall that a guy in New Zealand made quite a lot in leather but I
have no details of them. I made a fiberglass box to encompass the whole
mechanism at the bottom of both control sticks and they have a simple
leather boot to the sticks and a draw string to tighten them on. Go to
http://www.crix.org.uk and click on "Bob Harrison's Europa G-PTAG" then
select Control Sticks.
Bob Harrison G-PTAG
peter.rees01(at)tiscali.c Guest
Posted: Thu Sep 04, 2008 8:16 am Post subject: wiring exit from stick - uk practice? |
Hi Roland
You are correct in that there have been (at least) 3 designs of stick
- As you say, the early ones were straight - The position of these was
so far forwards that the PTT very nearly touches the map tray.
When we bought HI, it had a stick with a single crank in and made from
Ali - this was the larger diameter (ie it fitted into the CS-01 without
a bush). The position was pretty good but still not great.
The later ones, supplied in the XS kits are double cranked, smaller
diameter (requiring a bush to allow it to fit to the CS-01) - this
places the stick much better for those of us of a shorter stature.
Peter
----Original Message----
Date: 04/09/2008 15:04
Subj: Re: wiring exit from stick - uk practice?
net>
ali
Quote: | stick at the smaller diameter was not stong enough at higher G
cable
regards
Rowland
How safe is your email? - http://www.tiscali.co.uk/products/securemail
__________________________________________________________
Posted: Thu Sep 04, 2008 8:46 am Post subject: wiring exit from stick - uk practice? |
Hi! Rowland
Just for the record I have the whole works in the stick top by Mac,
that is trim flaps and PTT. Andy Draper on Test(Before he went to the
PFA) was concerned about the use of charts activating the buttons since
they are very sensitive. I had a picture of a flip top cover I made to
get over this problem on the http://www.crix.org.uk site but it seems to
have gone missing, John Cliff may have been shrinking the site a little
and decided to remove it . I also have all the switches duplicated on
the panel but the relays necessary are a bit mind blowing! I hope there
is never an issue needing them sorted whilst I have the 'plane !
regards
Bob Harrison G-PTAG
Posted: Thu Sep 04, 2008 10:21 am Post subject: wiring exit from stick - uk practice? |
Quote: |
Hi! Rowland
have gone missing,
I know of one case where the Mac switch probably got nudged and caused
the aircraft to be grossly out of trim (nose up) the aircraft spun in
from about 100 feet
Graham
raimo.toivio(at)rwm.fi Guest
Posted: Thu Sep 04, 2008 11:17 am Post subject: wiring exit from stick - uk practice? |
I have two trim swithes: one is in the stick (full speed)
and other one is on the panel (adjustable speed).
I use stick switch when landing (low air speed - faster trim speed)
and panel switch during cruise (fast air speed - slower trim speed).
I have a changeover switch to select which mode to use.
If one switch would go broken, I have still other one left over to trim.
Trim CB is near panel switch just in case to stop possible autotrim.
Raimo
OH-XT
karelvranken(at)hotmail.c Guest
Posted: Thu Sep 04, 2008 11:23 am Post subject: wiring exit from stick - uk practice? |
Rowland C
I have both trim controls C one on the stick and one on the panel with the matronics control system. This works first used first served.
Best regards C
Karel vranken.
> From: davidjoyce(at)doctors.org.uk
[quote] To: europa-list(at)matronics.com
Subject: Re: wiring exit from stick - uk practice?
Date: Thu C 4 Sep 2008 09:17:10 +0100
--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk>
Rowland C An exit hole at the back of the stick just above CS01 has worked
As to trim on the stick C there is the thought that if you fly with
other pilots and share the flying C then the co pilot will want access to the
position C reasonably close to the throttle hand C makes more sense.
Regards C David C G-XSDJ
Posted: Thu Sep 04, 2008 11:41 am Post subject: wiring exit from stick - uk practice? |
Tim Ward from NZ makes great boots.
I am very proud of mine. All the colours available.
Raimo from Finland
OH-XRT
jimpuglise(at)comcast.net Guest
Posted: Thu Sep 04, 2008 12:28 pm Post subject: wiring exit from stick - uk practice? |
Raimo-
The article on your airplane is in this month's Sport Aviation. It is well done and I really enjoyed reading it.
Jim Puglise, Punta Gorda, FL
[quote] --> Europa-List message posted by: "Raimo Toivio"
Raimo
OH-XT
Rowland_Carson
Posted: Fri Sep 05, 2008 2:50 am Post subject: wiring exit from stick - uk practice? |
At 2008-09-04 23:36 +0100 Duncan & Ami McFadyean wrote:
Quote: | The 1/4" holes in the bottom of the stick have no effect on the
strength of the stick, as it is at the position of the holes
socketed in to the lower fitting (CS01), which is of much greater
diameter and with much greater wall thickness.
The steel stick is stronger than the alloy stick. In particular, the
cranked and welded alloy sticks have virtually no strength, because
welding removes most of the strength of the 2024 heat-treated alloy
from which the stick is made.
The greatest forces on the stick will be in the for-aft direction
e.g either in the situation of a jammed elevator control and
feet-on-panel to get a decent 'pull', or as a matter of design
requirement (i.e CS-VLA). That means that any hole in the stick
should be drilled on the neutral axis in this situation (i.e. on the
side of the stick) and as far above the point at which the stick
enters CS01 as is possible.
As regards the size of hole, you could calculate that from the
proportion of material removed from the, say, a quarter of the
circumference of the tube. So if you remove half of the
quarter-of-circumference, then the hole would need to be half way up
the stick, for no significant effect on strength of the stick. Or
calculate from CS-VLA what strength you actually need and how much
material you can remove!
Anyway, why must you insist on a full grommet, when careful
attention to radiusing of the hole and some extra heatshrink on the
wires at that point should suffice.
Duncan - thanks for that very full explanation.
My original intention to fit a grommet was simply good electronic
engineering practice. As I said in a reply to Peter Rees, if the hole
edges can be radiused and smoothed, then securing of the wire against
movement both inside and outside would be as good and perhaps even
more satisfactory than a grommet - I just hadn't thought of doing
that!
One thing that might be difficult is ensuring that the inside edge of
the hole is free of sharp edges, particularly if it has to be distant
from the ends of the stick.
As to the position of the hole, it's beginning to sound as though
it's hardly worth considering drilling the CS16, and that a hole
through the CS01 would be safer. From your opening para, I assume
there would be less concern about adding weakness by drilling CS01 -
is that correct?
I'm copying this reply back to the list as Duncan's reply came only
to me (instead of to the list), and I think the points he raises are
worth publicising.
regards
Rowland
Posted: Fri Sep 05, 2008 4:01 am Post subject: wiring exit from stick - uk practice? |
Sorry, that was meant to read "..a design/template they could share.."
leather ones made by a leatherworker in NZ, and supplies them
worldwide.
regards
Rowland
Posted: Fri Sep 05, 2008 4:36 am Post subject: wiring exit from stick - uk practice? |
Jim,
Thanks. My purpose was to produce a little bit "different" text which should be readable also for possible non-builders and even for non-pilots. Those people tend to think we - builders and pilots - are not normal human people at all. Probably they are right. At least my wife said so regularly and again this morning (he noticed I could not sleep at all because I was planning some exciting modifications for XRT).
Raimo from Finland
OH-XRT
