fire extinguisher
danny shepherd
PostPosted: Thu Sep 04, 2008 7:59 am    Post subject: fire extinguisher Reply with quote
Hi All,
Can anyone tell me what kind of fire extinguisher they have in
there plane, and where about did they fit it. I have been looking at the
usual suppliers, and I'm a bit confused as to which one I should fit.
Cheers Danny G-ceri (getting close to the first flight)
ptag.dev(at)tiscali.co.uk
PostPosted: Thu Sep 04, 2008 8:49 am    Post subject: fire extinguisher Reply with quote
Hi! Danny
I have a CFC ?(Believe it was that can't say positively since the
aircraft is locked away in the trailor , it's not water and not powder
anyway!) behind the passenger seat head rest and part of the passenger
drill is to point out where it is .......it gives them lots of
confidence !
Bob Harrison G-PTAG
kheindl(at)msn.com
PostPosted: Thu Sep 04, 2008 9:19 am    Post subject: fire extinguisher Reply with quote
Danny C
I have a halon gas extiguisher. as far as i know it is only available from acs. position is same as described by bob.
Karl
<html><div></div></html>
Date: Thu C 4 Sep 2008 16:58:03 +0100
Subject: fire extinguisher
--> Europa-List message posted by: danny shepherd <danny(at)mcwalterscafe.co.uk>
Hi All C
there plane C and where about did they fit it. I have been looking at the
usual suppliers C and I'm a bit confused as to which one I should fit.
loboloda(at)execulink.com
PostPosted: Thu Sep 04, 2008 11:15 am    Post subject: fire extinguisher Reply with quote
Hi Danny,
Same as Karl, I have a Halon extinguisher, had to bring it in from Oshkosh as
they don't seem to be allowed to be sold in Canada.
Mounted on the centre consul, low down, just ahead of the seat and angled forward.
I can reach it from there, and it is not in the way of feet or legs.
Dave
On 4-Sep-08, at 1:18 PM, Karl Heindl wrote:
[quote] Danny,
Karl
Date: Thu, 4 Sep 2008 16:58:03 +0100
From: danny(at)mcwalterscafe.co.uk (danny(at)mcwalterscafe.co.uk)
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
--> Europa-List message posted by: danny shepherd <danny(at)mcwalterscafe.co.uk (danny(at)mcwalterscafe.co.uk)>
Hi All,
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
raimo.toivio(at)rwm.fi
PostPosted: Thu Sep 04, 2008 11:31 am    Post subject: fire extinguisher Reply with quote
Danny,
when airborne, Halon is your one and ONLY possibility in the case of fire.
Normal "on the ground use" is illegal but aviation use is still legal.
CO2 and powder types will kill you ( + powder spoils your panel etc!!!).
Water-fox-type -extinguishers are also not very practical.
There was a great article of that question this year in the magazine
Sport Pilot or Sport Aviation (USA EAA). Maybe some
American could find that article and let us know the main facts.
If not I wíll do it.
I fitted my (little) bottle between centre console and P2 backseat.
Always visible and easy to find and use.
Raimo from Finland
OH-XRT
wooburnaviation(at)google
PostPosted: Thu Sep 04, 2008 12:28 pm    Post subject: fire extinguisher Reply with quote
On my last fire course I was told that Haylon is still available for aviation use only, so maybe they are available through specialist suppliers? We still use Haylon on the Embraer 145 for engine and APU extinguishers.
On 04/09/2008, Carl Pattinson <carl(at)flyers.freeserve.co.uk (carl(at)flyers.freeserve.co.uk)> wrote: [quote]--> Europa-List message posted by: "Carl Pattinson" <carl(at)flyers.freeserve.co.uk (carl(at)flyers.freeserve.co.uk)>
I may be wrong Danni but I think Halon extinguishers are now no longer available in the UK anyway (aka BCF bromo chloro fluorethane) because they are considered harmful to the environment.
Legislation prohibits the sale of halon products from December 31st 2002. - NO IM NOT WRONG !!! http://www.mfs-fire-extinguishers.co.uk/halon.htm
The only other alternative suitable for aircraft use are dry powder. Water is unsuitable for aircraft use and too heavy and foam although acceptable is also too heavy. CO2 is probably the best substitute but again too heavy for aircraft use.
Halon if you can get it is undoubtedly the best as it is effective against a wide range of fires and wont damage the aircraft structure, engine or wiring if used. I have seen all of the above used in real life and used properly the Halon variety is by far the best - note Halon is extremely toxic in confined spaces (you wouldnt want to use it in an enclosed cockpit).
We have a Halon extinguisher 3kg but its getting on a bit (it had a twin but I accidentally set it off in the garage by mistake last week - but at least it proved the thing worked).
Good luck in your search.
Carl Pattinson
G-LABS
ami(at)mcfadyean.freeserv
PostPosted: Thu Sep 04, 2008 12:35 pm    Post subject: fire extinguisher Reply with quote
Ditto mine: Halon and behind-the-passenger-'headrest' mounting position,
which is out of the way, within easy reach and doesn't become a projectile
in a frontal crash.
BTW, it takes a 10Kg pull to release the 1Kg bottle. So any deceleration of
-10g in the direction of release will see the extinguisher becoming a free
agent.
Duncan McF.
Brian Davies
PostPosted: Thu Sep 04, 2008 1:37 pm    Post subject: fire extinguisher Reply with quote
BCF fire extinguishers are still available in the UK from LAS (Light Aero) in 1Kg and 0.5Kg sizes.
Brian Davies
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of David Buckley
Sent: 04 September 2008 21:28
Subject: Re: Re: Europa-List: fire extinguisher
Carl Pattinson
G-LABS
----- Original Message ----- From: "danny shepherd" <danny(at)mcwalterscafe.co.uk (danny(at)mcwalterscafe.co.uk)>
To: "matronics" <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Sent: Thursday, September 04, 2008 4:58 PM
Hi All,
Can anyone tell me what kind of fire extinguisher they have in there plane, and where about did they fit it. I have been looking at the usual suppliers, and I'm a bit confused as to which one I should fit.
_______________________________________
No viruses found in this incoming message
Scanned by iolo AntiVirus 1.5.4.5
http://www.iolo.com
No viruses found in this outgoing message
http://www.iolo.com
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Checked 270.6.15/1649 - Release Date: 03/09/2008 16:13
PostPosted: Thu Sep 04, 2008 2:37 pm    Post subject: fire extinguisher Reply with quote
in a frontal crash.
agent.
Duncan McF.
mikenjulie.parkin(at)btin
PostPosted: Thu Sep 04, 2008 9:22 pm    Post subject: fire extinguisher Reply with quote
Danny,
The only one to use is Halon. Still available for aircraft use. Mine is
mounted behind the passenger headrest. Go to
http://www.lasaero.com/article/a-bcf-fire.
regards,
Mike
PostPosted: Thu Sep 04, 2008 9:37 pm    Post subject: fire extinguisher Reply with quote
Ivor Phillips
PostPosted: Fri Sep 05, 2008 1:20 am    Post subject: fire extinguisher Reply with quote
They are available from http://www.lasaero.com/article/a-bcf-fire
Ivor
Subject: Re: Re: fire extinguisher
<mikenjulie.parkin(at)btinternet.com>
