AW: wiring exit from stick - uk practice?
uvtreith(at)t-online.de
PostPosted: Thu Sep 04, 2008 5:21 am    Post subject: AW: wiring exit from stick - uk practice? Reply with quote
Hi Willie,
Europa Aircraft UK can supply these. Leather gaiters in grey and beige.
45 GBP per set.
They have these self locking tapes on for fixing it to the floor and seat.
But you can use them only, when you can get them over the stick. When you
have a big grip on they will not fit or you have to open the sewing of the
top part a little.
Best Regards,
Bruno
-----Ursprüngliche Nachricht-----
Von: owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von William
Harrison
Gesendet: Donnerstag, 4. September 2008 10:51
An: europa-list(at)matronics.com
Betreff: Re: wiring exit from stick - uk practice?
<willie.harrison(at)tinyonline.co.uk>
Does anyone know a source of pre-made stick boots for the Europa?
Alternatively, does anyone have a they can share?
Cheers
Willie Harrison
G-BZNY Kit 401
<davidjoyce(at)doctors.org.uk>
Rowland, An exit hole at the back of the stick just above CS01 has
worked well for me. The wire is covered by a flexible boot designed
to stop the pens & other things you will drop jamming the controls.
