Posted: Fri Aug 29, 2008 9:35 am Post subject: Jos Okhuisen |
Just back from Wels in Austria where Bruce Morris, Mark Burton and I spent a
fair bit of time with Jos following his recent accident. He is in reasonable
spirits and making good progress medically. He looks like a boxer who picked
the wrong opponent, but is marvellously cheerful and positive to talk to,
and there seems real hope that his eye will recover. His burnt areas that
have been grafted with artificial skin are healing well.
We saw the wreckage of the plane and it appeared that the
propeller was in zero pitch or possibly negative. This fits with Jos's
description of events, that he climbed normally to 800ft, changed to cruise
mode, realised he had that set at too low rpm and decreased pitch to bring
rpm up to 5000 but then the engine speed rose above 6000 and he lost thrust,
and all attempts to change pitch then made no difference. The land ahead
area was heavily built up and he did a great job to get down more or less in
one piece. He initially aimed for a road but saw a power cable at the last
moment and swerved to land in a tree. The plane then fell out of the tree
and in short time caught fire, but he had not lost consciousness (he says it
is because Laplanders have thick heads!), and was able to get out pretty
quickly, suffering burns to just his lower legs, and trauma around his right
eye (?due to a branch)
His address for those who want to send best wishes is:
Klinicum Wels, Traumatology, 1st Floor
Grieskirchener Strasse 42
4600 Wels, Austria
Regards, David Joyce, G-XSDJ
cjh.richardson(at)virgin. Guest
Posted: Sun Aug 31, 2008 5:38 am Post subject: Jos Okhuisen |
David,
Do you know what type of propellor Jos had fitted to his aircraft? It might
help those with the same propellor to be prepared for a similar situation.
John.
josok-e(at)ukolo.fi Guest
Posted: Sun Aug 31, 2008 9:20 am Post subject: Jos Okhuisen |
Hi John, Just a short reply. Tomorrow the internet here should be repaired then more. It was a Woodcomp RS 3000 with reverse. Regards Jos Okhuijsen
Visit - www.EuropaOwners.org
frans(at)paardnatuurlijk. Guest
Posted: Wed Sep 03, 2008 12:53 am Post subject: Jos Okhuisen |
Did I miss something, or is there indeed a silence about this subject?
I'm about to install a Woodcomp propellor, but I'm holding this off
until I have some more insight about the reliability of this system.
Also, nobody mentioned it yet, but I'm very interested in the cause of
the post landing fire. It is a horrible prospect that this can happen,
and I want to take all precautions to minimise this risk.
One thing I wonder is how the drain valves affect this risk. They
protude from under the skin, and once you glide through a tree or over a
rough surface, they will probably break off, and the fuel is free to
leak away, possibly inside the cabin if the assembly comes loose, or
otherwise under the airplane, which is not desirable as well.
Also, not having a switch on the main fuel pump (914) and route it not
via the main switch, as the manual recommends, introduces the risk that
the fuel pump pumps the entire tank contents inside the cabin after a
crash. Of course, having a switch on it introduces another risk: an
inadvertently switch off... How do others think about this subject?
BTW, it is no longer possible for me to answer on the Europa list via
the online forum. The mandatory spell-check malfunctions (it mutters
something about a debug mode?). Is there a way to bypass this spell
check or can someone switch it off?
Frans
Posted: Wed Sep 03, 2008 4:39 am Post subject: Jos Okhuisen |
Hi Frans and all,
The silence is the normal waiting for the investigation to come to a conclusion. Today i had a long hearing about the course of events. While i have my theory about what happened, i will wait until the final findings are published before commenting. Nethertheless, lets put it this way, my choice will never again be for a propellor without mechanical endstops, in addition to the electrical limit switches. As a minimum i would add run to the outer limits and check outside if the switches are really working and at the right limits. As i found out the hard way, in the air it might be too late.
As for the fire risk: Difficult to do better then i did. Possibly, if i would have had one second more time before hitting the trees, i would have followed the emergengy drill better and switched off power before the crash. That maybe would have delayed the fire. Now a thick branch wiped the right side of the cockpit off, breaking the fuel return alu tube. The long range tank (full)survived the blaze i was told. Even with the wheel retracted, the fuel test points stay clear. Hmm, best way to prevent fire is not to crash, but i guess you know that.
Jos
wdaniell(at)etb.net.co Guest
Posted: Wed Sep 03, 2008 5:01 am Post subject: Jos Okhuisen |
Jos
I am glad to see you on line again.
It is always easy to be wise after the event but each event by its very
nature is something new. We have all learned an important lesson from your
mishap.
Two things strike me:
1. you were remarkably lucky to escape without worse from landing in a tree
2. the fact that it was not worse suggests that the Europa is as safe as it
gets.
Will
Posted: Wed Sep 03, 2008 6:43 am Post subject: Jos Okhuisen |
Hi Will and all,
Before i forget again the most important thing i would like to say: Thank you all for all the snail- email- sms's and phone calls. I knew this is a great community, still all those people living these events with me is more then i did expect. You probably will never know how very important your communications were for me at the worst moments.
Yes, in my humble, crah tested opinion, the Europa is a safe plane, not only to fly but also to crash. Still, on more then one account, the accident was not survivable. I was extremely lucky, and the fact that being born Dutch makes me a cheese-head might have helped to maintain consiousness and get out before the fire really started bazing.
Jos Okhuijsrn
Posted: Wed Sep 03, 2008 7:46 am Post subject: Jos Okhuisen |
Hi Jos and all,
Quote: | Hi Frans and all, The silence is the normal waiting for the
Ok, I understand that. It is just that a few days ago you wrote that you
were going to post more detailed information the next day, but I never
saw it, so I wondered what happened. Glad that you are still ok.
Quote: | Now a thick branch wiped the right side of the cockpit off, breaking
Ok, two toughts about that:
1) The fuel return line is obviously a risk, as it can not be closed
with the fuel valve, and once broken it allows the tank to drain
completely. I just realised that this risk can be minimised by putting a
check-valve (one way valve) in the return line. So fuel can go TO the
tank, but never FROM the tank. Has anyone ever considered this? I think
I'm going to put this into my fuel system, unless someone can tell me
why it is not a good idea to do so.
2) I have seen that many builders do away with the rubber hoses and use
aluminium. Maybe the risk is higher with aluminium, since these tubes
breaks easily, whereas rubber hoses just give way to impacts.
Frans
Posted: Wed Sep 03, 2008 10:28 am Post subject: Jos Okhuisen |
Hi! Frans/all
As a novice I agree with your suggestion on the "check valve" in the
return line and your impact theory for rubber pipes but the latter item
would be marginal either way IMHO. The main thing is to apply the
maximum delay of fuel spreading to the likely fire source at the front
or under you and an element of chance would apply to either type of
pipe. This is what has prompted me/many to replace the glass filters
under the seat for Andair in the fuselage away from the pilot and /or
have a different sight gauge to one encircling the pilot.
All such things have to be weight considered otherwise an automatic
extinguisher system with heavy tankage to supply but I'm sure you don't
need me to remark on that.
Bob Harrison G-PTAG
Posted: Wed Sep 03, 2008 3:04 pm Post subject: Jos Okhuisen |
Frans & all
I agree a check valve might be good. I also think in a serious crash
either rubber or aluminum will fail.
The most likely cause of fire is electrical, as Jos tells us, first
action is to shut off the electrics.
In my crash I think the tank split. Battery was at the front and shot
off forwards straight away so "automatic switch off" probably occurred
as it were.
The problem is, when the workload gets too high one forgets the plan, ie
"we lose the plot!" I always tell mono drivers to pull stick full back
as soon as they feel the tailwheel touch. I never did remember to do it
myself, my brain was busy doing something else. Age? maybe but the more
you train yourself in these vital actions the more likely you will do it
when muck hits fan
Graham
Robert C Harrison wrote:
Quote: |
Hi! Frans/all
return line
Bob Harrison G-PTAG
ami(at)mcfadyean.freeserv Guest
Posted: Thu Sep 04, 2008 2:34 pm Post subject: Jos Okhuisen |
A number of subjects there.
Firstly the non-return valve. Actually, the PFA questioned why I had NOT got
one fitted in the case of the fuel injection system that I had fitted
previously (which circulated fuel back to the tank at a similar rate to the
914 system).
As a poor-man's alternative, I now have the 912 return-line restrictor
located just behind the firewall (because there is a joint in the return
line there and because it creates more unrestricted vapour headspace in the
top of the return line); so, if the return line is severed at a point
forward of the firewall, the restrictor provides at least some restriction
to backflow from the tank; LAA know about this and approved the
installation.
About fire suppression systems: a suggestion to the PFA some years ago to
include a port in the instrument panel and connected to a pipe leading to
the undercowl space (with suitable check valve) in to which a handheld fire
extinguisher could be discharged, met with a positive response. Albeit for
some reason unknown to me, such fire systems have been outlawed on rally
cars.
Regarding the RV that flipped on to its back at Fishburn recently, the pilot
commented that he would have preferred to have had a small 2lb axe to have
been able to get out. It was the rescuers that enabled exit through the
broken canopy. He considered that the small "lifesaver" hammers were a
complete waste of time.
Duncan McF.
nwcmc(at)tiscali.co.uk Guest
Posted: Sun Sep 07, 2008 10:38 pm Post subject: Jos Okhuisen |
Quote: | As a poor-man's alternative, I now have the 912 return-line
restrictor
Quote: | located just behind the firewall (because there is a joint in the
return
Quote: | line there and because it creates more unrestricted vapour headspace
in the
Quote: | top of the return line); so, if the return line is severed at a
point
Quote: | forward of the firewall, the restrictor provides at least some
restriction
Quote: | to backflow from the tank; LAA know about this and approved the
installation.
As the flow back to the tank is slow one idea might be to place a
second inline restrictor by the tank (slightly larger orifice if
considered necessary). Any fracture in the line between the firewall
and the tank would result in a very limited flow rate of fuel.
Nigel Charles
How safe is your email? - http://www.tiscali.co.uk/products/securemail
__________________________________________________________
Posted: Mon Sep 08, 2008 1:32 am Post subject: Jos Okhuisen |
Hi Nigel,
This installation was a 914, and there is NO restrictor in the return line. One pump was producing 120 l/hr Through that return pipe. It was part of the pre-flight check to check for that number to makes sure pumps and gascolator were healthy.
Jos Okhuijsen
