refueling trouble on the plane
yck.laurens(at)wanadoo.fr
PostPosted: Tue Sep 02, 2008 4:39 am    Post subject: refueling trouble on the plane Reply with quote
After a one hour and a half flight, I tried to refuel the plane, but I wasn't able to add more than 8 liters. One hour later, I was able to refuel 16 liters more.
I don't understand the problem, tank air vent looks OK, has anyone experienced this pb ? how is it possible ?
It's quite worrying as the sight gauge is not reliable...
thank's if you have informations
yannick LAURENS
europa classic
F PSCZ
no 192
based in france
LA BAULE
rampil
PostPosted: Tue Sep 02, 2008 5:47 am    Post subject: Re: refueling trouble on the plane Reply with quote
You don't say how your vents are connected, but if gasoline
enters the sight tube vent at its connection to the filler, and there
there is alocal low spot in the vent tubing, you will get an air lock
at the top of the sight gauge which will make the meniscus in the
sight tube read too low.
Ira N224XS
