Removing a wheel to fix a tire?
Goto page Previous  1, 2
peteohms
PostPosted: Sun Aug 31, 2008 6:28 am    Post subject: Removing a wheel to fix a tire? Reply with quote
Can an ATV dealer break the bead? What would I need to do myself if I don't
have the tools?
Pete
Pete
Leander, TX
Kitfox III, 912ul, Grove
akflyer
PostPosted: Sun Aug 31, 2008 6:35 am    Post subject: Re: Removing a wheel to fix a tire? Reply with quote
any ATV shop can take it off, fix it and have it back on in a few minutes for a few bucks. I change mine by pulling the valve stem. then putting the edge of the tire under the car tire and pulling forward. It will pop it right off, just don't stick it under too far or you can bend the rim.
Harbor freight has what you need for a few bucks too
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=34552
you will need the ATV adapter for 3.99
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=36448
Then you have the 5.00 redneck version that you probably dont need to leave home to ge the materials for....
http://www.ibmwr.org/otech/beadbreaker.html
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Sbennett3(at)aol.com
PostPosted: Sun Aug 31, 2008 6:41 am    Post subject: Removing a wheel to fix a tire? Reply with quote
Take it to Walmart, They'll break it free for ya. They don't sell tubes anymore. Oh ya, tell them its for a golf cart. Steve Bennett Wal mart store number... No just kidding..
In a message dated 8/31/2008 10:29:24 A.M. Eastern Daylight Time, apeterchristensen(at)sbcglobal.net writes:
[quote]--> Kitfox-List message posted by: "Pete Christensen" <apeterchristensen(at)sbcglobal.net>
have the tools?
Pete
shinco(at)bright.net
PostPosted: Sun Aug 31, 2008 6:45 am    Post subject: Removing a wheel to fix a tire? Reply with quote
don't have the tools?
Pete
dave
PostPosted: Sun Aug 31, 2008 9:33 am    Post subject: Re: Removing a wheel to fix a tire? Reply with quote
Pete
Yup they have the tools.
The Redneck version in my opinion would not work.
You need to get in an pry the bead past the bead lock........ it not that easy without the right tools.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
tleiss(at)earthlink.net
PostPosted: Sun Aug 31, 2008 10:02 am    Post subject: Removing a wheel to fix a tire? Reply with quote
I took mine to a local Golf course.
Todd
[Original Message]
Date: 8/31/2008 1:38:16 PM
Subject: Re: Removing a wheel to fix a tire?
> Pete
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
http://www.youtube.com/profile_videos?user=kitfoxflyer
http://forums.matronics.com/viewtopic.php?p 1823#201823
lcfitt(at)sbcglobal.net
PostPosted: Sun Aug 31, 2008 6:03 pm    Post subject: Removing a wheel to fix a tire? Reply with quote
Pete, I have broken the bead several times by putting the wheel and tire on
the ground over a patch of old carpet and driving the front tire of my truck
onto it. It helps to have a guide man - my wife, in my case. It takes a
while and be careful you don't cut your truck tire or bend the ATV rim. I
never did, but was careful. I did once try one of the small tire changing
units from Harbor Freight and damaged the rim where the grease cup
attatches. I fixed it with a lathe.
Lowell
peteohms
PostPosted: Mon Sep 01, 2008 7:05 am    Post subject: Removing a wheel to fix a tire? Reply with quote
On my VW dunebuggy I used to put a 2X6 about 3' long on the tire as a ramp
and drive my car up to break the bead. Would this work?
Pete
Pete
Leander, TX
Tom Jones
PostPosted: Mon Sep 01, 2008 5:32 pm    Post subject: Re: Removing a wheel to fix a tire? Reply with quote
Pete
Pete, it might. I have dismounted car tires using the "drive on", method, the bumper jack method and the sledge hammer method. The kitfox wheel and tire foiled me however. I finally surrendered and took it to the tire store (Les Schwabs) told the guy it was an atv wheel and he dismounted the old tire, mounted the new one and did't charge me anything.
Those Douglas wheels are getting hard to come by. I see new ones are available but I think they have diamonds woven into them by the price I have seen quoted. Be careful.
Tom Jones
Classic IV
Ellensburg, WA
Float Flyr
PostPosted: Mon Sep 01, 2008 5:51 pm    Post subject: Removing a wheel to fix a tire? Reply with quote
I've used everything from an old truck to my Imprezza to break down tires.
My early model Quad's tires won't fit most of the tire changers in this area
including the one at the outdoor shop. Just make sure to remove the valve
stem first and break the back of the tire first. You may have to break the
bead in steps. I knew a guy who used to mount tubeless tires with an ounce
or so of gas.... he threw it into the tire waited a minute for it to
vaporize and tossed a match in the general direction.... bang! The tire was
mounted. I don't have the kahunas to try that myself!
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
dave
PostPosted: Tue Sep 02, 2008 2:41 am    Post subject: Re: Removing a wheel to fix a tire? Reply with quote
Pete
Pete, I really doubt that would work. You have to get between the lip of the rim and the bead of the tire and you have to go in about 1/2 inch or so. Your way the tire will likely fold over and the bead will not slide over the bead lock ridge on the rim. A simple tool like the tool that I made works well. If you are unsure just take to a ATV shop or make your own.
Dave
Page 2 of 2
