Europa-List: Mono swing arm
carl(at)flyers.freeserve.
PostPosted: Mon Sep 01, 2008 11:30 am    Post subject: Europa-List: Mono swing arm Reply with quote
When the Europa is sitting on the ground the rubber block is compressed such
that there is about 1/2 to 1 cm of bolt showing (from the bottom of the
shock plate to the bolt head). That is normal for all Europas. Do not
attempt to take up this slack by tightening the bolts - if you do the
undercarriage will not retract fully.
