h&jeuropa
Posted: Mon Sep 01, 2008 7:15 am Post subject: Mono swing arm |
We’ve got our Europa back together and flown a little. Had a hard arrival yesterday and noticed today that the M8-100 bolts have threads showing above and below the shock plates. Looks like the LG06 shock absorber is collapsed.
So how does one disassemble the swing arm mechanism. It appears like the bungee will have to be taken lose first. How do you get to that with the engine and firewall in place?
Jim & Heather Butcher
N241BW
raimo.toivio(at)rwm-syste Guest
Posted: Mon Sep 01, 2008 10:42 am Post subject: Mono swing arm |
Jim,
I think your plane is OK (IMHO)!
Once I noticed during normal inspection same situation with my mono and was
very worried.
Investigated little and decided afterwards everything was ok.
During building phase you tightened those bolts M8-100 so,
that the distance between shock plates was 79 mm.
That is maximum - with load it is less.
If you now lift your plane upp (= no load on the gear), you notice the
distance will be again 79 mm.
And no thread showing above and/or below shock plates.
If so, your polyurethane block LG is not collapsed.
Look Europa manual chapter 29M.
I really wish I am right...and you are happy.
Regards, Raimo
OH-XRT
h&jeuropa
raimo.toivio(at)rwm.fi Guest
Posted: Tue Sep 02, 2008 1:37 am Post subject: Mono swing arm |
Heather & Jim
Congratulations!
Mono gear is very strong and cabable (do not ask how I know).
Removing and reassembling it would be a nightmare (for me at least).
Raimo
