Brantel
Posted: Thu Aug 28, 2008 4:05 am Post subject: Kitplanes article on an Elegant LED driver |
I took a look at the new kitplanes article on how to build an elegant LED driver for aircraft.
Up until now I have been planning to use an off the shelf cheap constant current power supply from LEDDYNAMICs. But people are reporting everywhere that these things are trashing the aircraft radios with RF noise.
That being said, what if any advantages would the kitplanes article driver have over one of these off the shelf drivers and would the noise problem still exist with that driver as well?
From looking at the circuit, it looks similar to what one might think the LEDDynamics one would look like inside.
echristley(at)nc.rr.com Guest
Posted: Thu Aug 28, 2008 5:03 am Post subject: Kitplanes article on an Elegant LED driver |
Brantel wrote:
| Quote: | That being said, what if any advantages would the kitplanes article driver have over one of these off the shelf drivers and would the noise problem still exist with that driver as well?
Education.
david.nelson(at)pobox.com Guest
Posted: Fri Aug 29, 2008 5:37 am Post subject: Kitplanes article on an Elegant LED driver |
Hi Bob,
I'm curious, why is such a high freq (1-2MHz) needed for an application
such as this? Rather, why not in high 100's of Hz given that the eye
can't even discern above 30 Hz?
Thank you,
/\/elson
~~ Lately my memory seems to be like a steel trap .... without any spring. ~~
On Thu, 28 Aug 2008, Robert L. Nuckolls, III wrote:
| Quote: | <snip>
http://www.national.com/ds/LM/LM3404.pdf
This is one of a host of similar one to multi-channel dimmer
controllers. The 3404 delivers up to of constant current
to it's companion loads.
It's a switcher. It hums at 1 to 2 Mhz with a butt-ugly
wave-form rich in harmonics. This device needs to be
a very compact layout (small antenna aperture) and be fitted
with conduction filters on the input/output wires. It
MIGHT be okay in a plastic enclosure . . . but a metal
one never hurts.
<snip>
Posted: Fri Aug 29, 2008 6:11 am Post subject: Kitplanes article on an Elegant LED driver |
David E. Nelson wrote:
<david.nelson(at)pobox.com>
Hi Bob,
application such as this? Rather, why not in high 100's of Hz given
that the eye can't even discern above 30 Hz?
100's of Hz will put you in the audio range and possibly give a humm in
the audio portions of the airplane. Somewhere just above 30KHz would
seem like the best frequency range.
Posted: Fri Aug 29, 2008 7:38 am Post subject: Kitplanes article on an Elegant LED driver |
Hi Ernest,
Ok, 30KHz makes sense. Although 30Hz may not be within the dynamic range
of the audio equipment, I could definately see a square wave's odd
harmonics (90 Hz and 150 Hz, etc IIRC) reaching up into a sensitive audio
area. Interesting.
So now, why the MHz freq the LM3404?
Thank you,
/\/elson
On Fri, 29 Aug 2008, Ernest Christley wrote:
<echristley(at)nc.rr.com>
> Hi Bob,
> such as this? Rather, why not in high 100's of Hz given that the eye can't
100's of Hz will put you in the audio range and possibly give a humm in the
audio portions of the airplane. Somewhere just above 30KHz would seem like
Posted: Fri Aug 29, 2008 9:39 am Post subject: Kitplanes article on an Elegant LED driver |
I think Bob answered that well. Switching power supplies have an easier
time of it at higher frequencies. The power supply in the back of your
computer converts the 60Hz line signal up to something like 10KHz (IIRC)
for the same reason. It is much easier to transform and then rectify a
higher frequency signal to a clean output. The components can be much
smaller and there is less heat generated.
Posted: Sat Aug 30, 2008 5:29 am Post subject: Kitplanes article on an Elegant LED driver |
Hi Ernest,
My apologies. My intention was not to loose site of the original question
should this be read years from now in one of the archives.
Take care,
/\/elson
I think Bob answered that well. Switching power supplies have an easier time
of it at higher frequencies. The power supply in the back of your computer
converts the 60Hz line signal up to something like 10KHz (IIRC) for the same
reason. It is much easier to transform and then rectify a higher frequency
signal to a clean output. The components can be much smaller and there is
Posted: Sat Aug 30, 2008 5:33 am Post subject: Kitplanes article on an Elegant LED driver |
Hi Bob,
Thanks for the great explanation - as usual.
Do not archive.
Take care,
/\/elson
On Fri, 29 Aug 2008, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)cox.net>
> Hi Bob,
> Thank you,
> /\/elson
Great question. The problem of selecting an operating
frequency comes from a trade-off in reactances . . .
in the form of inductors and capacitors. The higher
you go in frequency, the more energy can be stored on
a given size inductor (assuming the core is loss less).
The higher you go in frequency, the easier it is to
couple energy via capacitors . . . both for the purpose
of bypassing and transfer.
In this case, the power supply is an energy conversion
system that stores a short pulse of current on and inductor
and then retrieves that energy at a different voltage level.
Given no other considerations for efficiency of the switching
devices and losses in the magnetics, one would LIKE to operate
at the highest possible frequency to drive down the physical
size of components.
Example. Step down transformers for 60 Hz AC delivered to
the house can handle about 60 watts per pound of transformer
core and copper. Airplanes use 400 Hz and the same transformer
weight and volume can handle over 6 times the power . . .
but the iron for the transformer must be tailored for low
losses at the higher frequency.
The high output LEDs need about 4v per lamp (whites) but
they're CURRENT driven devices. The really cool thing about
switchmode power supplies is that you can take energy in
at voltages in a much below or above the desired output
levels and bring the energy out as either a constant current
or constant votlage. The LM3404 is designed to operate in
the constant-current mode.
Batteries are not constant voltage devices . . . so the
most efficient flashlights will have a rather sophisticated
voltage to constant current generator that accepts battery
voltage over the full range useful output and delivers
a constant current to the lamp until the batteries are
truly drained. These converters need to be tiny and
efficient . . . highest practical operating frequency
is a strong consideration in meeting design goals.
Eric M. Jones
Posted: Sun Aug 31, 2008 9:44 am Post subject: Re: Kitplanes article on an Elegant LED driver |
My two cents....
I think Jim Weir was not well-advised in publishing his article. There are tons of DC-DC converters available for less than what it would cost you to build one, even if you forget the bench full of test gear and the years of education, and the labor required to do this job well.
My advice--
1) Buy the supply if you need one. www.Astrodyne.com, etc. or Google "DC-DC switcher supply"
2) Don't use a switcher supply if battery voltage DC will do.
3) If you really MUST make one, sign onto National Semiconductor's Web Bench where they will design a supply to your specs, component list, PCB layout and all.
4) This is not a job for the amateur. Switchers supplies are hard work, especially the quiet ones. Here's a free million-dollars-worth of education--"Spend the extra money for a four-layer PCB".
5) The fact is that the LED will almost certainly last longer than the power supply. This should give one pause....
"Inventor: A person who makes an ingenious arrangement of wheels,
levers and springs, and believes it civilization."
--Ambrose Bierce
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
rgf(at)dcn.davis.ca.us Guest
Posted: Sun Aug 31, 2008 2:06 pm Post subject: Kitplanes article on an Elegant LED driver |
I fully agree. Describing this is the same as a handyman magazine
describing how to design wall studs. Huh? As a kitplane builder I don't
want to design and build fundamental electrical/electronic devices. If I
did I'd be subscribing to ARRL or similar.
Instead, Kitplanes should have electrical articles that either describe
basic technique (for the steady stream of beginners) or higher-level issues
like connecting displays/autopilots/GPSs, maybe some of the APRS stuff,
maybe electronic ignitions...
Given Mr. Weir's well-deserved reputation as an abusive hot-head in public
forums, and his poor reputation as a seller in VAF, maybe Kitplanes should
consider someone else writing the electrical articles. Bob?
Ralph Finch
mrspudandcompany(at)veriz Guest
Posted: Mon Sep 01, 2008 10:18 am Post subject: Kitplanes article on an Elegant LED driver |
At 10:55 PM 8/31/2008 -0400, you wrote:
<jimw_btg(at)earthlink.net>
I had a conversation with an engineer from the mfg of the Buck Puck and
the very first thing he suggested is to package the PWS in a
container. Just going to try this? Hope he is right.
That's half the battle. Containers provide (1) attenuation
of radiated emissions and (2) ground reference for line filters
to attenuate conducted emissions.
A metallic enclosure MAY be necessary. Line filters are
the first thing to try. That's why I asked if the noise
conduction path had been identified in an earlier post. If
the noises are noted coming in through the antenna on
vor/com receivers, then the filters need tailoring for vhf
frequencies . . . MUCH smaller/easier than audio/LF
frequencies that plague other victims by conducting noise
out on power lines.
One observes by the packaging of the Buck Puck that it was
not designed to be a stand-alone product but a component
of a more comprehensive assembly. The elegant solution
for integrating this device into airplanes is to built
an adapter board that also mounts a d-sub connector.
The line filter components can be assembled on the board
along with the connector and power supply.
Once the filter components are wired in, you can test to
see if the noise went away. If not, mount the assembly in
a metal enclosure where the 'ground' side of the filters
are connected to that enclosure.
I'll lay out a board and get some WAG filter components
ordered. I need to know if there is continuity between
the LED- and Vin(-). If you can get me this bit of
info, I'll finish the board layout and get those ordered
too. Also, do you plan to use the CONTROL or REFERENCE
features of these devices?
If you are going to build a board, it would be good to keep all options
open.
Roger
Brantel
Posted: Mon Sep 01, 2008 11:17 am Post subject: Re: Kitplanes article on an Elegant LED driver |
Bob,
I am using the simple 4 wire version of the buck puck and do not intend to use the control or reference functions but it would be great if those "could" be used on this rig in the event someone wanted to strobe/dim/on-off control these things for other applications in the plane.
I checked the continuity between the Vin Minus and LED minus and it does have 100% continuity both directions (diode mode not required on meter).
I also checked the current on the input and it was 460mA (at) 12vDC using a wall wart powersupply.
