swperk(at)earthlink.net Guest
Posted: Fri Aug 29, 2008 6:17 am Post subject: How to troubleshoot glide slope not working |
Hi Andrew,
Yes, it could be a bad cable, but there are a couple of other things to
check, too.
Has the radome been removed (particularly if it was right around the time
you started to have the glide slope problem)? The glide slope antenna is
built into the radome, and the cable to the antenna must be disconnected to
remove the radome. Sometimes it doesn't get reconnected when the radome goes
back on.
The other thing to check would be the splitter that is somewhere between the
antenna and the two radios, probably right behind the instrument panel.
Stan
apg86
Joined: 12 Feb 2007 Posts: 22 Location: KAJO Corona CA
Posted: Fri Aug 29, 2008 9:02 pm Post subject: Re: How to troubleshoot glide slope not working |
| swperk(at)earthlink.net wrote: | Hi Andrew,
check, too.
back on.
Stan
We just bough the airplane, I will check the cable from the radome to instruments are is easy access in this airplane thank you
_________________ Andrew P Geraghty
Corona CA |
