Jabiru Engine Mount Attachment Plate Thickness
Thruster87
PostPosted: Thu Aug 28, 2008 1:48 am    Post subject: Jabiru Engine Mount Attachment Plate Thickness Reply with quote
Looking at my Engine Mount for a 601xl [Supplied by Jab USA] and noticed the Firewall Attachment Plates are only 0.080” thick on the Upper L/H and both bottom plates. The upper R/H is 0.125” thick. On the drawing 6-JE-1 it specifies that all should be 0.125” thick. Has anyone else come across this anomaly Cheers
Thruster87
PostPosted: Wed Sep 03, 2008 12:43 am    Post subject: Re: Jabiru Engine Mount Attachment Plate Thickness Reply with quote
Here is a pic of the suspect Jabiru 3300 Engine mount attach plate
 Filesize:  830.76 KB
 Viewed:  330 Time(s)
