sarg314(at)comcast.net Guest
Posted: Mon Aug 25, 2008 9:30 am Post subject: Mate aluminum ram air pressure tube to poly |
Posted: Mon Aug 25, 2008 7:08 pm Post subject: Mate aluminum ram air pressure tube to poly |
I'll try this again since my text got clobbered last time:
I have a 1/4" O.D. aluminum tube coming out of my wing from the pitot
tube which has to some how get mated to a 1/4" poly tube that goes to
the air speed indicator. What is a good way to do this? Van's says just
butt the two tubes together with a length of plastic tube with a 1/4"
I.D. slipped over it. That doesn't sound very reliable.
Will those nylo-seal fittings grip the aluminum tube well enough to be
useful?
Tom S., RV-6A
dsvs(at)ca.rr.com Guest
Posted: Mon Aug 25, 2008 7:40 pm Post subject: Mate aluminum ram air pressure tube to poly |
Tom,
The simple way is to do as Van's says to do. Dan C did it that way. An
other slternative is to flair the al tube ahd use an AN fitting that has a
flair on one end and pipe threads on the other. Mate this to a nylo seal
female pipe fitting and you are all set. Don VS
Posted: Mon Aug 25, 2008 8:10 pm Post subject: Mate aluminum ram air pressure tube to poly |
Don:
As luck would have it I found some 1/4" I.D. tygon tube on my
random-parts shelf and tried it. It grips the aluminum aggresively, so
yes, it looks like it will work better than I expected.
Along these same lines, I just ordered some nylo-seal fittings and 1/4"
tube to hook up my airspeed, altimeter and VSI. Is that what folks
usually use for this purpose?
Don Vs wrote:
Tom,
Posted: Mon Aug 25, 2008 8:26 pm Post subject: Mate aluminum ram air pressure tube to poly |
Yes but you always need to use the inserts to get a good seal.
msausen
Posted: Tue Aug 26, 2008 5:40 am Post subject: Mate aluminum ram air pressure tube to poly |
You could also use the quick connects from the likes of Stein or SafeAir that are basically commercial air line versions of the plumbing quick connects from your local Lowes Depot.
Michael Sausen
RV-10 #352 Fuselage
sbuc(at)hiwaay.net Guest
