Brake Linings
Goto page 1, 2  Next
coop85(at)cableone.net
PostPosted: Sun Aug 24, 2008 11:54 am    Post subject: Brake Linings Reply with quote
It's time to replace the brakes and my research has found Tim's notes of
requiring Cleveland part# 66-112. However, Vans has a brake kit with 4
linings and the rivets for $33. I'm guessing those aren't Cleveland parts
so I was wondering if anyone knew of RAPCO now had a matching part? I'll
happily order the parts from Vans, however I'm a lot closer to AS&S and I'd
like to save on the shipping since I have to order the brake tool from them
anyway.
Marcus
Kelly McMullen
PostPosted: Sun Aug 24, 2008 1:32 pm    Post subject: Brake Linings Reply with quote
AS&S shows Cleveland version for 15.60 a pair, under Beech Skipper. So
tax vs shipping would be the tie brake.
On Sun, Aug 24, 2008 at 12:53 PM, Marcus Cooper <coop85(at)cableone.net> wrote:
anyway.
Marcus
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
dlm46007(at)cox.net
I believe you will find that the Rapco brake linings use same numbering
system as Cleveland but have RA as a prefix.
dlm46007(at)cox.net
PostPosted: Sun Aug 24, 2008 1:34 pm    Post subject: Brake Linings Reply with quote
You might order the brake rivet set and use your hand squeeze on them.
Kelly McMullen
PostPosted: Sun Aug 24, 2008 1:49 pm    Post subject: Brake Linings Reply with quote
Unfortunately, Rapco doesn't supply equivalents for every variety brake pad.
Kelly McMullen
KCHD
wcurtis(at)nerv10.com
PostPosted: Sun Aug 24, 2008 1:58 pm    Post subject: Brake Linings Reply with quote
I looked at these and though it was about time that someone came out with something like this, but then the price makes no sense. $37 for brake rivet set only when the old complete "hammer" version is only $23. The brake rivet set should be no more than $10. For example this 5 piece rivet set is only $18.95: http://www.aircraftspruce.com/catalog/topages/rivset4sqzr.php
It may be better to just grind down a set of an old rivet set.
http://www.aircraftspruce.com/catalog/topages/brakerivset.php
William
http://nerv10.com/wcurtis/
PostPosted: Sun Aug 24, 2008 2:06 pm    Post subject: Brake Linings Reply with quote
Thanks, good catch on the part number but I read it as price per lining so with the new price of $16.95 that would be double Vans price. I have a question in to AS&S so we'll see. If anyone has confidence that the price is per pair please let me know and I'll hit send on the order. My concern is because there are several airplanes mentioned that need 1 versus 2 of the same part number but the price is the same leading me to believe price is per lining.
Marcus
PostPosted: Sun Aug 24, 2008 2:07 pm    Post subject: Brake Linings Reply with quote
Great call, now why didn't I think of that?!
PostPosted: Sun Aug 24, 2008 2:20 pm    Post subject: Brake Linings Reply with quote
I found Rapco's full catalog on the AS&S sight and you're correct, RA66-112
for the Skipper. Unfortunately AS&S site doesn't have them available. I'll
keep looking though.
Marcus
Tim Olson
PostPosted: Sun Aug 24, 2008 3:06 pm    Post subject: Brake Linings Reply with quote
Cleaveland is the ONLY place making them at this point, so
all linings of that part number are the ones you need.
Rapco is thinking about it, but hasn't.
anyway.
Marcus
dlm46007(at)cox.net
PostPosted: Sun Aug 24, 2008 4:11 pm    Post subject: Brake Linings Reply with quote
I bought Cleveland replacements at Air suppliers out of Texas. Better price
than AS&S IIRC.
dlm46007(at)cox.net
PostPosted: Sun Aug 24, 2008 4:15 pm    Post subject: Brake Linings Reply with quote
You can figure about $15 per lining no matter which supplier you buy for
aircraft; it goes on certified aircraft.
dlm46007(at)cox.net
PostPosted: Sun Aug 24, 2008 4:18 pm    Post subject: Brake Linings Reply with quote
Check http://www.airsuppliers.com/shop/search.asp for 66-11200.
tintopranch
PostPosted: Mon Aug 25, 2008 11:30 am    Post subject: Re: Brake Linings Reply with quote
AircraftSpruce price is for each lining and you will need 4 at $16, I just purchased them...will purchase from Van's in the future, I just needed them faster than Van's could ship.
MARK SUTHERLAND
RV-10 40292
Flying since June 07
PostPosted: Mon Aug 25, 2008 2:53 pm    Post subject: Brake Linings Reply with quote
Yep, I got the e-mail from AS&S and the price is per each lining, $16.95 x 4
- ouch, Van's is getting the order for sure. Rapco has the right part
number in their catalog so they appear to make them, hopefully AS&S will
start carrying them soon but right now they are still showing unavailable.
Marcus
dlm46007(at)cox.net
PostPosted: Mon Aug 25, 2008 3:12 pm    Post subject: Brake Linings Reply with quote
If you are looking for a deal, I ordered 8 pads and 20 rivets from air
suppliers in Texas. Each Cleveland pad was $13.08 and rivets were $.16 each.
Fedex ground was $12.61. total $122.05. Because it is a part that goes on
certified aircraft you have the FAA/PMA premium.
dlm46007(at)cox.net
PostPosted: Mon Aug 25, 2008 3:16 pm    Post subject: Brake Linings Reply with quote
I am told that Vans sells the Grove brand and a set of four linings is $33.
dlm46007(at)cox.net
PostPosted: Mon Aug 25, 2008 3:32 pm    Post subject: Brake Linings Reply with quote
I just called Vans and confirmed that they do not sell Grove for the 10 but
do sell Cleveland 66-11200 , a set of 4 for $33. I ordered two sets. That is
a deal.
jcumins(at)jcis.net
PostPosted: Mon Aug 25, 2008 3:34 pm    Post subject: Brake Linings Reply with quote
Sacramento Skyranch has 66-11200 for $16.64 and they do carry the
RA66-11200 but do nut publish there price on line.
There a great place to get parts and reasonable too.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
partner14
PostPosted: Mon Aug 25, 2008 6:16 pm    Post subject: Brake Linings Reply with quote
I will do my best to NOT shop at Sacto SkyRanch ever again. Went in there to buy some West System Epoxy Resin and was told they don't stock stuff for them Experimental planes! See ya!
Don McDonald
#40636
SB done today
--- On Mon, 8/25/08, John Cumins <jcumins(at)jcis.net> wrote:
[quote]From: John Cumins <jcumins(at)jcis.net>
Subject: RE: Brake Linings
Date: Monday, August 25, 2008, 4:31 PM
[quote]--> RV10-List message posted by: "John Cumins" <jcumins(at)jcis.net> Sacramento Skyranch has 66-11200 for $16.64 and they do carry the RA66-11200 but do nut publish there price on line. There a great place to get parts and reasonable too. John G. Cumins President JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider --
Don A. McDonald
40636
Goto page 1, 2  Next
Page 1 of 2
