lancej(at)charter.net Guest
Posted: Sun Aug 24, 2008 5:52 am Post subject: strobe wire routing |
Hello,
I am constructing an RV9A and finishing the fiberglass tip at bottom
of rudder. What is the recommended routing of strobe/position light
wires at
rear of fuselage through to the tip of rudder? Thanks.
Lance Sorensen
Selah, WA
Vanremog(at)aol.com Guest
Posted: Sun Aug 24, 2008 8:58 am Post subject: strobe wire routing |
In a message dated 8/24/2008 6:53:37 A.M. Pacific Daylight Time, lancej(at)charter.net writes:
| Quote: | I am constructing an RV9A and finishing the fiberglass tip at bottom
wires at
rear of fuselage through to the tip of rudder? |
My suggestion is always to get some distance along a hinge line, so that the wiring will tend to flex in torsion. That is, exit the leading edge of the rudder low and then dress the wire harness up vertically about 3 inches before then turning and going forward thru the tail post.
N1GV (RV-6A, Flying 900hrs, O-360-A1A, C/S, Silicon Valley)
It's only a deal if it's where you want to go. Find your travel deal here.
rv6n(at)optonline.net Guest
Posted: Sun Aug 24, 2008 5:36 pm Post subject: strobe wire routing |
Lance C
6nbsp;
I agree with the suggestion from 2Vanremong 2 E 6nbsp; That sounds like an excellent idea E 6nbsp; I did not put a strobe in my rudder C but that sounds like a great idea E
6nbsp;
6nbsp;
Bob Bales
N954RB
RV6 6nbsp;
80 hr 6nbsp;TT
