Radio gremlins
davidjoyce(at)doctors.org
PostPosted: Fri Aug 15, 2008 10:12 am    Post subject: Radio gremlins Reply with quote
My nearly new Garmin SL30 which has previously worked fine, today in the air
started refusing to change frequency. It was as though it had decided to
stick to just one working frequency and just one standby. Changing the
standby saw it change back to the starting one over the next second or two.
Changing from the active to the standby was followed by it changing itself
back to the previous active. This is a potential disaster as I am due to fly
off to the Black Sea (fortunately the West bank of it!) on Wednesday, and
the avionics experts at RGV Aviation are off on holiday.
The SL30 is linked to a Blue Mountain Efis to display VORs & glide
slopes, and potentially to share frequencies, but the radio behaved the same
when I switched off the Efis.
Any thoughts would be most welcome
Regards, David Joyce, G-XSDJ
nwcmc(at)tiscali.co.uk
PostPosted: Fri Aug 15, 2008 10:59 am    Post subject: Radio gremlins Reply with quote
If you can use an SL40 in the same rack then you can borrow my radio as
I will be too busy to fly my Europa for the next couple of weeks.
Nigel Charles
josok-e(at)ukolo.fi
PostPosted: Fri Aug 15, 2008 11:37 am    Post subject: Radio gremlins Reply with quote
David,
Looks like a wiring fault. Is it very difficult to remove the connecting wires?
Jos
Visit - www.EuropaOwners.org
kheindl(at)msn.com
PostPosted: Fri Aug 15, 2008 11:38 am    Post subject: Radio gremlins Reply with quote
David C
I don't want to ruin your weekend and I hope you find a solution locally. My transponder failed last year and had to be shipped to the factory in Oregon. They charge a flat rate of $ 400 plus the shipping.
They also provide a 'loaner' foc C but again you pay for the courier cost.
Karl
<html><div></div></html>
Subject: Radio gremlins
Date: Fri C 15 Aug 2008 19:10:42 +0100
--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk>
My nearly new Garmin SL30 which has previously worked fine C today in the air
off to the Black Sea (fortunately the West bank of it!) on Wednesday C and
slopes C and potentially to share frequencies C but the radio behaved the same
Regards C David Joyce C ========================>
kheindl(at)msn.com
PostPosted: Fri Aug 15, 2008 12:10 pm    Post subject: Radio gremlins Reply with quote
David C
I just called Garmin Apollo support to get the phone number for calling from overseas: 503-391-3411.
As they are on Pacific time C you may still reach them this afternoon.
Karl
Regards C David Joyce C G-XSD=======================
&g=====================
PostPosted: Sun Aug 17, 2008 3:26 am    Post subject: Radio gremlins Reply with quote
Nigel, That's remarkably kind of you. Unfortunately it's pretty clear that
it is a wiring problem. However the RGV Avionics guys return from holiday
tomorrow and I have time if necessary to rewire the whole thing! Regards,
David
PostPosted: Sun Aug 17, 2008 6:17 am    Post subject: Radio gremlins Reply with quote
Nigel, Very many thanks for that most generous offer. Unfortunately it's
pretty clear that the problem lies in the wiring. However, am optimistic
will have it sorted tomorrow. Regards, David
