		James Baldwin
				 Posted: Sat Aug 16, 2008 8:56 pm    Post subject: B&C alterator problem |
				Bob and others -
 I have a newly purchased RV8 with a B&C 40 amp alternator and automotive style blade fuses.  Good grounding with a firewall mounted ground bus which is then routed to the engine.  The digital ammeter indicates a running load of 6-7 amps.  The battery is a Concorde dry cell mounted on the firewall.  On two separate occasions the 15 amp alternator field fuse has blown without any additional or noted transient loads being placed on the alternator.  The builder had this happen to him also and he thought it was the battery so he replaced it.  The new, year old Concorde battery has great cranking power so I am not looking at this as a potential problem.  The only other problem I have noted is when using all of the lights, strobes, fuel pump and electric flaps the main 40 amp C/B popped once.  Ignoring this as an overload my real problem appears to be the field fuse.  Why does the 15 amp field fuse blow and what's the smartest way to diagnose this problem?  Thank you.  JBB
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		nuckolls.bob(at)cox.net Guest
				 Posted: Sun Aug 17, 2008 6:12 am    Post subject: B&C alterator problem |
				At 10:39 PM 8/16/2008 -0700, you wrote:
 Bob and others -
    The first problem is that the original builder did not
    understand the physics of the system he/she was crafting
    and chose not to study and understand why the z-figures
    were designed the way they are.
    A 40A breaker on a 40A alternator is UNDERSIZED. The
    nameplate rating of an alternator is for worst-case
    conditions. I.e. minimum rpm for full output and max
    ambient operating temperature. Under less stressful
    conditions, the alternator may deliver 15 to 25%
    more current.
    This says that the 60A breaker on the b-lead of 60A
    alternators in 100,000 GA aircraft is DESIGNED to
    nuisance trip. Suggest you replace the 40A breaker
    with a 30-50A current limiter out on the firewall.
    There should not be a field fuse with an LR series
    regulator. These us crowbar OV protection and are
    designed to work downstream of a breaker only. Is
    the recommended 5A breaker also installed? IF so,
    the wiring between the breaker and the bus needs
    little if any protection. The z-figures recommend
    a fusible link . . . exceedingly robust compared
    to the fuse.
    Now we need to figure out what's irritating the
    OV protection system. Do I presume correctly that
    the regulator also came from B&C (LR3 series?) or
    is there some other combination of regulator/ov
    in place?
    I'll assume that since the field protection is being
    nuisance tripped, there is some form of crowbar
    ov protection in place.  The ov protection may
    be an older version that was sensitive to some
    forms of normal bus transients. The designs at
    both B&C and AeroElectric Connection were modified
    to eliminate that condition . . . the system you're
    working with may need to be updated.
    This is not a condition unique to 'crowbar' ov
    protection. EVERY ov protection system has some
    form of comparator between bus voltage and
    some stable reference. When a setpoint is exceeded,
    it sends a signal to some form of disconnect
    device (relay, transistor, scr, etc). There is
    a dynamic component to ov protection too . . .
    voltage excursions above the setpoint are allowed
    as long as they do not exceed certain time
    intervals. It's the fine tuning of the dynamic
    sensitivity that makes some products prone to
    nuisance trips. I've probably designed two dozen
    or more OV protection systems in my career, I've
    only had to re-tune two of them. In one case,
    the transient condition generated by the aircraft
    was greater than the Mil-STD-704 guidelines
    to which the product was crafted.
    Tell us what regulator/ov combination is installed.
    If an LR3, what's the manufacturing date? If
    an AEC crowbar module, what colors of wires does
    it have. Older versions are red/black, newer
    are orange/black.
