kenryan(at)alaska.net Guest
Posted: Sun Aug 10, 2008 7:55 pm Post subject: 701 vs 750 - useful load |
Thanks to those who responded to my
query on empty weights for the 701.
More input would be welcome!
Zenith lists the useful load for the 750 as 545 lbs.
(as compared to 520 for the 701) . . .
BUT
Sebastian told me that using the Rotax 914 in-
stead of the 0-200 would save about 100 lbs.
I think he's a little high on that, but I do believe
you would save 75 lbs. (and gain 15 hp) so that
would bring the useful load up to 620 lbs. (More if
you figure in the reduced weight of your wallet.)
Data I've seen regarding fuel consumption at 65%
power is:
912 UL 4.2 gph
912 ULS 4.8 gph
914 UL 4.8 gph
So it looks to me like if you go 750 with the powerful
Rotax, you will gain 100 lbs. useful load with no fuel
penalty (at least at cruise).
Consumption for the 914 does jump at higher power
settings:
75% 5.7 gph
100% 9.0 gph
Ken Ryan
http://kenryan.com
"Only two things are infinite, the universe and human stupidity,
and I'm not sure about the former." -Albert Einstein-
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Sun Aug 10, 2008 8:22 pm Post subject: 701 vs 750 - useful load |
A middle ground would be to fly the 750 with a Jabiru 3300.
-- Craig
billmileski
Posted: Sun Aug 10, 2008 8:44 pm Post subject: Re: 701 vs 750 - useful load |
Ken,
The fuel consumption figures for the 912 series seem a bit high to me; I regularly see less than 4 gph with a 912S, with a 701 cruising at 85mph, which I assumme must be at least 65% power.
Although I wonder.. the plane will do 110mph at full throttle, and if propellor/airframe load varies with the square of velocity, then it's possible that 85mph is more like 60% power..
Bill Mileski
701 912S 140 hrs
kevinthorp
Posted: Fri Aug 15, 2008 6:48 pm Post subject: Re: 701 vs 750 - useful load |
craig(at)craigandjean.com wrote: | A middle ground would be to fly the 750 with a Jabiru 3300. -- Craig
That would gain more useful load over a Cont engine, but wouldn't it also shift the CG back, reducing the baggage you could carry?
Posted: Fri Aug 15, 2008 7:00 pm Post subject: 701 vs 750 - useful load |
I don't know. I suspect the motor mount for the Jabiru places the engine's
CG farther forward than the mount for the Cont. I believe a 601XL with a
Jabiru can carry just as much baggage as an XL with a heavier engine.
-- Craig
Posted: Fri Aug 15, 2008 7:04 pm Post subject: 701 vs 750 - useful load |
Also on the XL with the Jabiru 3300 the battery is mounted on the firewall.
On heavier engines the battery commonly goes behind the seat or in the tail.
-- Craig
Joemotis(at)aol.com Guest
Posted: Fri Aug 15, 2008 8:46 pm Post subject: 701 vs 750 - useful load |
How about a 750 with a Raven redrive on the big fuel injected Suzuki 1.3 , I believe the 1998 model year is the optimum.?
Is any one running this in a CH 701? How much does the engine and cooling system with coolant in it weigh?
As in a number one could use as a benchmark.
Joe Motis
Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos.
kmccune
![](images/avatars/19685264047842535ec9ff.jpg)
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Sat Aug 16, 2008 4:51 am Post subject: Re: 701 vs 750 - useful load |
Don't forget that the 750 also carrys 3 gallons or 18 lbs more fuel in standard trim. so knock that off the 25lb advantage.
On G13 wet weight:
" 175lbs. dry for engine/redrive/computer/exhaust. Add 15lbs. for turbo
kit. Add 5-6 lbs. for radiator. We will be 17- 20 lbs heavier than 912
Rotax installation. Proportionally less for the 914 turbo Rotax equivalent
as our exhaust/turbo/ intake plenum are lighter than Rotax for the turbo
version."
This is from Raven on the SVS1300 Turbo, don't forget the weight of the stuff Rotax hangs on the firewall when figuring Rotax weight.
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
