Timing gear
Goto page Previous  1, 2
Michel
PostPosted: Thu Aug 14, 2008 10:42 am    Post subject: Timing gear Reply with quote
You are right, Dave, an oil leak won't repear itself as we do from e.g. the flu. Mechanical faults only get worse with time.
Thank you for the detailed explanation, Lynn. I will replace that seal but ... I must wait. You see, I had a operation and I still have the stiches. I am not supposed to lift my left arm more than 90 degrees and ... as you know, there isn't much room behind a Jabiru in a Kitfox. But I will get to it.
Incidentally, I just went flying a few touch and go, today, with my son as the PIC. It was nice to be in the air again, even as a passenger.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... flying as a PAX.
Page 2 of 2
