Aircraft ID plate
Goto page Previous  1, 2
Guy Buchanan
PostPosted: Tue Aug 12, 2008 7:46 pm    Post subject: Aircraft ID plate Reply with quote
At 05:47 PM 8/12/2008, you wrote:
But I'm also reluctant to add more drag, do I really need that 2nd antenna?
Does everyone with and ELT have a dedicated external antenna?
My ELT antenna is internal. It's attached to an upper horizontal
behind the seat and points down. (Works better upside down that way. Very Happy )
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Guy Buchanan
At 12:21 PM 8/12/2008, you wrote:
So I am opting for bolting it to the seat tray, as close to center as
possible, facing forward as required. There I can get to it easily to switch
it on manually, or unclamp it to take with me (it's made for that). Anybody
care to note where/how their ELT is mounted please?
Mine's on a small panel mounted to the horizontal tubes using Adel
clamps, behind the left seat.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
matronics(at)bob.brennan.
PostPosted: Wed Aug 13, 2008 2:56 am    Post subject: Aircraft ID plate Reply with quote
Well that's all the endorsement I need... internal it is!
Thanks Lowell &Guy for the pointers.
Float Flyr
PostPosted: Wed Aug 13, 2008 5:06 pm    Post subject: Aircraft ID plate Reply with quote
The reason the instructions say to mount the ELT antenna a minimum of 5 ft
away from your com ant. is to reduce the occurrence of a parasitic
resonance. That could reduce the power output of your com. The reverse is
also true if the ELT goes off and the com antenna is too close it will
become a parasitic element to the ELT Ant. Why not mount the ELT ant on top
of the vert stab?
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Page 2 of 2
