jvanlaak(at)aol.com Guest
Posted: Tue Aug 12, 2008 1:17 pm Post subject: Trio |
Listers,
I am having trouble getting my Garmin 420 to talk to my Trio autopilot. I can see that there is a low voltage on the rs232 output from the Garmin and I had my 295 talking to the Trio just fine, but these two act like strangers.
Documentation is rather light on both sides (the trio says it will autodetect and I do not have the install manual for the 420) so any help would be appreciated.
Jim
RV-6 N79RL bought flyingIt's time to go back to school! Get the latest trends and gadgets that make the grade on AOL Shopping.
sbuc(at)hiwaay.net Guest
Posted: Tue Aug 12, 2008 2:18 pm Post subject: Trio |
jvanlaak(at)aol.com wrote:
| Quote: | Listers,
autopilot.? I can see that there is a low voltage on the rs232 output
Jim RV-6 N79RL bought flying
Call Jerry, Chuck or Sid at Trio. They offer superb customer service and
will get you up and running promptly.
Sam Buchanan
bo124rs(at)hotmail.com Guest
Posted: Tue Aug 12, 2008 2:35 pm Post subject: Trio |
Sounds to me you need to set your serial port output on your 420. Push your "enter" button on the 420 as you turn the unit on. This will access your setup page. The output on mine going to my GRT is "Aviation". The output from my serial GRT port to my Trio is set at "autopilot". I don't recall what the different settings are within the Garmin but if "autopilot" is an option give it a try and then go the baud rate page. I talked with Trio at the time and they said the buad rate couild be either 4800 or 9600. We'll see but the GPS is talking to my Trio. Save your setting by turning off your Garmin.
Good luck C
Dana Overall
Richmond C KY i39
RV-7 slider "Black Magic" Flying..well sorta C useta C kinda
Barrett Precision O 360 A1A
Hartzell C2YR-1BFP/F7497-2
http://rvflying.tripod.com/blackmagic.jpg
http://www.youtube.com/watch?v=MMi05-WU2D0#GU5U2spHI_4
To: rv-list(at)matronics.com
Subject: RV-List: Trio
Date: Tue C 12 Aug 2008 17:17:10 -0400
Listers C
I am having trouble getting my Garmin 420 to talk to my Trio autopilot. I can see that there is a low voltage on the rs232 output from the Garmin and I had my 295 talking to the Trio just fine C but these two act like strangers.
Jim
get="_blank">http://www.matronics.com/Navigator?RV-List
http://forums.matronics.com
| Get more from your digital life. Find out how. [quote][b]
