gary.algate(at)sandvik.co Guest
Posted: Sun Aug 10, 2008 9:49 pm Post subject: Wheel pants |
Lynn
I am in the process of fitting the pants - the instructional drawings are pretty poor and I don't quite understand the process re cutting the inside of the pants for the gear legs. Do you just cut enough fibreglass away to clear the obstructions (gear leg and brake lines etc) and then use the aluminum covers to cover the opening with the bent lip at the bottom. As you have the Grove gear this probably makes no sense at all so if anybody else has the tube gear and wheel pants I'd love your comments.
For the record I am a mechanical engineer and these instructions have me beat!
Gary
Gary Algate
Classic 4 Jab2200A
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission. [quote][b]
Lynn Matteson
Posted: Mon Aug 11, 2008 6:01 am Post subject: Wheel pants |
Hi Gary-
Basically what I did was to cut and fit. It helps if you can find the
very tiny dimple on the outside of the pant where the outer support
spindle hole is to be drilled. I found it on mine, and drilled this
hole, then it was a matter of nibbling away at the inner areas of the
pant until they cleared the obstructions as you observed. I ran a 1x4
board from the bottom of the wheel back to the tailwheel to mimic the
ground, then oriented the pant radially so the bottom became parallel
with this board. (Just as an aside, I made my pants just a wee bit
too close to the ground, and am always wary of transiting from grass
to runway, and vice versa. And low tire pressure can be damaging too.
I was too concerned with the tire sticking out and causing drag.) At
first I cut too much fiberglas away and had to build the area back
up. The second pant went much easier. I reinforced the areas (with .
032" aluminum as I recall) where the mounting bolts go through the
'glas, and in fact used nutplates for mounting the machine screws. I
imbedded the aluminum plates in fiberglas cloth and resin, keeping
the screw holes clean with grease. I made a U-shaped reinforcing
plate that surrounds the whole cut-out, and extends to the bottom of
the pant. Then I made a cover plate that ties the bottom of the pant
front-to-rear, and a slot in that to allow the brake line to exit.
The last picture shows the bottom cover/fairing that displays a less-
than-elegant landing that I made in a 19-35 mph crosswind in
Tennessee last year.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
On Aug 11, 2008, at 1:48 AM, gary.algate(at)sandvik.com wrote:
Quote: |
Lynn
have me beat!
Gary
Gary Algate
Classic 4 Jab2200A
arise as a result of the e-mail transmission. _-
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
Description: |
Filesize: |
177.17 KB |
Viewed: |
258 Time(s) |
Description: |
Filesize: |
134.68 KB |
Viewed: |
254 Time(s) |
Description: |
Filesize: |
188.36 KB |
Viewed: |
236 Time(s) |
Description: |
Filesize: |
184.75 KB |
Viewed: |
251 Time(s) |
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Mon Aug 11, 2008 2:57 pm Post subject: Wheel pants |
Lynn
Thanks for the step by step instructions and photos - that is exactly what I needed.
best regards
Gary
Gary Algate
SMC, Exploration
