Remote Oil Filter ?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
andynfultz(at)bellsouth.n
PostPosted: Thu Aug 07, 2008 1:27 pm    Post subject: Remote Oil Filter ? Reply with quote
Have any of you guys installed a remote oil filter kit on you r EA-81
engine? If so, where did you find it? I'm having a hard time finding one
with the correct size. The oil filter on my engine has an o-ring that is
2.25" ID and 2.5" OD. The smallest remote filter kit I can find has an
o-ring size of 2.5" ID and 2.75" OD. Any help appreciated.
Andy F.
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
gkrysztopik(at)satx.rr.co
PostPosted: Thu Aug 07, 2008 2:00 pm    Post subject: Remote Oil Filter ? Reply with quote
I pasted some old notes below - available from Summit racing. it was
about $100 and about 5lbs extra for all the hoses and hardware so I
skipped it. airflow over the oil pan seems to do just fine. the water
and oil cooling are related - i tried many different systems and poor water
cooling increased oil temps and poor oil cooling increased water temps. once
I removed the exhaust from being right behind the oil pan and got good airflow
around the oil pan and exhaust and a good radiator, everything was good.
A 11/16-16 female thread will fit loosely but may appear correct when
threaded to a male 3/4-16 male fitting. However the joint is around 1/3 as
strong (depends on the actual thread tolerances). The result is dangerous
however.
The soob EA81 Oil filter is now and has always been 3/4-16.
good luck,
gary
Andy F.
larry(at)macsmachine.com
PostPosted: Thu Aug 07, 2008 2:37 pm    Post subject: Remote Oil Filter ? Reply with quote
Hi Andy,
I've a friend Kelly Meiste who has a Stratus EA81 that uses a JC Whitney
sourced remote oil filter. A bit different, but
he says it works well, uses a standard size filter and reduces the oil
temps by 10-degrees or so.
Pictures attached
Andy F.
 Filesize:  61.2 KB
 Viewed:  796 Time(s)
 Filesize:  58.94 KB
 Viewed:  763 Time(s)
 Filesize:  61.79 KB
 Viewed:  807 Time(s)
 Filesize:  87.35 KB
 Viewed:  791 Time(s)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
