Pneumatic Installation
Goto page Previous  1, 2
keithhickling(at)clear.ne
PostPosted: Sun Jul 27, 2008 2:46 pm    Post subject: Pneumatic Installation Reply with quote
Karl,
I don't disagree with what you say at all. I, like I suspect Ron, Graham and Mike, was just discussing the theoretical aspacts.
grahamsingleton(at)btinte
PostPosted: Sun Jul 27, 2008 3:04 pm    Post subject: Pneumatic Installation Reply with quote
Mike
A few random thoughts
The stall warner is in fact a single point AoA meter. It tells you that
the wing is about to stall .
Near the ground attitude is important so you have to look out.
An audio AoA similar to the variometers in gliders would be nice. Just
like the stall warner but callibrated to give varying tone around the
critical AoA
My main point about AoA is it warns you when you get near stall, the ASI
tells you that you are at stall speed 20 seconds too late.
Graham
Mike Parkin wrote:
Graham,
I am not sure what is the safer route. I have never flown a low wing
loading ac with an angle of attack system, so I cannot say how useful it
would be. Certainly in many jets it is the major source for performance
indication. Having said that, with experience, for performance manoeuvring
I found that buffet was as good an indication as looking at the AoA
indicator/HUD. I guess it is 'what ever floats your particular boat'.
Personally with the Monowheel Europa, I tend to subscribe to Carl's view on
the problem. I have the Factory stall warner which I have found to be
spot-on. It gives an aural warning of impending stall in both
configurations. As an added bonus it gives a good indication of an
approaching accelerated stall.
Approach speed and approach path are important, but I find that having
arrived at the flare in good shape it becomes a case of keeping one's head
out of the cockpit and landing the monowheel very much by feel and visual
reference. Now if the stall warner sounds just before the tailwheel makes
contact slightly before the mainwheel - then it truly is a red letter day.
Mike.
Do not archive.
Fergus Kyle
PostPosted: Mon Jul 28, 2008 7:19 am    Post subject: Pneumatic Installation Reply with quote
I have been following the subject correspondence and must say I
think the proponents of the Europa Stall Warner have a point. However, their
sole interest appears to be finding out when they are going to stall - and
nothing else. That is of course important and stall strips will give them
that.
However when you turn to the AoA system, you encounter much more.
Having experienced an AoA approach to a carrier, I can say that there is no
comparison. Yes, it gives you your approach to a stall [and much more timely
and accurate warning than a stall warner does]. It also tells you when to
accept an ideal soar figure for loss of engine, when to revert to and use a
long-range attitude, how to loop with the same AoA around the circle - and
what effect ground effect has on stall speed. AND all these automatically
adjust for change in weight or CG - no charts needed.
The argument about diverting attention during landing loses value
when the warning is visual and in the vision of the lander, i.e: on the
coaming where the landing strip is seen. Since a change of colour is all it
provides, little or no conscious diversion should occur. Of course the ideal
warning should be in a HUD, but that's a touch effete in a Europa.
Naturally, a needle down on the instrument panel is useless for the stall
problem.
Just my $0.02.
Ferg
PostPosted: Mon Jul 28, 2008 9:21 am    Post subject: Pneumatic Installation Reply with quote
think the proponents of the Europa Stall Warner have a point. Of course the ideal
problem.
Just my $0.02.
Ferg
Fergus
worth rather more than 2 cents imho Very Happy
mikenjulie.parkin(at)btin
PostPosted: Mon Jul 28, 2008 10:38 am    Post subject: Pneumatic Installation Reply with quote
Hi Ferg,
All totally true. But don't forget that most "heavy metal" with AOA also
had a stick/pedal shaker. Presumably to warn those pilots of an incipient
stall that they had missed on the indexers/HUD. As I recall for deck ops,
the F4 had an AOA audio as well as indexer lights and a head down indicator.
Certainly, ours did.
I never did think that the AOA was the panacea to all ills. IAS and power
setting were also very important. It is possible to make the AOA read
whatever you like, although the flight path might not be the one required.
Yes, the AOA will indicate the best glide angle but depending on the wind,
that might not give the best speed to fly. The ability to fly a constant
AOA loop is a little on the irrelevant side in an aircraft that is not
cleared for aerobatics.
I think that once in ground effect an AOA indication is a bit superfluous on
an aircraft that when landing is virtually stalled - monowheel anyway.
The choice of to buy or not to buy is an individual one, and I would be the
last to criticise anyone's decision to fit AOA. If it works for them, then
great. I would personally spend the money on a better radio or a Mode S
transponder.
My 2 pence worth.
Mike
PostPosted: Mon Jul 28, 2008 10:44 am    Post subject: Pneumatic Installation Reply with quote
Ferg,
PS. Stall strips can affect short field performance - a stall warner does
not.
Mike
PostPosted: Mon Jul 28, 2008 12:22 pm    Post subject: Pneumatic Installation Reply with quote
Mike
absolutely right, anywhere between 15 ft altitude and zero, the visual
cues are all you need. However it's the earlier stages from base leg to
late finals where AoA is more useful and ASI is less useful, (imho, I
don't have your or Fergs' experience, or Ivan's come to that) I speak as
a not very current, not very intuitive pilot but with some painful
experience. It would be nice if I can save someone from making my
mistakes again.
Graham
transponder.
My 2 pence worth.
Mike
PostPosted: Mon Jul 28, 2008 12:30 pm    Post subject: Pneumatic Installation Reply with quote
That's why I took em off. Wish I hadn't now Sad
Graham
incidentally that's another story, very careful attention to the leading
edge profile (digital airfoil section as Don designed) make an enormous
difference to the character of the stall. 3 times and 3 airplanes now
many hours spent on the LE have given very good low speed handling. It's
the first 3 inches of the leading edge that make all the difference.
Mike Parkin wrote:
Ferg,
not.
Mike
rob(at)hyperion-ef.com
PostPosted: Mon Jul 28, 2008 12:48 pm    Post subject: Pneumatic Installation Reply with quote
Only one of the following can reliably keep you from making a smoking hole
in the ground if you make the wrong small mistake at the wrong altitude:
Mode S transponder
Better radio
Stall warning device
AOA
Guess which one.
Best regards,
Rob Housman
Irvine, CA
Europa XS Tri-Gear
A070
Airframe complete
PostPosted: Mon Jul 28, 2008 1:03 pm    Post subject: Pneumatic Installation Reply with quote
Which one Rob? stall warner and AoA are both angle of attack devices Wink
Graham
Mode S transponder
Better radio
AOA
Guess which one.
Best regards,
Rob Housman
PostPosted: Mon Jul 28, 2008 1:40 pm    Post subject: Pneumatic Installation Reply with quote
OK, Uncle Uncle - you must be right.
MP
rparigor(at)suffolk.lib.n
PostPosted: Mon Jul 28, 2008 2:45 pm    Post subject: Pneumatic Installation Reply with quote
Hi Graham
"very careful attention to the leading
the first 3 inches of the leading edge that make all the difference."
Don Dykins talks of Europa airfoil in his book and essentially what he
does is puts an amount of NASA Lead Edge Droop that keeps stall very
acceptable but not so much as to increase high speed drag too much.
He accomplished this by using computer at work and plotting many points.
On Classic it is a lot harder to keep airfoil to his specification
compared to XS I am sure!
On my 80 oz 3/4 hp 48" flying wing I put articulatable NASA Lead Edge
droop on the outboard 1" of wing that has range between -5 and +30
degrees.
Without any droop the plane is stink fast, but I will crash 1 in 4
landings! Will snap upside down, almost unrecoverable from 1000 feet,
make a hole from 100 feet guaranteed.
Dial in ~ 10 degrees and the plane turns into a pussycat as far as stalls
go! Anything more and stall is fine just begins to drag up at higher
speeds.
As a note if I go to -5 degrees the plane is even faster than with 0
degrees, you do not want to get anywhere near stall, plane snaps upside
down sooooo fast.
I fooled with 5 degrees droop on much lighter loaded planes that had poor
stall manors (35oz and 20oz) and it cured the problem instantly.
Anyway looking at my XS short wing, the first about 3 inches on the bottom
looks just about right to my "eyechrometer" to be a great compromise to
allow benign stalling and not drag up at higher speeds.
I can see on a Classic if shape on bottom of wing gets changed not even
too much, plane will fly fine, but stalls can become interesting.
In Dons book he speaks of how nasty stalling on some yesteryear aircraft
was dealt with by adding in the field NASA Lead Edge Droop (Brits have
another name for NASA Lead Edge Droop). Idea is to keep taking some away
till stall got nasty then add a little more back, then attach permanent.
I mentioned a while back if I have a plane that drops a wing, instead of
stalling the better wing at a faster airspeed by installing stall strips,
I think I would rather fix the worst wing to fly slower.
Even on a plane where AOA on one wing and flap is off, NASA Lead Edge
droop added will help out, if not a complete fix, then at least in part
with stall strips if really whacked. I know that Bud thinks not much or
changing angle of a wing for a poor flying plane.
NASA Lead Edge Droop changes the AOA of the wing, by adding to the bottom
of the lead edge of the wing it decreases AOA of that wing.
I fully agree with Graham that starting with the lead edge lower part of
europa wing to be what Don had in mind ("Dons Droop") is a great idea.
Graham would you be willing to make up some profile templates so mere
mortals could check their plane? I for one will order.
Having too much droop will only cause high speed drag, too little can make
stall a lot more violent.
Flying a heavily loaded plane will probably bring out the worst in a
Europa with not enough of "Dons Droop". Since plane was designed for 1370
AUW, flying at 1450, 1500 or 1525 even if it is only a few times in the
life of your europa it would be wise to make sure you have at least what
Don had in mind.
Ron Parigoris
PostPosted: Mon Jul 28, 2008 3:17 pm    Post subject: Pneumatic Installation Reply with quote
Ooooopppps
"> On my 80 oz 3/4 hp 48" flying wing I put articulatable NASA Lead Edge
droop on the outboard 1" of wing"
Sorry that should have been 1 foot not 1". Each half of wing is 2 feet
long (24") and 1 foot (12") is articulatable.
Ron P.
BTW on my flying wings as I mentioned the weight ranges from 10oz to 80oz.
That is bout the same as flying a short wing europa between 750lbs and
7,500lbs!
PostPosted: Mon Jul 28, 2008 3:40 pm    Post subject: Pneumatic Installation Reply with quote
Hi Ron
The essential thing is that the nose radius is quite small, therefore
VERY easily sanded away, it is also as you say drooped a bit. The effect
is very subtle and not obvious to the unaided eye.
My confused PC has hidden the CAD file of the airfoil section somewhere.
(I Hate Windoze!) I did publish it on the forum a few weeks ago so
anyone who has it please republish it?
Can't see myself being able to help just at the moment. Too many other
pressures, not least a depressed Long EZ still not ready.
Graham
rparigor(at)suffolk.lib.ny.us wrote:
Hi Graham
Don had in mind.
Ron Parigoris
PostPosted: Mon Jul 28, 2008 3:47 pm    Post subject: Pneumatic Installation Reply with quote
Sorry guys too much spackling today
"> BTW on my flying wings as I mentioned the weight ranges from 10oz to
80oz.
7,500lbs!"
Should have been between 750lbs and 6,000lbs.
Ron P.
PostPosted: Mon Jul 28, 2008 5:54 pm    Post subject: Pneumatic Installation Reply with quote
Hi Graham
I have a copy of the profile you posted and will attach to this E-Mail.
I don't have a program to open though.
Anyone want to make up some wing profiles?
Could sent them around like reamers for mod 72.
Ron Parigoris
Visit - www.EuropaOwners.org
http://www.europaowners.org//zfiles/wing_profile_graham_2_202.dwg
uvtreith(at)t-online.de
PostPosted: Tue Jul 29, 2008 7:43 am    Post subject: Pneumatic Installatíon Reply with quote
Hallo Europa Family,
What an amazing response and discussion on the pneumatic installation job.
Up to now I have counted 38 eMails with 11 Europa owners are involved and I have learned a lot of AOA, Stalls etc.
This shows that our Europa-matronics-list is the best way to communicate.
Many thanks for all this input.
My previous question however was quite simple.
As I have the Europa Stall Warner and the Dynon D 100 with its benefit to use also the integrated AOA device, I thought why not using when it is already there and as I have static ports on the fuselage sides, I thought why not using the static tube (on the Europa Pitot/Static device under the wing) as AOA probe. There are some others of us using a D 10, D 100 or D 180 with this benefit like Jos.
But general of course: first will be to fly the Aircraft and feel it.
I wish you all a good time and furthermore this alive active Europa group.
Best Regards,
Bruno Reith
terobo(at)tiscali.co.uk
PostPosted: Tue Jul 29, 2008 12:58 pm    Post subject: Pneumatic Installation Reply with quote
Graham
I agree your sentiments and if you do not have AoA then you naturally
compensate.
Tim Robertson
m.grass(at)comcast.net
PostPosted: Sat Aug 02, 2008 9:37 am    Post subject: Pneumatic Installation Reply with quote
Ferg,
Last year I had the pleasure of getting a ride from John Wigney in his Mono
N262WF. He has the neatest set up of an AOA installation from
http://www.advanced-flight-systems.com/Products/AOA/aoa.html
The neat thing what sets him apart from any other installations is that he,
unlike others, did not mount the display in the instrument panel face beside
other instruments. Quizzing him he had a very valid point. He says he does
not want to be distracted by looking away onto the instrument panel while
in the critical phase of landing. He mounted the display on top of the
instrument module instead. Then he arranged a 1/2 inch wide mirror mounted
on a spring loaded arm just in the filed of view. Part of his landing
procedure is that he unlatches this spring loaded arm. It pops up 45 deg
into the field of view almost like a HUD but only obstruct minimal to none
the forward view. Another point for this device versus the Europa stall
warner is that this is an analog device showing you always how much lift
reserve you have before the wing will stall. The Europa Stall warner is
warning at a specific point. For my aircraft, I like this device but still
will go with the Europa stall warner because I have it already and the price
tag of about $900 is to steep for my opinion but I love his set up.
Unfortunately I forgot to take a picture of that installation. Maybe John
could post a couple if he sees this post after his return from Oshkosh.
Thanks again John for giving me a ride at Jim Butchers home field last year
before Oshkosh.
Michael Grass
N581MG Europa Trigear, Detroit
Still gluing and pasting
Page 2 of 2
