jmcburney(at)pobox.com Guest
Posted: Mon Jul 14, 2008 6:40 am Post subject: Z13/8 questions |
I'm designing the electrical system for my Zenith CH801 based on Z13/8. Two
questions:
1. Would it be an advantage to use the B&C LR3 regulator (a.l.a. Z13/20)
rather than the "generic Ford", and why or why not?
2. In rev. P you have interposed a relay in the E-bus alternate feed line.
What's your reason for this? It seems to be another single point of failure
in a simple circuit.
I'm attaching my modified drawing. Comment on it if you wish. Thanks.
Blue skies and tailwinds
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
 Download |
| Filename: |
8-5992-E-000.dwg |
331.8 KB |
| Downloaded: |
379 Time(s) |
nuckolls.bob(at)cox.net Guest
Posted: Mon Jul 14, 2008 7:43 am Post subject: Z13/8 questions |
At 10:35 AM 7/14/2008 -0400, you wrote:
| Quote: | Bob,
questions:
These are ARCHITECTURE drawings . . . you can consider ANY alternative
components suited to your task. Yes, the LR3 is a very capable, all-in-one
alternator controller that includes adjustable remote sensing regulation,
lv warning, ov protection in a single package. If you don't object to
the price, it's an entirely acceptable alternative.
| Quote: | 2. In rev. P you have interposed a relay in the E-bus alternate feed line.
When we added the 8A alternator, the e-bus continuous
load capability went up to 8A, a bit high for an always
hot lead from the battery bus (tradition says 5A max
but a FUSED lead is much less likely to start a fire
than a BREAKERED lead). If you'd like to stay with the
previous architecture and fuse the alternate feed at
10A, I wouldn't have any heartburn over it. You presently
show a 15A fuse which I presume is intended to support
peak loads, I think I'd put the relay in.
| Quote: | I'm attaching my modified drawing. Comment on it if you wish. Thanks.
You need to add the resistor across the SD-8 filter capacitor
as part of the self-excitation feature.
Fusible link in the main bus feeder is not necessary.
It's unfortunate that you can't find a 12v starter
to fit your engine but the second battery arrangement
will probably work for you.
I've .pdf'ed your drawing and attached to this response
so that others on the list can see what we're talking about.
( -Thomas Paine 1776- )
 Download |
| Filename: |
8-5992-E-000.pdf |
165.15 KB |
| Downloaded: |
419 Time(s) |
