lcfitt(at)sbcglobal.net Guest
Posted: Sat Jun 21, 2008 11:39 am Post subject: New Model IV |
To the list:
I am back bulding again. I never thought I would do it again since flying
superceded the build experience, but then when there is no airplane....
Thanks to the local grapevine, I found a 1992 partially completed kit. It
was outfitted for the 582, so I have some parts that are available. I am
currently working on all the things I learned to wish I had on the original.
Just finished a cabane attached compression spring landing gear. It comes
in at about 8 lbs under the grove gear weight and I like that. It has a
wider stance and is a bit taller than the grove gear. The other major mod
is the elimination of the upper false ribs, replacing them with an aluminum
leading edge from the PVC leading edge aft to the stringer. I hope to
someday actually begin working on the airplane. Pictures of the landing
gear attached.
Glad to be back and active.
Lowell Fitt
Description: |
Filesize: |
70.08 KB |
Viewed: |
583 Time(s) |
Description: |
Filesize: |
90.92 KB |
Viewed: |
630 Time(s) |
wtrooper(at)gmail.com Guest
Posted: Sat Jun 21, 2008 12:04 pm Post subject: New Model IV |
Hello again Lowell -
I cannot say how heart-warming it is to hear this. Also - nice gear!
Best regards to you and Kay -
Bill Mills - Castro Valley
Chinook/912 in progress at LVK
Still lurking after all these years
On Sat, Jun 21, 2008 at 12:33 PM, Lowell Fitt <lcfitt(at)sbcglobal.net (lcfitt(at)sbcglobal.net)> wrote:
[quote] To the list:
I am back bulding again. I never thought I would do it again since flying superceded the build experience, but then when there is no airplane....
Thanks to the local grapevine, I found a 1992 partially completed kit. It was outfitted for the 582, so I have some parts that are available. I am currently working on all the things I learned to wish I had on the original. Just finished a cabane attached compression spring landing gear. It comes in at about 8 lbs under the grove gear weight and I like that. It has a wider stance and is a bit taller than the grove gear. The other major mod is the elimination of the upper false ribs, replacing them with an aluminum leading edge from the PVC leading edge aft to the stringer. I hope to someday actually begin working on the airplane. Pictures of the landing gear attached.
Lowell Fitt
rjdaugh
Posted: Sat Jun 21, 2008 4:24 pm Post subject: New Model IV |
Good news Lowell!
I like the looks of your gear. And the dimensions. And the weight. I can
assure you though that the Grove gear is tough!
Randy
Randy Daughenbaugh, N10NH
Black Hills of South Dakota, - Near Mount Rushmore
Home Strip, Grass Room in Hangar for visitors
Series 5/7 (7 Firewall Forward) 912S, Warp Drive Taper Tip
Gross Weight 1320 lbs, Flying since November 2004
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
vft(at)aol.com Guest
Mo
Joined: 29 Jan 2006 Posts: 14 Location: Massachusetts
Posted: Sat Jun 21, 2008 8:11 pm Post subject: New Model IV |
Welcome back Lowell. You have been missed.
Maurice Fitzgerald
mdkitfox(at)aol.com Guest
Posted: Sat Jun 21, 2008 8:44 pm Post subject: New Model IV |
Lowell,
Welcome back to the list. It's great to hear you've returned to building.
Rick Weiss
Series V, still building, but there is light at the end of the tunnel!
Jim Shumaker
Posted: Sat Jun 21, 2008 9:16 pm Post subject: New Model IV |
Welcome Back Lowell. Always great to hear from you.
Jim Shumaker
_________________ Jim Shumaker |
Lynn Matteson
Posted: Sun Jun 22, 2008 2:42 am Post subject: New Model IV |
Hi Lowell-
Nice to hear from you.
It may just be all the shadows or the angle at which you took the
shot, but it seems like there are more structural members within the
fuse of your plane than normal. Is that just an illusion, or did you
add some reinforcements?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/530 hrs
airplane....
Lowell Fitt
<Landing Gear 3.jpg>
<Landing Gear 5.jpg>
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Catz631(at)aol.com Guest
Posted: Sun Jun 22, 2008 5:15 am Post subject: New Model IV |
Lowell,
Good to have you back on the list! Did I tell you that I absolutely love the elevator trim system you made for me? It's first class all the way! What a difference in the aircraft!
Dick Maddux
Fox 4-1200
Pensacola,Fl
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
Float Flyr
Posted: Sun Jun 22, 2008 11:14 am Post subject: New Model IV |
Welcome home!
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Sun Jun 22, 2008 1:15 pm Post subject: New Model IV |
Thanks to all for the welcome. To Lynn, this is the typical Model IV. I
guess with a bright sunny day and lots of contrast it makes it look busy.
Actually, though, from the advice of friends, the turtle deck area has been
modified to allow the shoulder straps to attach directly behind pilot and
passenger. I always struggled keeping the shoulder harness from dropping
off my shoulder. Repositioning the center lug also makes the baggage area
more accessable.
Lowell
Lynn Matteson
Posted: Sun Jun 22, 2008 5:35 pm Post subject: New Model IV |
Lowell-
I sort of cured that shoulder harness problem by using a 2" wide
length of belting material (similar to the harness) wrapped around
the two shoulder belts, and velcroed to itself. In other words, it's
a circle of belting material that has velcro attached such that it
becomes a straight section in the middle with a loop on each end. The
straight section is formed when the ends of the belt are wrapped
around the harness and pressed together. I'm not explaining it very
well..too late in the day...but the result is the shoulder straps are
held together on your shoulders, yet the thing can be removed very
easily if needed. I put mine behind the down tubes.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Jun 22, 2008, at 4:59 PM, Lowell Fitt wrote:
Quote: |
<lcfitt(at)sbcglobal.net>
IV. I guess with a bright sunny day and lots of contrast it makes
it look busy. Actually, though, from the advice of friends, the
turtle deck area has been modified to allow the shoulder straps to
attach directly behind pilot and passenger. I always struggled
keeping the shoulder harness from dropping off my shoulder.
Repositioning the center lug also makes the baggage area more
accessable.
Lowell
N369LM |
Sbennett3(at)aol.com Guest
Posted: Sun Jun 22, 2008 5:54 pm Post subject: New Model IV |
I have hooker harnesses on my 4 When I do cross countries and use the small cargo area, Me and my passenger just loop our shoulder harnesses on the outside only. Belts only on the inside. Steve Bennett Rebel...
dave
Posted: Mon Jun 23, 2008 1:38 am Post subject: Re: New Model IV |
Lowell, Welcome back and I love you gear. Your cub type gear is awesome. Looks like a cheaper and light alternative to the grove gear.
Will you be selling it ?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Mon Jun 23, 2008 5:40 am Post subject: New Model IV |
Lynn,
I did exactly the same thing, but with 1" red nylon webbing. I worried at
times if it would be hard to get out of in the event of a crash and fire.
It is interesting that in our hard landing, the nylon just came apart. What
I mean is the webbing shredded.
Lowell
kerrjohna(at)comcast.net Guest
Posted: Mon Jun 23, 2008 7:49 am Post subject: New Model IV |
Lowell, they world is back on its proper axis with you building again.
A comment on the shoulder straps: Tired of having them slip off my shoulders, I swapped the ends so that they cross behind me. There is no "scissor" action as the angle is only slightly greater than if centered behind the seats.
John Kerr
[quote]-------------- Original message --------------
[quote] --> Kitfox-List message posted by: "Lowell Fitt"
more accessable.
Lowell
Lynn Matteson
Posted: Mon Jun 23, 2008 11:49 am Post subject: New Model IV |
John-
That's a good idea...I'll have to look and see if I can still do that
move now that the plane is covered. I recall that one of the belts is
pretty hard to access with covering on, but I think that was the lap
belt on the outside of the plane.
Lowell-
Shredded? Wow, that must have been some hit. Did you sew the red
webbing, or velcro it? With the velcro, it should have just popped
the velcro loose, I would think.
The more I think about how I did mine, the less sure I am about the
safety issue....I might just get turned sideways and slip through the
shoulder harness and get up close and personal with the panel....time
to revisit this situation, I think.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/538 hrs
worried at times if it would be hard to get out of in the event of a
crash and fire. It is interesting that in our hard landing, the nylon
just came apart. What I mean is the webbing shredded.
On Jun 23, 2008, at 11:46 AM, kerrjohna(at)comcast.net wrote:
Quote: | Lowell, they world is back on its proper axis with you building again.
John Kerr
N369LM |
Posted: Mon Jun 23, 2008 1:27 pm Post subject: New Model IV |
Lynn,
The strap had velcro on each end with a small "D" ring for grabbing in an
emergency. Picture of what was left attached. Yes it was a hit.
Lowell
Description: |
Filesize: |
46.66 KB |
Viewed: |
510 Time(s) |
patreilly43(at)hotmail.co Guest
Posted: Mon Jun 23, 2008 2:28 pm Post subject: New Model IV |
Lowell, I'm fairly new to this list. But, I will also say welcome back. By the looks of the gear you built, you are an irreplaceable asset to a site like this. You say your building again. I tell people I will be trying to get out of the coffin to build something, anything. Do you happen to have blueprints of the gear you built? Even rough skeches with dimensions and material sizes?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Quote: | From: lcfitt(at)sbcglobal.net
Subject: New Model IV
Date: Sat, 21 Jun 2008 12:33:44 -0700
To the list:
gear attached.
Lowell Fitt
Posted: Mon Jun 23, 2008 5:49 pm Post subject: New Model IV |
Pat,
I would be happy to help. I have a meeting to go to tonight and can give
some dimensions tomorrow. I'll tell give you a brief discription how I did
it. A friend gave me some basic measurements - height above the ground -
forward end of the forward mounting boltto the ground and the and track. I
then fixed the fuselage on a sawhorse level at that height and secured it.
I removed the tires and using the bare axles, I dropped a plumb line and
marked the floor exactly below the ends of the old tube gear. A line was
drawn through those line to give a fix on the wheel contact line in a fore
and aft direction. Then a plumb line down from the center of the fuselage
to give a center point on the wheel contact line. The total track was then
marked on that line to give the relative position of the ends of the axles.
I then used two lengths of 1X1X1/8" angle extending beyond the widest marks
on the line and welded a length of angle between them about 10" long. I now
had two parallel rails that were fixed to the floor with bondo with the line
between them. The plan is to use the rails to make fixtures on trollys that
fix the angle and location of the axles. Of angle iron and wood, I made
spacers about 1.3" high that rode on the rails essentially extending the
rail height that 1/3 inch. Then using tubing that exactly fit over the
axles, I welded up fixtures of angle iron that rode on the spacers to fix
the angle and location of the axle.
After the fixtures were finished. I removed the old landing gear, tapped out
the axles and using the fixtures without the spacers and mounted at the
appropriate distance on the rails positioned the axles at the desired
location for the new landing gear. The rest amounted to using the axles
mounted to the fixtures on the rails and the fuselage as a jig and cutting
and welding everything in place. Of course tack welding and then removing
to bench top height made the welding easier. I found that starting at the
axle and then working to the pivot points on the tops of the legs gave a
more accureate reslult given the warpage typical with welding.
The cabane strut was made pretty much the same way. I will send some detail
photos. For the spring strut, I used 3/4" .049 tubing and it wasn't until
after finishing the struts that I learned that the spring strut made for my
friend was 7/8 .049 tubing. These struts are commercially made and are
designed for airplanes heavier than the Model IV. I will stick with what I
have, but may go to the larger tubing if I make another set. The springs
themselves are available from Aircraft Spruce in their catalog. They are
heavy puppies and cost abour $90 per set.
I'll take a couple of photos of the jigs and track and send them also. Also
when welding up the final gear legs, I drilled and tapped holes in the jigs
through and into the tracks and placed bolts in them so nothing would move.
Questions - just ask. I doubt all this makes sense at first.
Lowell
