jbowerman(at)fastspot.net Guest
Posted: Thu Jun 19, 2008 8:44 am Post subject: Timing |
I have installed a new left magneto on my Yak52 and tried to time it to the Right mag. It is about 5 degrees off and I have no more adjustment on the studs. The aircraft seemed to be running fine on the right mag, so the assumption was that it was timed correctly.
One other item, I know where the timing marks are on the prop hub, but don’t know where the marks are on the engine. Can anyone help me with the location of the timing mark on the engine case?
Thanks in advance,
Jim Bowerman N52YA
petervs(at)knology.net Guest
Posted: Thu Jun 19, 2008 10:01 am Post subject: Timing |
Just find TDC on Cylinder 1 and make a pointer that you can attach to the gills to point to the O degree mark on the prop hub.
Pete
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Jim Bowerman
Sent: Thursday, June 19, 2008 11:42 AM
To: yak-list(at)matronics.com
Subject: Timing
Thanks in advance,
Jim Bowerman N52YA | Quote: | | http://www.matronics.com/Navigator?Yak-List | 0123456789
Posted: Thu Jun 19, 2008 12:26 pm Post subject: Timing |
Jim,
Timing a new magneto can be somewhat of a challenge. If you have a copy of the M14 maintenance manual, it is highly recommended you go through the installation procedure for a new magneto which is on page 205, Task Card 202. Trying to explain this on the yak list is difficult to say the least. Basically though, there are 3 timings that you must go through; raw, course and fine.
Raw timing - setting the coupling on the bottom of the magneto to the correct position prior to installing the magneto.
Course timing - adjustment of the magneto by rotating the magneto in the slotted holes.
Fine timing - adjustment of the plate to which the points are mounted by the eccentric screw on the opposite side of the points.
It is important that you following the procedure in the manual starting with the setting of the coupling. Otherwise you will be chasing your tail for a very long time.
Using a magneto synchronizer/timing box and after you have the mags firing fairly close to each other, you can tweak the timing or synchronize the mags using the concentric adjustment screw on the opposite side of the points. You must loosen the large slotted screws on the sides of the plate first. Do not loosen the small slotted screws as these are loosened to adjust the point gap. (.25 to .35 mm or .010 to .014). Point gap will also affect the timing position. But the most important thing to do is to set the coupling on the bottom of the mag as instructed in Task Card 202.
Dennis
Posted: Thu Jun 19, 2008 12:30 pm Post subject: Timing |
That's correct Peter, but ONLY if the magneto has been properly timed BEFORE installing it. ie: setting the coupling on the bottom of the mag to the correct position as stated in the M14P manual, pg 205 Task Card 202.
Dennis
Posted: Thu Jun 19, 2008 12:36 pm Post subject: Timing |
BTW, you don't time the mags to cylinder #1. They are timed to cylinder #4.
Dennis
Posted: Thu Jun 19, 2008 12:44 pm Post subject: Timing |
Jim, there are many adjustment points on these MAGS.
Remove the MAG from the engine. Look on the bottom of the MAG for the
coupling. This coupling is really slick. You will notice that if you
loosen one bolt that holds it on, you can turn the OTHER bolt and it
will move the whole coupling on the MAG shaft. Look carefully at this
thing, it is an ADJUSTABLE MECHANISM! Since you already know which
direction you need to go on the screw slots to get the 5 degrees more
that you need, you should be able to look at that coupling shaft and
adjust it in the correct direction. Be careful, a small adjustment goes
a long way. You can then put the mag back onto the engine, and try to
sync the darn thing. By a lot of trial and error, you can even end up
getting it synced with the screw slot holes for the mag itself "in the
middle" per se. Lastly, there is a fine tuning screw opposite of the
points themselves. This is one of those "egg shaped" deals that as you
turn it, it moves the assembly. I think it is actually moving the
breaker plate for the points. This is kind of the way that a vacuum
advance breaker plate advances the timing on a automobile distributor.
ANYWAY... With that knowledge, and a lot of time and patience you can
get from to your goal. It's not a lot of fun, but it is a worthwhile
learning experience.
Mark Bitterlich
Posted: Thu Jun 19, 2008 12:45 pm Post subject: Timing |
I can't believe we were typing an answer to this at the same time
Dennis. Sheesh. Your answer was better than mine.
Mark
Posted: Thu Jun 19, 2008 1:28 pm Post subject: Timing |
Absolutely!
Peter
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Thursday, June 19, 2008 3:25 PM
Subject: Re: Timing
Dennis
----- Original Message -----
From: Peter K. Van Staagen (petervs(at)knology.net)
Sent: Thursday, June 19, 2008 12:53 PM
Subject: RE: Timing
Pete
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Jim Bowerman
Subject: Timing
Thanks in advance,
Jim Bowerman N52YA | Quote: | | http://www.matronics.com/Navigator?Yak-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-Listhref="http://forums.matronics.com">http://forums.matronics.com | 0 | 123456789 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 0 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 1 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 2 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 3 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 4 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 5 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 6 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 7 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 8 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 9 | Quote: | | http://forums.matronics.com | 0
Posted: Thu Jun 19, 2008 1:34 pm Post subject: Timing |
DOH! You are so right, my bad.
Guess I should keep my mouth shut!
Pete
Sent: Thursday, June 19, 2008 3:34 PM
Subject: Re: Timing
Dennis
From: A. Dennis Savarese (dsavarese0812(at)bellsouth.net)
Subject: Re: Timing
Dennis
Subject: RE: Timing
Pete
Subject: Timing
Thanks in advance,
Jim Bowerman N52YA | Quote: | | http://www.matronics.com/Navigator?Yak-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Yak-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | | 01234 | 56789 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 0 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 1 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 2 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 3 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 4 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 5 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 6 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 7 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 8 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 9 | Quote: | | http://forums.matronics.com | 0 | Quote: | | http://forums.matronics.com | 1 | Quote: | | http://forums.matronics.com | 2 | Quote: | | http://forums.matronics.com | 3 | Quote: | | http://forums.matronics.com | 4
