dpersyk(at)worldnet.att.n Guest
Posted: Thu Jun 12, 2008 8:45 am Post subject: Lycoming carb question |
Hi Kim,
Flight instruments aside, does the engine behave like it is too lean when
the mixture knob is in at cruise less than 75% power? That is, if you
slowly lean, does the EGT decrease?
If you are in fact flying lean of peak, the exhaust temps will be less than
peak because the cooling is coming from excess air instead of excess fuel.
I guess I don't understand your "high EGT" temps if your readings are at
cruise configuration. All the EGT instruments I'm familiar with indicate
relative temps.
I'm not saying you don't have a lean carb problem - just curious if the
simpler determination of mixture gives the same indication.
Good landings,
Dennis
N600DP 6a sold http://home.att.net/~dpersyk/rv6a.htm
I have an 0-320 E2D in my RV9A and have fighting high CHT's. The engine
monitors suggest that the engine is running too lean, therefore
contributing
to
the high CHT and exhaust temps. I learned yesterday that lycoming
apparently makes 2 different carbs for this engine. One runs
leaner/richer than
the
other. One of the guys in my EAA chapter said that he had the same
problem
with his 0-320 until he changed to a richer running carb and now has no
problems.
Can anyone tell me which carb for the 0-320 is the one that runs rich?
Thank you.
Kim Nicholas
RV9A
Auburn, WA
Knicholas2(at)aol.com Guest
Posted: Thu Jun 12, 2008 2:26 pm Post subject: Lycoming carb question |
Thanks for the interest. Yes, everything points to a lean running engine. Another RV-lister sent me information that it is common for the 10-5009 carbs to run lean. He is send me a new carb jet (apparently there was a Lycoming service bullitin about it) to make it run more rich. I will post my results on the list.
Kim Nicholas
In a message dated 6/12/2008 9:48:35 A.M. Pacific Daylight Time, dpersyk(at)worldnet.att.net writes:
| Quote: | --> RV-List message posted by: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Hi Kim,
relative temps.
Good landings,
Dennis
contributing
to
leaner/richer than
the
problem
problems.
Thank you.
Kim Nicholas
RV9A
Auburn, es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ; =========================
Vote for your city's best dining and nightlife. City's Best 2008.
