rockyjs
Posted: Fri May 30, 2008 7:52 pm Post subject: Testing SD-8 Circuit |
I searched, but could not find the answer. I'm all wired and ready to close the open access that I have to all my SD-8 circuit wiring. I'm following Z-13 and would really like to test this standby alternator circuit before it becomes difficult to repair, replace or modify. Is there anything wrong with me hooking up a battery on a small charger into the leads that are normally fed from the SD-8 regulator to test the relay and associated wiring? I believe the battery on a charger would act like the SD-8/regulator combination. Or is there another way to accomplish this task that I'm overlooking?
Rocky
nuckolls.bob(at)cox.net Guest
Posted: Wed Jun 04, 2008 5:55 am Post subject: Testing SD-8 Circuit |
Rocky
Hmmmm . . . this system is exceedingly simple.
If you are confident of your wiring, then it will
work as advertised. "Chargers" used to be coarse
substitutes for power supplies but recent shifts
to include battery charging and maintaining
electronics make their performance as power
supplies uncertain.
A electronics-bench power supply would be a sure
bet . . . but I'm not convinced that it's a good
use of your $time$.
( -Thomas Paine 1776- )
rockyjs
Posted: Wed Jun 04, 2008 7:05 pm Post subject: Re: Testing SD-8 Circuit |
Thanks Bob,
I think I'll just close it up.
