yenduc(at)sbcglobal.net Guest
Posted: Sun Jun 01, 2008 9:25 pm Post subject: cowling filler |
I want to fill the texture "pin holes" in my cowl before mounting the cam locs to the firewall edges of the cowl. I tried Evercoat Feather Fill primer and Evercoat Metal Glaze and was disappointed with the results -- got nearly as many "pin holes" as before I made the applications. I'm thinking of trying micro balloons next. What has worked best for you guys out there????
dave
Vanremog(at)aol.com Guest
Posted: Sun Jun 01, 2008 9:43 pm Post subject: cowling filler |
In a message dated 6/1/2008 10:26:50 P.M. Pacific Daylight Time, yenduc(at)sbcglobal.net writes:
| Quote: | | I want to fill the texture "pin holes" in my cowl before mounting the cam locs to the firewall edges of the cowl. I tried Evercoat Feather Fill primer and Evercoat Metal Glaze and was disappointed with the results -- got nearly as many "pin holes" as before I made the applications. I'm thinking of trying micro balloons next. What has worked best for you guys out there???? |
Make small batches of a loose slurry of (insert favorite epoxy compound here) and microballoons and use a plastic spreader to work it into the offending surfaces. You really want to fill the holes so use a good scrub to get it into, not on the surfaces. Then sand and prime. I used light coats of DuPont Uro primer block sanded in between.
-GV
Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food.
Deems Davis
Posted: Sun Jun 01, 2008 9:45 pm Post subject: cowling filler |
It's not so much what you use but how you apply it. Get an old credit
card or reasonable fact similie, brush or roll on your filler, to a
relatively small area (say 10" x 10" ). it doesnt' have to be a lot of
filler as this step is only going to ofill the pinholes & voids. Then
use the credit card to squeegee the surface with the filler (Metal glaze
will probably set up too fast for this application) . In my experience
Poly Fiber UV smooth Prime works wonderfully and 'dries' within minutes
and is water based. This will fill 99.9% of the pinholes in the 1st
application, and then you can proceed to prime the part/s as desired.
Others have used a razor blade instead of the credit cards, and some use
an epoxy mix as a filler.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
David Cudney wrote:
| Quote: | I want to fill the texture "pin holes" in my cowl before mounting the
dave
n320wt(at)yahoo.com Guest
Posted: Mon Jun 02, 2008 3:07 am Post subject: cowling filler |
Dave, I do composite fabrication for a living mostly on Lancairs. I've been using a product called Wonder-fil from Loehle Aero Coatings. It is applied with a paper towel, allowed to dry and then wipe the excess residue away. This leaves the pin holes and porosity completly filled. Spray urethane primer and the Wonder-fil will wick solvents from the urethane and fully bond. It is compatiable with any urethane paint system on the market but I've found Loehles paints to be superior to anything else I've tried and now its the only system I'll use. See www.loehle.com
BRIAN ALLEY (N320WT)
CARBON FIBER COMPOSITES
101 Caroline Circle
Hurricane, WV 25526
www.carbonfibercomposites.net
304-562-6800 home
304-395-4932 cell
How are you going to win by a nose if you don't stick out your neck?
--- On Mon, 6/2/08, David Cudney <yenduc(at)sbcglobal.net> wrote:
| Quote: | From: David Cudney <yenduc(at)sbcglobal.net>
Subject: Re: cowling filler
To: rv-list(at)matronics.com
Date: Monday, June 2, 2008, 1:21 AM
dave
| [quote][b]
Posted: Mon Jun 02, 2008 2:02 pm Post subject: Cowling Filler |
Walt and Deems:
What did you guys use after filled the Smooth Prime? Did you use a
primer and if so what kind? Have you finish painted the cowl? And if
so what did you use? What I'm getting at is were there any
compatibility problems? I was hoping to use a two part polyurethane or
polyester primer and then fly the plane for a year or so before having
it professionally painted. I don't want any compatibility problems
down the line -- so far Smooth Prime sounds like the answer for me.
Clearly heavy spraying with Feather Fill did not work. I'm hoping to
avoid hours of mixing small batches of filler and scraping it in with
a credit card, blade, or squeegee --- will the credit cards still work
after such abuse?
Thanks for your help
dave
On Jun 2, 2008, at 5:07 AM, rveighta wrote:
Dave, like one of the other guys, I used water based "Smooth Prime"
on my RV-8 cowl. I just rolled it on then sanded it down. Most of
the smooth prime is sanded off, but the pinholes are filled in. I
wouldn't use anything but this stuff in the future. Easy to use,
easy to clean up.
Walt Shipley
Deems Davis
Posted: Mon Jun 02, 2008 3:01 pm Post subject: Cowling Filler |
David, I've used Smooth Prime on all of my fiberglass parts as the
primer (after filling the pin holes).
http://deemsrv10.com/album/Sec%2047%20Spinner%20and%20Cowling/slides/DSC04322.html
I haven't painted the cowl yet, supposedly the painter is going to pick
up the project Jul 1 for paint, then final assembly and.........
(The credit card trick really doesn't take that long, when used w/
smoothprime and it insures that the pinholes are filled) . the credit
cards will definately NOT work after use so just send them to me and I
will 'dispose' of them "appropriately" O
Deems Davis # 406
David Cudney wrote:
Walt and Deems:
after such abuse?
dave
> on my RV-8 cowl. I just rolled it on then sanded it down. Most of the
> wouldn't use anything but this stuff in the future. Easy to use, easy
> to clean up.
> Walt Shipley
sarg314(at)comcast.net Guest
Posted: Mon Jun 02, 2008 9:48 pm Post subject: cowling filler |
I've had mixed results with UV smooth prime. Often it cures with tiny
bubbles in it or has just too much texture. By the time you sand all
the texture out, it's all gone. It worked well on my spinner but it
seemed like it was an awful lot of work. Recently I seemed to get
better results thinning it slightly - about 5% - with water. That may
suppress the bubbles and texturing a bit.
Polyfiber advised using a foam roller (their preferred method
apparently) with the smallest foam cell size possible. I think that did
help. It seems I have to put on about 6 very thin coats, then sand 95%
of it away. Yes, 6. That's what they told me. I do 3, sand it a bit
and then 3 more. And you must let it sit for a couple weeks before
painting to let the water get out of it.
Does any one have any advice on using this stuff? Am I doing it wrong?
Polyfiber doesn't seem to have all the recommended procedures in one
place. Some is on the can, some on their website and some you get by
calling up and asking. Frustrating. But I guess that's fiberglass for
you. It's expensive too.
Tom S. - RV-6A
stuck in fiberglass hell.
Posted: Tue Jun 03, 2008 6:35 am Post subject: cowling filler |
Tom:
I called and got similar advice on the roller application. How long
did you let it dry between roller applications to get your three plus
three coats? I plan to let it dry for a couple of weeks after the
last sanding before I apply a seal coat of either epoxy or
polyurethane top primer. They stressed that it is necessary to put on
a top coat of a primer that requires a catalyst particularly if you
plan to fly the plane for a while before painting.
Thanks to all of you for your help
dave
On Jun 2, 2008, at 10:43 PM, tom sargent wrote:
tiny bubbles in it or has just too much texture. By the time you
sand all the texture out, it's all gone. It worked well on my
spinner but it seemed like it was an awful lot of work. Recently I
seemed to get better results thinning it slightly - about 5% - with
water. That may suppress the bubbles and texturing a bit.
did help. It seems I have to put on about 6 very thin coats, then
sand 95% of it away. Yes, 6. That's what they told me. I do 3,
sand it a bit and then 3 more. And you must let it sit for a couple
weeks before painting to let the water get out of it.
wrong? Polyfiber doesn't seem to have all the recommended
procedures in one place. Some is on the can, some on their website
and some you get by calling up and asking. Frustrating. But I
guess that's fiberglass for you. It's expensive too.
Tom S. - RV-6A
Posted: Tue Jun 03, 2008 8:03 pm Post subject: cowling filler |
David:
Not very long at all. 10 minutes seems to do it. On the spinner, I
think I put on the 3 coats one night and the other 3 the next night.
David Cudney wrote:
Tom:
I called and got similar advice on the roller application. How long did
you let it dry between roller applications to get your three plus three
coats? I plan to let it dry for a couple of weeks after the last
sanding before I apply a seal coat of either epoxy or polyurethane top
primer. They stressed that it is necessary to put on a top coat of a
primer that requires a catalyst particularly if you plan to fly the
dave
Posted: Tue Jun 03, 2008 8:21 pm Post subject: cowling filler |
I should add that I live in southern arizona, so it's hot and super dry
here (5% humidity yesterday) so things dry out fast.
tom sargent wrote:
David:
David Cudney wrote:
> Tom:
