Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Tue Jun 03, 2008 11:49 am Post subject: 914 Coolant temperature sensor |
Hello,
I am at the stage of installing a coolant temperature sensor and
wiring to the coolant system on my Europa 914.
I am sure there are better sites onto which to install the sensor,
but I was hoping to get agreement from similar owners to fit it on the
downward coolant line running back from the reservoir on top to the radiator
directly below. I have not read the specific instructions as yet, but am
fearful of disturbing a complex area immediately behind the reservoir
because of its tight component population.
Is it workable to take temps from the vertical coolant line?
Ferg
Europa A064
rlborger(at)mac.com Guest
Posted: Tue Jun 03, 2008 12:16 pm Post subject: 914 Coolant temperature sensor |
Ferg,
Check my build website at Europa Owners. Go to Year #7, Q1 2008, page 1 for pics and words on the installation of my coolant temperature sensor. I believe that this is where the factory recommends installing the sensor. I'm sure that anywhere along the line from the coolant manifold down to the radiator will do if you prefer not to disassemble all the plumbing and other assorted hardware on the upper aft of the engine. Do remember that you may have to work on this thing again at some point in the future. Back behind the engine on the vertical line may be a difficult location to access.
Good building and great flying,
Bob Borger
http://www.europaowners.org/N914XL
On Tuesday, June 03, 2008, at 02:54PM, "Fergus Kyle" <VE3LVO(at)rac.ca> wrote:
Hello,
Ferg
Europa A064
Posted: Tue Jun 03, 2008 8:53 pm Post subject: 914 Coolant temperature sensor |
Hi! Ferg
The sensor MUST be at the hottest common point in the system and this
must be just after the header tank (which receives the coolant from each
cylinder head on top of the engine) and before the radiator intake.
Which I think is the same place that you are proposing.
Bob Harrison G-PTAG
