Posted: Mon Jun 02, 2008 8:32 am Post subject: heat transfer compound |
Do you have to use a heat transfer compound on plugs in a 447?
Bill Sullivan
Kolb Firestar/447
Windsor Locks, Ct.
Roger Lee
Posted: Mon Jun 02, 2008 11:35 am Post subject: Re: heat transfer compound |
The 2 strokes do not get any paste, lube or anti-seize at all. They are supposed to be a dry thread and torqued because the heads on the 2 strokes are softer aluminum (different materials than the 4 strokes) and can be damaged with improper torque. This can happen whether they are dry if you use to much torque, but more susceptible if lubricated.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
imap8ntr(at)cox.net Guest
Posted: Mon Jun 02, 2008 12:42 pm Post subject: heat transfer compound |
Roger
On my 582 the US Dealer/Distributor had me put antiseize on the sparkplugs
(silver colored antiseize.)
Ivan
Roger Lee
Posted: Mon Jun 02, 2008 3:54 pm Post subject: Re: heat transfer compound |
Hi Ivan,
I went back through all the 2 stroke manuals and it doesn't say anything about the use of anti-seize on 2 stroke plugs, but it is taught not to use anything on 2 stroke threads in the Rotax classes. If the manual doesn't say use it there must be a reason for it.
It does say to torque them on a cold engine only. Remember the heads are aluminum and the plug threads are steel. No gorilla arms when tightening plugs.
The maint. manual says to torque the plugs on a cold engine to 238 in/lbs or 19.8 ft/lbs. page 11-4 sec. 11.8
The installation manual says to torque the plugs with a CHT sensor ring in place to 133 in/lbs. or 11 ft/lbs pg 20-1 fig. 49
This is quite a difference. Might help to call Lockwood for a clarification.
Tucson, Az.
Cell 520-349-7056 |
Posted: Mon Jun 02, 2008 4:32 pm Post subject: heat transfer compound |
Thanks for the info. Kemmeries Aviation, the US importer for Air Creation
Trikes which all come with Rotax engines, gave me this info. I will double
check it this month.
Ivan
Float Flyr
Posted: Mon Jun 02, 2008 4:46 pm Post subject: heat transfer compound |
I've been criticized for this before but I always torque the plugs on my 582 to 220 in.lb. intentionally. I tend to check my plugs quite often (5-10hr) and have never had a problem with the lower torque. I do check my torque wrench annually for calibration at that torque. I also never use anything on the threads of my plugs except a soft clean cloth. Whenever I remove all the plugs I will put a clean shop towel over the plug openings to keep any grit from getting into the combustion chambers.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Roger Lee
Posted: Tue Jun 03, 2008 11:52 am Post subject: Re: heat transfer compound |
Hi Noel,
I don't see any thing to criticize. You torque the plugs within 1 ft/lb. Not a big deal since many don't torque them at all.
Tucson, Az.
Cell 520-349-7056 |
Float Flyr
Posted: Tue Jun 03, 2008 4:31 pm Post subject: heat transfer compound |
I'm a bit anal about torque and using a calibrated wrench. I have been
criticized for doing the lower torque but I do it for two reasons. 1. I
pull my plugs a lot... I never really trust the EGTs to do more than give me
a trend. Plugs will always tell the whole story. 2. I feel the 20 in. Lb.
will create less stretching of the heads. I've been torquing plugs into
outboard engines, snowmobiles etc.. for more years than I like to think
about and I've yet to strip a thread.. I've also yet to lose a plug from
having it too loose.
The important thing is consistency. You can only get that if you use a
torque wrench or for the real small stuff a torque meter.
Thanks for the reply Roger
Noel
Kitfox III-A
