Dennis Jones
Joined: 17 Sep 2006 Posts: 45 Location: Poplar Grove, IL
Posted: Sun Jun 01, 2008 9:50 pm Post subject: Batteries |
O.K. how about this. Interstate has a wide selection. For example FAYTX20 18AH 270CCA 11 lbs. $104.95 or the other end FAYTX24HL 21AH 350CCA 14 lbs. $132.95. Unless Interstate batteries are junk these batt. numbers smoke an Odyssey. That's a 20% increase in AH and over 50% increase in CCA for the same weight and approximately the same price. Or have a little more power and save over 25% in weight plus your pocket book. There about the same size overall compared with each other and the other types including the Odyssey. And they are AGM type. Drive across town buy the thing and if you have problems you go back and talk to them in person. No internet return headaches.
Jonsey
Sam
Posted: Mon Jun 02, 2008 3:34 am Post subject: Batteries |
I believe Bob would say to do the tests and gather the data.
Sam
On Mon, Jun 2, 2008 at 12:42 AM, Dennis Jones <djones(at)northboone.net (djones(at)northboone.net)> wrote:
[quote] O.K. how about this. Interstate has a wide selection. For example FAYTX20 18AH 270CCA 11 lbs. $104.95 or the other end FAYTX24HL 21AH 350CCA 14 lbs. $132.95. Unless Interstate batteries are junk these batt. numbers smoke an Odyssey. That's a 20% increase in AH and over 50% increase in CCA for the same weight and approximately the same price. Or have a little more power and save over 25% in weight plus your pocket book. There about the same size overall compared with each other and the other types including the Odyssey. And they are AGM type. Drive across town buy the thing and if you have problems you go back and talk to them in person. No internet return headaches.
Jonsey
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
simon(at)synchronousdesig Guest
Posted: Mon Jun 02, 2008 5:26 am Post subject: Batteries |
And report findings back to the group. This will take several years if
the batteries are worth their weight in lead. It's worth it, though,
because we need new known good vendors of these new technology AGM
batteries.
Interstate used to be my vendor of choice for car batteries long ago when
they had superior batteries. Then they started carrying Optima batteries,
which were six gell cells wrapped in cylindrical fashion. They were
military technology fresh out to the civilian world. I've had them in two
of my three cars for about five years now with no problems until last
month. One of them gave out, so I replaced it with an Odyssey flat plate
AGM cell. Although many have great success with the PC-680 and PC-925L
for years, I'm using a different Odyssey battery (automotive) for this
application, but it uses the same technology - flat plate instead of
circular plate like the Optima uses. I am hoping it delivers the
advertised 8-10 years instead of the 5 years Optima delivered.
Simon in Florida
Quote: | I believe Bob would say to do the tests and gather the data.
Sam
On Mon, Jun 2, 2008 at 12:42 AM, Dennis Jones <djones(at)northboone.net>
> Jonsey
echristley(at)nc.rr.com Guest
Posted: Mon Jun 02, 2008 8:37 am Post subject: Batteries |
Dennis Jones wrote:
Quote: | O.K. how about this. Interstate has a wide selection. For example FAYTX20 18AH 270CCA 11 lbs. $104.95 or the other end FAYTX24HL 21AH 350CCA 14 lbs. $132.95. Unless Interstate batteries are junk these batt. numbers smoke an Odyssey. That's a 20% increase in AH and over 50% increase in CCA for the same weight and approximately the same price. Or have a little more power and save over 25% in weight plus your pocket book. There about the same size overall compared with each other and the other types including the Odyssey. And they are AGM type. Drive across town buy the thing and if you have problems you go back and talk to them in person. No internet return headaches.
Jonsey
Some simple physics here. There are very few tricks in building a
lead-acid battery. You don't get more AH or CCA for free. About the
only way to increase either value without increasing the battery size is
to somehow get more contact area between the lead and the acid. The
only way to accomplish that is to squeeze both the lead plate and the
mat between them thinner. CCA can theoretically be negatively effected
if the lead gets to thin, but that won't realistically ever happen in a
battery robust enough to be marketable. Unless Interstate has some
packaging techniques that support and protect the lead in their
batteries, they will necessarily be less robust.
Personally, I would buy the Interstate, mount it to the airplane with
shock absorbing materials (sit it on a rubber mat?), and expect to
change it every two years.
mkimball(at)gci.net Guest
Posted: Mon Jun 02, 2008 10:03 am Post subject: Batteries |
FWIW I am a big fan of my 925 Odyssey. Small in size and a really cool
custom tray for it to sit in. Sits way in back of my Super Rebel and spins
my 10:1 Chevy 350 with no problem even after months of sitting without
receiving a charge. It's about 4, maybe 5 years old now. No sign of
degradation.
Mike
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Mon Jun 02, 2008 6:03 pm Post subject: Batteries |
Quote: | Quote: | I believe Bob would say to do the tests and gather the data. |
Seems every time the battery issue pops up I listen to the agonizing over the issue and offer this solution that has worked quite nicely on my RV for almost five years, currently about $80 bux/pop:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P231-ND
Sad part is that the first one I bought was maybe $45...
>From The PossumWorks in TN,
Mark
_________________ From The PossumWorks... |
bbradburry(at)bellsouth.n Guest
Posted: Mon Jun 02, 2008 7:47 pm Post subject: Batteries |
This is the battery that I am using.. I plan to replace one of them each year, so max age will be two years.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=522-1014-ND
Sadly, the first battery I bought was about $25, the second about $35, and now they are $55!
Bill B
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of fiveonepw(at)aol.com
Sent: Monday, June 02, 2008 9:59 PM
Subject: Re: AeroElectric-List: Batteries
Mark
-----Original Message-----
Sent: Mon, 2 Jun 2008 8:26 am
Subject: Re: Batteries Quote: | --> AeroElectric-List message posted by: simon(at)synchronousdesign.com (simon(at)synchronousdesign.com)
batteries.
Simon in Florida
> Sam
>> Jonsey
Stay informed, get connected and more http://www.matronics.com/Navigator?AeroElectric-List --> http://forums.matronics.com -Matt href="http://www.matronics.com/contribution">http://www.matronics.com/c===========
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Tue Jun 03, 2008 4:14 am Post subject: Batteries |
Mark,
Do you know if this battery will fit inside the PC-680 battery box?
Bret Smith
RV-9A "Canopy"
Blue Ridge, GA
www.FlightInnovations.com
_________________ Bret Smith
RV-9A (Emp) |
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Tue Jun 03, 2008 11:07 am Post subject: Batteries |
Not all of them will fit without some modification to the battery box. The Odyssey PC-680 corners (and the box) have a big radius on the corners and the other brands have much sharper corners. Consequently they don't fit even though width and depth are the same. I cut the back out of the box Van's provides and riveted the brackets on leaving a little extra depth. If I ever put an Odyssey in it I can use some rubber baffle material as a shim.
Greg Young
[quote] From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bret Smith
Sent: Tuesday, June 03, 2008 7:05 AM
Mark,
Bret Smith
RV-9A "Canopy"
Blue Ridge, GA
Mark Phillips in TN
Posted: Tue Jun 03, 2008 6:13 pm Post subject: Batteries |
Quote: | Do you know if this battery will fit inside the PC-680 battery box? | >>>
Here's the datasheet from Digikey for the Panasonic:
http://www.panasonic.com/industrial/battery/oem/images/pdf/Panasonic_VRLA_LC-X1220P_LC_X1220AP.pdfhttp://www.odysseybatteries.com/battery/pc680.htm
..and for the PC680 from West Coast Batteries:
I found this battery is available from Summit Racing for $120, but didn't do an extensive price search.
Main difference I see is the 680 has 6mm threaded holes in the top for connection with bolts, the Panasonic has lead lugs for connection with 5mm bolts (supplied with battery). I doubt there is a hillabeans difference in their internal construction or performance. Other than the extra 3Ah the Panasonic claims. I've used the Panasonic exclusively in my plane (O-320, 150 hp) and also the recent IO-360 I helped with, and it has performed very well in both cases. The Jabirus I am now working on use Odyssey batteries, but I'm trying to educate them...
Looks like they are about the same size. I also measured the box included with Van's FWF kit for the recent project (which I did not use) and it appears either will fit in the box.
Mark
Sent: Tue, 3 Jun 2008 7:04 am
Mark,
Bret Smith
RV-9A "Canopy"
Blue Ridge, GA
Mark Phillips in TN
nuckolls.bob(at)cox.net Guest
Posted: Wed Jun 04, 2008 7:59 am Post subject: Batteries |
headaches.
Jonsey
When selecting a battery, consider life-cycle costs
of ownership. Assuming one subscribes to the idea that
a battery needs to be a KNOWN quantity of stored energy
for the purpose of supporting a KNOWN e-bus load for
a KNOWN period of time, how do you plan to verify
the battery's suitability for continued airworthiness?
Cost of ownership includes $time$ expended in original
purchase, tools to test, $time$ expended in supporting
those tests. If you purchase a premium battery then there's
a certain amount of pressure to expended still more $time$
testing so as to squeeze the last bit of value before
removing the battery from service.
Alternatively, consider using the lowest cost battery
you can find and simply replace it periodically.
Batteries like this:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P174-ND
have performed well in OBAM aircraft. If you replace
the battery when it's CAPACITY falls below your KNOWN
e-bus operating limits, then it's still quite capable of
cranking an engine. Therefore, issues like cold cranking
amps are very low priority for selecting a battery.
If you're a fair-weather, VFR pilot and you carry
dark-panel backup equipment . . .
http://aeroelectric.com/Pictures/Misc/Vacination_for_Dark_Panel_Syndrom.pdf
. . . then you can run a battery until it simply doesn't
crank the engine any more. In this case, you MIGHT
be able to get more $value$ out of a premium battery.
There are many operating variables that drive
battery service life. It's exceedingly difficult to
quantify return on investment for one style of battery
over another. If it were my airplane, I'd
put in the least expensive battery I can find. Run
a real-time, e-bus endurance test at one year and every
six months thereafter. Replace the battery when
e-bus support drops below 2 hours (or what ever
number you've selected for your modus-operandi).
( -Thomas Paine 1776- )
Mark Phillips in TN
Posted: Wed Jun 04, 2008 8:05 pm Post subject: Batteries |
Update- I tried to stuff a Panasonic LC-X1220P (same dimensions for the
17Ah version) into the Van's PC-680 box (supplied with FWF kit) and it
is a no-go. Appears this battery is just slightly too big for the box-
a one-sixteenth shave in length would be enough to make it fit. Not
the reason I opted to make a "box" of my own design, but if using Van's
kit, the PC-680 looks like a better fit.
Oh well...
Mark
