mikedoble(at)wi.rr.com Guest
Posted: Fri May 23, 2008 1:02 pm Post subject: Elevators |
Please help. I’ve attached the elevators to the horiz stab and adjusted to have a roughly even gap at the trailing edge of the stab. Height wise though there is a 3/16” difference between the left and right elevator horns. Anyone else have this issue? Is there a fix or is this a common misalignment? Just drill away and live with the difference?
Thanks in advance.
Mike Doble
Builder 40691
Working on my tail.....
Waukesha, Wisconsin
Posted: Fri May 23, 2008 1:24 pm Post subject: Elevators |
In my experience it is not at all uncommon to have the horns not exactly lined up. I think it's just an issue of the welds and lack of accuracy there. I have seen some that line up almost perfectly and some that are off by as much as 10 degrees, probably. Is this what you are referring to?
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
dogsbark(at)comcast.net Guest
Posted: Fri May 23, 2008 1:54 pm Post subject: Elevators |
Mike,
I believe in Section 11-3, it specifically refers to the horns not being aligned and has you go through a procedure to drill them "as is" while in the trail position.
Sean Blair
#40225
From: "Mike Doble (Home Office)" <mikedoble(at)wi.rr.com>
Please help. I’ve attached the elevators to the horiz stab and adjusted to have a roughly even gap at the trailing edge of the stab. Height wise though there is a 3/16” difference between the left and right elevator horns. Anyone else have this issue? Is there a fix or is this a common misalignment? Just drill away and live with the difference?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Thanks in advance.
Mike Doble
Builder 40691
Waukesha, Wisconsin
msausen
Posted: Sat May 24, 2008 3:16 am Post subject: Elevators |
Hey Jesse, how many RV-10’s are you up to now? Must be at least 5 or 6. Just curious.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Friday, May 23, 2008 4:19 PM
Subject: Re: Elevators
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Posted: Sat May 24, 2008 4:28 am Post subject: Elevators |
When in trail position the horns are both vertical and lined up fairly well. I’m talking about the horizontal alignment. If you look from the back with the elevators in trail, the bottom of the horns are uneven by 3/16”. I guess it really should not matter too much as long as they’re drilled accurately. I’m really anal about things like this….ugh! Unless someone thinks otherwise, I’ll move on and live with it.
Mike Doble
Builder 40691
Waukesha, Wisconsin
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Lew Gallagher
Posted: Sat May 24, 2008 4:42 am Post subject: Re: Elevators |
Hey Mike,
Ours were off by at LEAST that much. And after obsessing over it way too much, another builder told us, "you know, it's an airplane, not a Swiss watch" ... and we moved on.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Posted: Sat May 24, 2008 7:49 am Post subject: Elevators |
If you are referring to the elevator counter weight arms being out of alignment when the elevator trailing edges are lined up, yes, I had the same issue. I concluded you just have live with it. I'd suggest not deciding to line up the counterweights instead of the trailing edges (obviously) or even trying to split the difference (appealing but probably bad).
My thinking is that the the counterweight arms end up not being built exactly the same, perhaps one of the few spots where the CNC- match hole fabrication fails. Between the fluting and other machinations required to get the assembly together in the first place, I'm thinking that I may have pushed and pulled it together unevenly and cemented in some misalignment when match drilling and power squeezing. I'm pretty sure that given that experience, I could get both of them together more 'evenly' next time.
I'll be checking arm alignments out at Osh this year...
Oh, mine is about 3/16" too. I've moved on.
Bill "those doors may not be so bad" Watson
Durham
40605
Mike Doble (Home Office) wrote: [quote] <![endif]--> <![endif]-->
Thanks in advance.
Posted: Sat May 24, 2008 7:53 am Post subject: Elevators |
Well, I can see I answered the wrong question in another post. Yes my horns were uneven too in seemingly all directions. So much so, I found it difficult to maintain the prop edge clearance on one or the other.
I obsessed so much about it that with the help of my Tech Counseler, we re-engineered it a bit so it looked like his Pitts.
Bill "finding a boxed up YIO-540 makes a fine door sanding bench" Watson
Mike Doble (Home Office) wrote: Quote: | <![endif]--> <![endif]-->
| Do not archive
Posted: Sun May 25, 2008 5:46 am Post subject: Elevators |
Lew/Bill – Thanks for the reassurance. I’m drilling it and moving on.
Mike “Keep Reminding Myself It’s NOT a Swiss Watch” Doble (Thanks Lew – I like that!)
Builder 40691
Working on my tail.....Still
Waukesha, Wisconsin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver
Sent: Saturday, May 24, 2008 10:49 AM
Do not archive http://www.matronic - MATRONICS available via the Web href="http://forums.matronics.com">http://forums.matronics.com===================[/b]http://www.matronics.com/c=[/b] [b]
daveleikam(at)wi.rr.com Guest
Posted: Sun May 25, 2008 12:33 pm Post subject: Elevators |
Mike,
There is a "Gotcha" at this point. I am out of town in Door County, but I can come by and take a look when I get back if you like. The horns may be misaligned, but you have to be careful how you drill them. Check the archives on this.
Dave Leikam
#40496 N89DA (Reserved)
Muskego, WI
Posted: Sun May 25, 2008 5:31 pm Post subject: Elevators |
I couldn't remember the gotcha but now I do. My horns where different lengths as well.
When looking at the horns from behind, make sure to measure and drill from the shorter side into the longer side. I got lucky with this but I know at least one other builder had a problem here. If you measure and drill from the longer side, you may not have sufficient material under the hole on the short side.
Dave Leikam
Muskego, WI
Posted: Sun May 25, 2008 6:03 pm Post subject: Elevators |
Thanks Dave. I drilled them today. Here’s what happened. The aft horn by chance (per plans, drill the aft one first) was the long one. Ugh!!! Fortunately, the horns were only about 3/16” different in length so I still have 1/8” in edge distance on the short one. I wish I had seen your post earlier today. I would have drilled the short one into the long one. Disappointing but not the end of the world. It’ll work. I checked my trusty Aircraft Handbook and the edge distance needs to be ½ or more of the fastener diameter.
I’ll have to keep an eye on it. As far as one being aft of the other, it was only by about 1/16th. So I could have drilled the forward one and I would have a much better edge distance for the hole. Oh well. When I build my second or third RV it’ll be more like a Swiss watch….Those Saint RV’s must be pretty nice!
Thanks for the tip. This should really be archived. I didn’t search, maybe it is.
Mike (It really isn’t a Swiss watch) Doble
Builder 40691
Working on my tail.....but almost done!!! Yippeeee
Waukesha, Wisconsin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Sunday, May 25, 2008 8:28 PM
Dave Leikam
Muskego, WI
Quote: |
----- Original Message -----
Sent: Sunday, May 25, 2008 3:27 PM
Subject: Re: RV10-List: Elevators
Mike,
Dave Leikam
Muskego, WI
From: Mike Doble (Home Office) (mikedoble(at)wi.rr.com)
Sent: Friday, May 23, 2008 3:57 PM
Subject: Elevators
Thanks in advance.
Mike Doble
Builder 40691
Waukesha, Wisconsin Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | | 0123456789 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 1 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 2 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 3 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 4 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 5 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 6 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 7 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 8 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 9
Lenny Iszak
Posted: Tue May 27, 2008 7:16 am Post subject: Re: Elevators |
Arrrghhh, missed this thread by about 20 minutes... drilled my elevator horns by the plans and screwed up... drilled the longer horn into the shorter one, just like Mike described:(
Called Van's, they told me that it will hold up as it is. I have 3/16 of steel from the hole to the edge of the metal. They said for peace of mind I could weld it and redrill.
Tim, If you could add this on your tips page it may save someone from doing the same thing.
There goes my swiss watch airplane... has anyone tried opening up the elevators and replacing the horns with new ones?
Lenny
#40803
Tim Olson
Posted: Tue May 27, 2008 7:48 am Post subject: Elevators |
Will do...can someone type up the text in a nice complete wording of
what the problem is, and what the solution is? I'll be happy to
post it. Try to give plans page numbers and all if you can.
Lenny
#40803
http://forums.matronics.com/viewtopic.php?p=185030#185030
pascal(at)rv10builder.net Guest
Posted: Tue May 27, 2008 8:25 am Post subject: Elevators |
Following the instructions that tells one to find the most aft (11-3) and
drill a 3/16th hole 3/8 x 1/2 from the edges is not a screw up,. I did per
the plans and aligned everything fine. I have a 3/16 span from the hole to
the edge and it will be just fine in regards to strength- IMO. I'm not
worried and I assure you many before us followed the instructions as well
and they are doing just fine.
certainly make a change to the plans as a Gotcha and drill another way, no
harm but in my book I'll stick to the plans and know that Van's has this as
an acceptable building standard.
BTW- wait until you get to the fusellage, there will be 70% staring at the
plans looking ahead;10% trying to figure out if you're doing it right and
10% doing it.
Pascal
Sent: Tuesday, May 27, 2008 8:16 AM
Lenny
#40803
me(at)chadcarlson.com Guest
Posted: Tue May 27, 2008 9:09 am Post subject: Elevators |
Hi All,
As a mere mortal observer (read: wannabe builder) collecting building notes
(thanks to all of you & especially Tim!), I am wondering if someone would be
willing to provide a photo or two depicting the potential problem and
workaround.
At this point, the issue is very curious to me because without sufficient
reference material (remember - I have no plans & apparently can't get a set
until I buy my empennage kit), I am left to think this issue results from a
flawed manufacturing process. I could be completely wrong, but the elevator
horns sound like something that ought to be fashioned using fairly
consistent materials, templates, and techniques. Obviously, model aircraft
are poor analog to a full-scale build, but horns from a given model
manufacturer are virtually identical in every way from package to package,
regardless of size. Is that not the case with the RV-10 kit?
Now that I have said the above, what am I missing in my attempt to
understand the problem??
Chad E. "Swiss watch maker wannabe" Carlson
www.chadcarlson.com
"Pilots may be temporarily uncertain of their position, but they are never
lost."
Posted: Tue May 27, 2008 9:32 am Post subject: Elevators |
Chad,
The parts in question are welded steel and very similar to R/C horns except they attach to the face of the elevator spar and rib. The "gotcha" if it exists is based, on where to drill the hole between the two horns. You center the elevators then drill a hole through each horn to make your pushrod attach point. Use the link below to see the horns. Tim has "discussion plans" on his site and you can get a good idea of what folks are talking about. And for all you guys plugging away on the elevators and scratching your head....it get's much easier...HA!!!! HA!!!! HA!!!!....Wait till you bend your fifth trim tab!!!
http://www.myrv10.com/Plans/RV10_Plans_sec09-pg07.html
Rick Sked...How long does the last 5% take???
If one more neighbor asks me how much longer I'm gonna scream!!
40185
rene(at)felker.com Guest
Posted: Tue May 27, 2008 9:41 am Post subject: Elevators |
Let me try this, it has been a while since I did it..years....and I am not a
watch maker...
The horns have a relative position to each other based on the construction
of the elevators and their mounting and alignment. Even if the horns we
made perfectly, the construction and mounting of the individual elevators
will affect their end position in 3-d space.
Does that help any?
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Posted: Tue May 27, 2008 9:43 am Post subject: Elevators |
My last 10% took about 40% of the total build time........and I am not done yet, wheel fairings go to the painter in the next week or so.....
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Posted: Tue May 27, 2008 9:54 am Post subject: Elevators |
Although a good reference I think this is the step in question where one
actually drills the elevator
http://www.myrv10.com/Plans/RV10_Plans_sec11-pg03.html
Sent: Tuesday, May 27, 2008 10:28 AM
Subject: Re: Re: Elevators
Chad,
40185
