kitfoxpilot(at)msn.com Guest
Posted: Wed May 14, 2008 12:49 am Post subject: ENGINE MOUNT QUESTION? |
Hello Everyone,
Recently I had to remove my 912uls to change the Sprag Clutch! I removed the upper and lower bracket arms to inspect for cracks! can anyone tell me what they should be re-torqued to? these are the engine mount bracket arms that bolt to the sides of the engine block.
Ray
Stay in touch when you're away with Windows Live Messenger. IM anytime you're online. [quote][b]
bigboyzt0yz
Joined: 29 Jan 2008 Posts: 29 Location: Centeral Maryland
Posted: Thu May 15, 2008 8:36 am Post subject: Re: ENGINE MOUNT QUESTION? |
If you are talking about the 10 MM bolts the screw into the block they should be 310 inch pounds. Since my inch pound wrench only goes up to 50 I use my foot pound wrench and that would be 25.8333333333. Snicker Snicker
_________________ Lee Fritz in Owings Mills Md. 2002 KitFox-IV Classic/912UL/Warp drive taper tip/100% Complete ( Extras Strut fairings08, Grove gear09,) 300 hrs since Aug 07 "Have your feet on the Pedals and keep reaching for the sky". |
Posted: Thu May 15, 2008 6:45 pm Post subject: ENGINE MOUNT QUESTION? |
Your reading your email!! WOW.
Ray
| Quote: | Subject: Re: ENGINE MOUNT QUESTION?
Date: Thu, 15 May 2008 09:36:39 -0700
--> Kitfox-List message posted by: "bigboyzt0yz" <bigboyzt0yz(at)yahoo.com>
Lee Fritz in owings Mills Md. 2002 KitFox-IV Classic/912UL/Warp drive prop/100% Complete (just adding the Extras now) /71 hours time on plane since Aug 07 "Have your feet on the Pedals and keep reaching for the sky".
http://forums.matronics.com/viewtopic.php?p=183304#183304
&g========================>
