Guy Buchanan
Posted: Fri May 09, 2008 6:36 am Post subject: AW: Re: 912 with low RPM--- new vibration problem |
At 03:31 AM 5/9/2008, you wrote:
| Quote: | Has anyone had concerns or experiences about particular oils?
Currently using vsx4
Thanks for all the inputs. I tried them all bar a prop balance.
Swapped props instead and still had the same issues.
You did confirm that your engine has a slipper-clutch, right?
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Gtblu
Posted: Sat May 10, 2008 3:07 pm Post subject: Re: AW: Re: 912 with low RPM--- new vibration problem |
There was no question Guy about mine having a slipper clutch. It was installed after 50 hours on the clock.
Cheers
Gtblu
Guy Buchanan
Posted: Sat May 10, 2008 6:19 pm Post subject: AW: Re: 912 with low RPM--- new vibration problem |
At 04:07 PM 5/10/2008, you wrote:
| Quote: | There was no question Guy about mine having a slipper clutch. It was
Cheers
Gtblu
OK, good. I just couldn't remember if you'd checked that.
Unfortunately it leaves me out of ideas. Good luck!
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Thom Riddle
Posted: Sun May 11, 2008 3:06 am Post subject: Re: AW: Re: 912 with low RPM--- new vibration problem |
Have you thoroughly inspected the engine mount? Any looseness or crack at any point in the engine mount could allow a small normal vibration amplify itself. This would be an urgent safety issue too.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
