rv9ralph(at)tailsrwaggin. Guest
Posted: Sat May 10, 2008 5:00 pm Post subject: RV9-List: Settting the correct Spacing (Gap) between VS Top |
My question is - how do you set this Gap up ???
You cannot adjust the top gap very much due to pre-punch holes which
pretty must sets it for you.
| Quote: | It seems to me that the Rod End Bearings on the Rudder
Spar need to be screwed into the Rudder Spar the "
The distance indicated for the rod ends will set the gap between the
spar of the VS and the rudder, too little and the rudder will hit the VS
skin at full deflection. Too much and it will put too much load on the
VS spar and drag from too big of a gap.
The final adjustment of the rod ends it to make sure they are in
alignment with the hinge points. If they are not aligned properly you
will have flexing of the spar, friction on the hinge line and other
related issues.
Ralph
Livermore,
Wings, fuse in box
