richard.goode(at)russiana Guest
Posted: Tue May 06, 2008 6:30 am Post subject: Tragic loss |
I am sorry to have to report the death of Patrick Debonne, one of the top air show pilots in France, flying a Yak-54. It would seem that he had engine failure and a forced landing and then a fire but I have no more information at the moment.
Richard
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
dsavarese(at)elmore.rr.co Guest
Posted: Tue May 06, 2008 10:59 am Post subject: Tragic loss |
My deepest sympathy to the family and friends of Patrick.
Dennis
bhancock(at)worldwidewarb Guest
Posted: Wed May 07, 2008 9:53 am Post subject: Tragic Loss |
On May 6, 2008, at 11:58 PM, Yak-List Digest Server wrote: | Quote: |
Richard |
That is sad. Gang, are we noticing anything here? We do not have any details here, but this is the 3rd power loss and resultant fatal crash in our community in recent months. Wasn't Sergei's crash an engine failure too?
When was the last time we practiced our EP's? Better yet, when was the last time you rehearsed them in your head?
Our equipment is so reliable it lulls us into complacency and puts at disregard the life and death matters of those few vital seconds and critical decisions that need to be instinctive in that time that could well spell the difference between a favorable and unfavorable outcome. I, for one, don't rehearse as often as I should...
On this note we are having a Emergency Procedures seminar at All Red Star (May 14-1 . This takes recent real life accounts of engine failures (Bill Blackwell is going to tell his story) and combines them with an emergency egress and crash survival seminar by former USN Survival Training Specialist Noah Graeme. Hopefully this will get us thinking about the things we often conveniently ignore most of the time...
Barry
PS There is still time to register for All Red Star at http://www.flyredstar.org/helios//events/index.php?com=detail&eID=18
Posted: Wed May 07, 2008 12:19 pm Post subject: Tragic Loss |
Sergei Boriak's crash was not from engine failure, even though he had a
rather extensively modified M-14PF, it was running like a sewing
machine. Just wanted to clear the air on that fact.
One thing more I would like to relate for folks who might be interested.
I was flying my 50 over the Outer Banks of North Carolina a few weeks
ago when the engine just stopped dead cold for a short period of time...
Probably no more than 5 - 10 seconds. However it was enough time to
check fuel level, pressure, oil pressure, pump the primer and system
pressure a few times quickly, and then it was time to pick a place to
land on the beach. As I was looking, the engine started running again,
but rather badly. Some stumbles and surges, but enough power to keep
flying. I took a chance and headed out over water directly for the
closest airport. As I got over MRH airport, with it safely made, I
decided to check the one thing I had not to this point. The MAGS. When
I selected one mag, the engine started booming and banging horribly. I
immediately switched to the other mag which ran really well, but with an
occasional miss. The end of the story is that I climbed to 15,000 feet,
and then glided back to New Bern North Carolina with no further
problems.
The left mag was bad. I do not know what in it was bad. The right mag
had failed about 100 hours earlier with sheared internal gearing. It
just went Tango Uniform with no other indications. Found it on engine
run up. THIS MAG however, did something I have never experienced
before. It made the whole engine STOP .... Which makes NO sense to
me... And then whatever it was "changed" to where the engine then RAN
.. Albeit pretty damn badly. How can this happen with two mags? It's
beyond me, but it happened.
The left mag was completely bad. The right mag had one intermittent
spark plug wire. Everything has been changed, engine runs perfectly
now.
So.. The left mag failed within 100 hours of the right mag failing. The
engine has about 780 hours on it.
Just something to consider along with everything else.
Mark Bitterlich
N50YK
cjpilot710(at)aol.com Guest
Posted: Wed May 07, 2008 12:53 pm Post subject: Tragic Loss |
In a message dated 5/7/2008 4:21:05 P.M. Eastern Daylight Time, mark.bitterlich(at)navy.mil writes:
I had a very similar happening. It turned out to be a missing Woodruff key on the rotor shaft. The mag was a Chinese mag that I was using on my M-14p at the time. The mag had 250+ hours since its "overhaul". The only thing that had been holding the gear in place on the shaft was the nut and its lock washer. My engine didn't totally quite although I thought it was going to.
Jim "Pappy" Goolsby
problems.
... Albeit pretty damn badly. How can this happen with two mags? It's
now.
Mark Bitterlich
N50YK
Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food.
dougsappllc(at)gmail.com Guest
Posted: Wed May 07, 2008 2:08 pm Post subject: Tragic Loss |
Mark,
You might be a victim of the Russian and Chinese for that matter, overhaul system in which they just look at a part and make a decision rather or not in their opinion the part will last another 500 hours. Hal Provo just bought a M14P that had absolutly trash on it for mags and it was a fresh overhaul. Of course if your engine is "since new" and the mag numbers match those in the back of the engine log it's a different story. Personally if I install a overhauled engine in my aircraft the first thig I do is change out the mags for factory new ones. In my opinion (at) $750.00 each it's the best money I can spend.
On Wed, May 7, 2008 at 1:51 PM, <cjpilot710(at)aol.com (cjpilot710(at)aol.com)> wrote:
| Quote: | In a message dated 5/7/2008 4:21:05 P.M. Eastern Daylight Time, mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil) writes:
Jim "Pappy" Goolsby
problems.
now.
Mark Bitterlich
N50YK
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644 [quote][b]
Posted: Wed May 07, 2008 2:44 pm Post subject: Tragic Loss |
Thanks all for your thoughtful inputs. I have benefited from reading
your thoughts and experiences.
Doug... My mags were "since new". My engine is a "first run" and I have
the logs. Your thoughts on mag replacement seems to be very well
founded. Lesson learned on my part.
Mark Bitterlich
P.s. Interesting thought on the woodruff key as well Pappy. I am
trying to think how I could check that easily.. But without removing
that bottom adjustment assy., I can't think how! Can you SEE it? I am
going home tonight and check!
B747crew
Posted: Wed May 07, 2008 3:04 pm Post subject: Tragic Loss |
That stuff will get your ass tight enough to make a diamond.  Jack
_________________ Jack Snodgrass
4305 Claridge Ct.
Apex, NC 27539
919-745-7434 |
Posted: Wed May 07, 2008 3:42 pm Post subject: Tragic Loss |
I neglected to add that part.
Yes... Turning away from land (even though it was nothing but sand
dunes) to fly over rough cold water, with no boats in sight, at 100
feet, barely keeping altitude with an engine slinging M-80's every few
seconds did indeed negate the need for toilet paper for quite some time.
Thank you Jesus.
Mark Bitterlich
N50YK (happy to say)
Posted: Wed May 07, 2008 6:00 pm Post subject: Tragic Loss |
Went down that the road with a bad mag too! It is never fun to turn away
from the runway to get landing spacing!
Doc
Posted: Wed May 07, 2008 7:33 pm Post subject: Tragic Loss |
In a message dated 5/7/2008 6:45:43 P.M. Eastern Daylight Time, mark.bitterlich(at)navy.mil writes:
Its actually fairly easy to check. If you take off the mag cap, you'll see the rotor. Simply try to turn it. If it turns the woodruff key is out or the shaft is sheared. With the woodruff key out the gear below the rotor next to the coil is allowed to spin freely, throwing off the internal timing of the mag. To see the gear itself, you would have to remove the mag and than remove that side section that gives you access to the coil. That gear is right there. You can't see the woodruff key if the gear is properly mounted.
Pappy
Mark Bitterlich
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
Posted: Thu May 08, 2008 1:47 pm Post subject: Tragic Loss |
Never thought of the obvious. Thanks Pappy.
Mark
wlannon(at)persona.ca Guest
Posted: Thu May 08, 2008 7:28 pm Post subject: Tragic Loss |
A caution note here folks.
If you are able to rotate the rotor through an angle of about 10 to 12 degs. and it returns to original position on release don't go yanking the mag.
You have an auto advance magneto type M9, M9-25M, M9-35M (which will turn a little further) or a Chinese CD-5.
These are not standard for the M14P (should be M9F) but there may be some out there replacing the original fixed spark M9F. I know of at least one such M14P.
Walt
