mikedoble(at)wi.rr.com Guest
Posted: Tue May 06, 2008 5:03 am Post subject: Trim Tab Frustration |
After many months of putting it off, I bonded the trim tabs and elevator trailing edge with proseal (not too terrible of a job by the way). Per the instructions Page 9-17 – 9-18 and Figure 2 on 9-19 it says to rivet the bent tab ends on the trim tabs with CS4-4. Huh? Did I miss something? Instructions say to drill and dimple #40. CS4-4 requires #30 hole and dimple.
Please help.
Mike Doble
Builder 40691
Working on my tail.....
Waukesha, Wisconsin
tsts4
Posted: Tue May 06, 2008 5:36 am Post subject: Re: Trim Tab Frustration |
Mike,
The last sentence in step 1 on page 9-17 has you drill those holes with a #30. The gotcha (sort of) is step 6 where it tells you to dimple all the holes in the skin but not specifically the close-out tabs. And then you rivet, as you pointed out, in step 10 with the CS4-4s.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
ogdenk
Posted: Tue May 06, 2008 5:51 am Post subject: Trim Tab Frustration |
Mike,
I just went through this myself. I just drilled with the #30, and by bending the tabs out a little I was able to re-dimple with my squeezer.
Kent Ogden
#40710 (tailcone)
| Quote: | >> "Mike Doble (Home Office)" <mikedoble(at)wi.rr.com> 5/6/2008 9:00 AM >>>
After many months of putting it off, I bonded the trim tabs and elevator trailing edge with proseal (not too terrible of a job by the way). Per the instructions Page 9-17 - 9-18 and Figure 2 on 9-19 it says to rivet the bent tab ends on the trim tabs with CS4-4. Huh? Did I miss something? Instructions say to drill and dimple #40. CS4-4 requires #30 hole and dimple.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Please help.
Mike Doble
Builder 40691
Waukesha, Wisconsin
Andy Turner
Posted: Tue May 06, 2008 4:27 pm Post subject: Re: Trim Tab Frustration |
Yep, add me to the list who failed to drill #30 and dimple those end tabs when it would have been easy.
_________________ Andy Turner |
Posted: Tue May 06, 2008 6:09 pm Post subject: Trim Tab Frustration |
Ok, Ok, Ok, don’t all come at me at once. Step 1, page 9-17…drill #30…..
I’ll crawl back into my hole now….
Mike Doble
Builder 40691
Waukesha, Wisconsin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Doble (Home Office)
Sent: Tuesday, May 06, 2008 8:01 AM
Subject: Trim Tab Frustration
Please help.
Mike Doble
Builder 40691
Waukesha, Wisconsin
= -Matt Dralle, List Admin.[/b][/quote]http://www.matronics.com/con[/b] [b]
Posted: Tue May 06, 2008 6:34 pm Post subject: Trim Tab Frustration |
Grasshopper.....your journey has just begun....many more diffcult challenges await you in your quest..
Rick Sked
40185, page 19 is a far distant memory
Finshed the baffeling
daveleikam(at)wi.rr.com Guest
Posted: Tue May 06, 2008 6:46 pm Post subject: Trim Tab Frustration |
Come on now Mike, stay out, it's nice to hear from you once in a while!
Dave Leikam
#40496 N89DA (Reserved)
Muskego, WI
Fuel lines
tsts4
Posted: Wed May 07, 2008 1:03 am Post subject: Re: Trim Tab Frustration |
Yeah, no worries Mike. This is an easy fix. The only reason I didn't miss this myself was pure dumb luck. Before I hit that section someone else had asked the same question over on the VAF forum so I avoided missing the step simply because I was at the right place at the right time. If you have not done so. I recommend taking a look at Tim Olson's site, www.myrv10.com. He's got a tips and hints page compiled from a host of builders.
